Question about Acer Computers & Internet
Acer 5740 no power. no light etc. charger is ok. also charger connector on motherboard is ok. what can be the problem. seems like some faulty parts on motherboard
Acer 5740 model i3 processor
  • Acer Master
  • 5,660 Answers
Charger = AC adapter
Charger connector = DC Power Jack. Abbreviated as DC_IN
Faulty parts on motherboard?
Power MOSFET's, and/or MLCC's, and/or SMD fuse.
Could also be bad SMD/SMT diodes.
!O_O!
Using the HP Pavilion dv6000, and Pavilion dv9000 series of Notebook PC's, as an example,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
See the first photo? That '8-legged creature' is a Fairchild Semiconductor Industries - FDS6679 - Power MOSFET.
Those '8-legs' are J-leads.
http://www.mouser.com/Search/Refine.aspx?Keyword=fds6679
The FDS6679 is obsolete, so we will use the cross-reference example - FSS6679AZ.
http://www.mouser.com/ProductDetail/Fairchild-Semiconductor/FDS6679AZ/?qs=sGAEpiMZZMsrr1kXJis%252bJwONNw%252bcopWaDOKRGBUF24Q%3d
Observe the second photo down. Has the Alpha & Omega Semiconductor Limited - AO4407 - Power MOSFET in it.
http://www.mouser.com/Search/Refine.aspx?Keyword=AO4407
Here we see it is obsolete also. Using one of the cross-reference examples,
http://www.mouser.com/ProductDetail/Diodes-Inc/DMP3020LSS-13/?qs=%2fha2pyFadujguNNSgppBRqXbOxXLwzGsZm9SWxz1EqWpzoSJOpHpWA%3d%3d
By the way, did you notice that one FDS6679 is $1.01 USD?
The AO4407 substitute above is 78 Cents USD.
Looking back at the second photo again, with the AI4407 in it;
Look at the immediate bottom/right corner, or the Ai4407 circled in Yellow.
That is an MLCC. Multi-Layer Ceramic Capacitor
You will also see one to the immediate right.
Small rectangular object, with a dark wide band in the middle of it.
There's one above it, one above that one (Top), one to the right of the top one, and one to the right of it.
There are 4 smaller examples to the bottom/left corner of the AO4407.
Look to see if any are burned/blackened/blistered
http://www.youtube.com/watch?v=3NN7UGWYmBY
http://www.youtube.com/watch?v=5uiroWBkdFY
http://www.youtube.com/watch?v=fYz5nIHH0iY
You can use a low wattage soldering iron. You don't need a soldering station.
Capacitors that we use in computers, are rated in Microfarads.
(uF)
I'm going to show examples of MLCC's, that are rated in capacitance at 4.7uF, and 16 Volts. (DC)
[They are also SMD/SMT
Surface Mount Device/Surface Mount Technology.
So are the Power MOSFET's ]
Main chart,
http://www.mouser.com/Search/Refine.aspx?N=516259
Scroll down.
4.7uF / 16VDC examples,
http://www.mouser.com/Passive-Components/Capacitors/Ceramic-Capacitors/Multilayer-Ceramic-Capacitors-MLCC-SMD-SMT/_/N-b2cj?P=1z0wrjcZ1z0x565
Scroll down.
Fuse - SMD/SMT
http://www.mouser.com/Circuit-Protection/Fuses/_/N-5g3l?P=1z0z7ym&Keyword=SMD+fuse&FS=True
Regards,
joecoolvette
Posted on Jan 16, 2013
SOURCE: Problem with motherboard MSI P35 Neo2-FR
I just bought a msi p7n sli platinum. my board is better than yours hahaha, j/k, all playing aside, I have the same problem with the 8pin power connection. A power supply rated v2.2 has the proper 8 pin connection, but 2.1 or lower doesn't, regardless, plugging in two 4 atx pin connectors wont work because you'll be taking 4pins away from the main 24 pin plug (even though my manual says 20 pins will work, it doesnt, they lied!!!). However, when I put the normal configuration of 24 then the 4 in place of the 8, it works fine. The only thing i would worry about is overclocking, thats when you need to be careful with your voltages, etc. Also, I read somewhere that the 8 pin is actually 2 four pins, each 4 pin is for each side of the cpu...
Posted on Aug 13, 2008
SOURCE: Acer Motherboard MS6772
This board uses typical INTEL styled pin header for front panel connections and is used on many major OEM boards. Here is the pin assignment:
Pin 1-3 HD LED (Red color in this particular board)
Pin 2-4 Power LED (Green)
Pin 5-7 RESET
Pin 6-8 Power ON/OFF
Note: Pin 10 is empty
Posted on Sep 13, 2008
bluegreenash
  • 661 Answers
SOURCE: Gigabyte Motherboard USB Connection
the motherboard manual should have a pin out diagram in the manual for all the pin headers showing you exactly where things go....
Posted on Sep 30, 2008
joecoolvette
  • 5660 Answers
SOURCE: board power is ok but run cpu&fan plz give me answer
1.Check the Electrolytic Capacitors on the motherboard. Specifically the one's around the processor. These are Voltage Regulators for the processor.
The processor must have DC voltage within a specific range. This zone, or range is very small. Too much voltage, the processor turns off, or won't start up. Too little voltage does the same.
This link will show what Electrolytic Capacitors look like, and what they look like when they are failing, or have failed,
Electrolytic Capacitors are the number one weakest link, of computer hardware failure.
For ease of explanation of construction of them, they look like little aluminum pop cans, they have a rubber seal at the bottom of them, and inside them they have Electrolytic paste.
When the capacitors start to fail, the paste inside develops a gas.
(Hydrogen gas) This gas expands, and pushes the against the seal. The seal's edge pushes out of the 'can', and paste starts to ooze out. So much paste loss, and the capacitor operates at a weakened state. Too much paste loss, and the capacitor fails.
Besides the motherboard capacitors failing, the next area to watch are the one's in the power supply. Power supply's have voltage rails inside. More specifically, they have a 3.3 volt rail, a 5 volt rail, and a 12 volt rail. Voltage may be thought of as the 'speed' of electricity. Amperage may be thought of as how much.
Volts times Amps = Watts.
If you have a power supply with weak, or failed capacitors, you won't be getting the full wattage your computer needs. Your motherboard power light will light up, other lights will light up, fans will spin, and the harddrive sounds like it's working.
ALL the lights use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
The harddrive just sitting there spinning it's platters, uses about 3 to 5 Watts.
PROCESSORS use 55 to 125 Watts!!
So you see you can have lights lit, fans spinning, and the harddrive spinning, but when BIOS tries to turn the processor on, it can't!
Not Enough POWER!
Posted on May 24, 2009
SOURCE: power switch pinout for the 02R4087 motherboard
Progerssed the internet and got a FREE note Free response. Did not have to spend money on your pathetic permium system. Why should you charge for what others give for free?? Parasites
Posted on Jul 10, 2009
Acer aspire 5740 no power
It sounds lie the charger jack in the laptop is broken. When you installed the new battery the laptop had power to run several hours but once the battery drained it could not be charged back up. Check the charging jack when the charger plugs into. I would bet that you will find to loose or broken. These jacks can be replaced but you will need to take the laptop apart and do a little soldering to do the job. Check Ebay for the jack, you can do a search for your model laptop along with "power jack", the parts should run less than $10 with shipping.
Sep 12, 2012 | Acer Aspire 5740-6025 Notebook
How do i fix an Acer aspire 4730z that will not charge the battery and has the charge light no longer comes on, is the motherboard bad?
Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
Sep 09, 2012 | Acer Aspire Computers & Internet
Sir i have acer 4720Z series laptop. when I plug in the power adapter it show adapter light green. when adapter pin connect the laptop then light show blink and laptop not charging.
Your laptop battery seems to be broken.
To be a 100% sure, can the computer run on only battery?
Try to have the computer plugged in to the charger for a couple of hours without starting it.
Feb 28, 2011 | Acer Aspire 4720 Notebook
I've had my acer 5538 laptop for less than about a year now.. but now the charger isn't charging anywhere that i plug it in. what can i do?
Whenyou connect the power adapter into the laptop, does the power LED light up? Ifnot then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Feb 12, 2011 | Lifetime Acer Aspire 5538 Replacement...
Can i connect a video card on my acer aspire 5740?
i think you can, but this laptop has great integrated graphic card, it use Integrated Intel® HD Graphics or Discrete ATI Radeon™ HD 5650 graphics or Discrete ATI Radeon™ HD 5470 graphics
this graphic card can make great picture for HD video
Feb 05, 2011 | Lifetime Acer Aspire 5740 Replacement...
My acer 5740 LAPTOP blinks with a sound. Please advice to solve this problem
Try re-seating the RAM. Beep codes usually signal a hardware problem, and 90% of the times it's a RAM related issue. If you have two sticks of RAM, try starting the laptop with one stick at a time, and see which one causes the problem.
If this post was helpful and informative please vote for it with a Thumb Up. Thank you.
Jan 19, 2011 | Lifetime Acer Aspire 5740 Replacement...
My charger has been plugged in but the battery is not charging. i have an acer aspire 5740 laptop
me too the same... When I plugged in the charger the power indicator shows battery in charged 100% when I removes it goes to 0%.. I installed ubuntu on acer 5740..
Aug 31, 2010 | Computers & Internet
AC Adapter
Hi Kayla,
It is most likely the power connector on the laptop is faulty and the power adapter is not making electrical connection with the laptop.
You stated that by moving the touchy power plug that you could get it to charge, this is proof that you have a faulty power input connector on the laptop.
Check the power adapter's laptop connector with a multimeter, if there is voltage at the connector then the adapter is OK, the voltage reading should be as stated on the label or slightly higher.
You may be able to get the power connector repaired (it may need resoldering because of a dry joint) or it may need to be replaced.
Jan 02, 2009 | Acer Aspire 3610 Notebook
Computers & Internet Logo
161 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
