Question about Kenmore 47566 Front Load Washer
Washer will not drain
I have cleared the hoses and got the washer to work a couple of times but it will not drain now at all.
  • 130 Answers
Did you check if the pump was blocked?
Posted on Jan 24, 2009
catriver
  • 878 Answers
SOURCE: Washer doesn't drain
Flore, there is a check ball that sits in the reservoir that goes to the pump. That could be all gunked up. I assume you have power to the new pump. Sometimes the motor conroller can be the culprit, but if you have power we'll rule that out. You can remove the basket to get at the reservoir and check ball. You will have to pop the top, remove the basket and nutate cover and unbolt the basket. If you don't have power to the new pump then check the motor controller. This will be the board on the left under the control panel. There will be a P-5 connection. 3 prong. You will want to see if there is 120V on the tan/yellow to the white wire while in drain. If you don't have that voltage, then you motor controller is causing the problem. First be sure you have 120V on the P1 connector, thats power in. Catriver
Posted on Aug 10, 2008
  • 16 Answers
SOURCE: LD light
something is clogging your drain pump
Posted on Nov 23, 2008
  • 56 Answers
SOURCE: Drain pipe for washer overflows..how do I clear it out?
if the water is coming up from the drain it means your drain is restricted you either need a plumber or you have to run a plumbers snake down the drain to clean it outl.
Posted on May 30, 2009
  • 107 Answers
SOURCE: Receive error code F35 and SUD at start of washer.
SUD = Suds detected during wash cycle
Too much detergent run an empty cycle no soap.
or
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch,
and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
F35 =ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer
component detected by the Steamer Electronic Board.
1. Check if pressure hose is fixed correctly.
2. Check if the airtrap is not blocked.
3. Check if the hose is not blocked.
I would first inspect and check the drain filter to see if it is patially clogged. Remove the front lower panel. Look for the white filter near the pump. Place a pan underneath it and then remove it. I have found these clogged with socks, coins, nails, ect..
Posted on Nov 06, 2009
SOURCE: Washer wont spin or drain
This happened to mine, too. The lid close button was stuck open, had to stick the end of of hanger into where the lid closes, we finally duct taped inside to hole to make it think that the lid is closed.
Posted on Apr 17, 2010
Whirlpool cabrio washer f 33 error code
Whirlpool Cabrio strange fix. This thing acted strange, If I went to drain spin it would run trying to work but I could not cancel this function and would have to unplug to reset the machine I had the F 33 fault code, I pulled the drum out and found about $2.00 worth of change. Then I put the washer on it's face and removed the back panel then disconnected the hose to the pump and spun the impeller to make sure no blockage was present. lt was clear so I reassembled the washer and washed one load of clothes and had the same problem occur. Washer would not drain or spin. Went back to work on the washer and in the process of moving it out from the wall I disconnected a 4' hose that I hadn't disconnected the first time that I have running to the drain from the drain hose on the washer, at this point I noticed water coming out of the washer drain hose. To make a long story short my 4' drain hose addition had a ripped up sock plugging the hose. Unbelievably this sock made it through the washer and pump and plugged up the hose. I never thought a sock could make it past the impeller so if your Cabrio is not draining or spinning check the hose past the pump, you may have an easy fix.
May 16, 2013 | Washing Machines
Intermittant 0E error
I believe the OE error is generated if it takes too long for the washing machine to drain. If the drain is blocked or the pump is is not functioning well, the error will show up intermittently. I believe we experienced a similar error a couple of years back. After verifying the drain was clear, I replaced the drain motor, I believe the washing machine was about 5 years old at that time.
Feb 28, 2013 | LG WM-2277HW Front Load Washer
I cleaned the pump filter after getting sud error. now i get F 21 code.
Press the pause cancel button 2 times this should clear it. If it does not and the filter and drain hose are clear you will need to replace the pump.
F21 Fault Code Repair
LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:
After 4 minutes the "Sd" error will be displayed, then 4 minutes later the "F/21" error code will be displayed.
Press PAUSE/CANCEL two times to clear the display.
LONG DRAIN
NOTES:
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
LONG DRAIN
NOTES:
Nov 03, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Error code f 21, what does this mean?
The error code F-21 refers to Long Drain. The washer has sensed that it has not drained out completely and cannot go into further cycle.
If yours is a HE 2 washer, afer few minutes, Sd error will be displayed and then after couple of minutes F21 error code will appear. Water valves will be turned off and stops running.
If yours is a HE front load, when drain time exceeds 8 min, F21 error will be displayed. The water valves will be shut off and pump will stop running.
Generally, by re-storing the power to washer, it may fix the problem.
You may press the pause or the cancel button twice to clear the display.
You may have to double check the drain hose to see if there are any kink, clogs.
Also, you may unplug your washer, turn the circuit breaker off for 1-2 minutes and then plug it back in to check if it works. After this, check to see if the washer drains.
May 18, 2010 | Washing Machines
My he5t is giving me f25 code. i have pressed stop and tried to drain but i get f25 again. do i need a new belt?
Here is the info on "F25":
f25_code.jpg?t=1177554999
When you open the top of the washer, look at the black rubber hose leading up to the pressure switch. If the hose is kinked, it will fool the pressure switch into thinking the washer is either full of water or it did not see a water level change after the water valves have been on for a period of time. These failures generate the F20 / F25 codes.
To Clear the F25 Fault. Disconnect & Connect the "Water Level Presure" switch plug, a couple of times, Give it a couple of light "Taps" Reconnect again, and see if that works, it should.
Feb 16, 2010 | Kenmore Elite HE5t Washer
Whirlpool Duet washer... code flashes saying 02 F ... Help!
F-02(Long Drain)
HI. This code is an indication of a failed drain cycle(Long Drain Issue). Kindly, follow the steps below to address this issue further.
If the drain time exceeds eight minutes, the water valves are turned off and "F02" is flashed.
NOTE: After four minutes the "Sud" error will be displayed, then four minutes later the "F02" error code will be displayed..
Possible Causes / Procedure
Dec 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Maytoag Bravos Top load washer drains really
Is the drain hose kinked or clogged? Is the drain hose installed properly? look in the installation Instructions, Press POWER/CANCEL to clear display........ hope this helps.....
Jul 09, 2009 | Maytag Bravos MTW6600T Top Load Washer
Whirlpool Cabrio washer is leaking water
The problem happens when your installer throws away the drain hose u-bend, and stuffs the hose as far as it will go down the drain pipe. When this happens the end of the hose can get pushed under water, which causes the washer to siphon out the wash water when it fills. This results in an LF "Long Fill" error.
The solution is to get your installer to come back and install the washer properly.
Jun 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio Washer LD error code
Is there water in the bottom of the tub? If yes then open back of washer and remove drain pump (on left side) and pull off of tub and clear whatever is blocking its impeller.
If the water is all gone and drained but pump stays on for several minutes and then gives "LD" fault then open back and check the small clear tube that is attached to the tub. Make sure is not blocked with debris and check tube and tub for anything that could block the small clear tube. If these are ok then remove 3 screws in back of the control panel, pull open control panel and check the clear tub all the way up from the tub to the washer controller board (computer) make sure it is not kinked or disconnected. If not then the problem is most likely the pressure sensor on the (computer). This unit will have to be replaced.
You can test the sensor by doing the following: 1. When the "LD" fault comes on start by pressing the pause button. then pull the clear tube off of the computer board. Then attach a tight fitting drinking straw over the sensor. Press the start button and wait for 60 seconds - If the washer does not start the spin cycle on its own after the 60 seconds then **** on the drinking straw that you attached to the pressure sensor earlier. The sucking action should reset the sensor thus telling the computer that the water is drained and it will start the spin cycle. Just remember if you have to do this to get the washer to spin - that means the sensor is damaged most likely from moisture traveling up the tube over time. The computer board will need to be replaced. I believe it costs $205 without shipping. Hope this helps.
Oct 13, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer will not leave the drain cycle
Press PAUSE/CANCEL twice to clear the display then
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
It's because of a Long Drain condition. If the drain time exceeds 8 minutes, the water valves are turned off the code is flashed.
But Note: After 4 minutes the "Sud" error is usually displayed, then 4 minutes later the error code is displayed.
Jan 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 47566 Front Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
