Question about Dell LATITUDE Computers & Internet
Changed msconfig now will not boot
Changed msconfig and restarted computer and now will not boot
    Novelist:
  • 250 Answers
Try to start laptop in Safe Mode. Restart laptop and before black screen disappears click F8 key, wait for a while and a menu will appear having multiple options. Select Safe Mode option for windows StartUp.
Download system optimizer Reginout, Install it and by using its StartUp and Service optimizer feature adjust the startup programs.
Posted on Jan 18, 2013
Vista only runs in safe mode
1. Press the Start button.
2.
Type msconfig in Start menu or click 'run' and type msconfig.
3.
Open the program. (Click msconfig icon if it doesn't open automatically)
4.
Also, open the command box. Click Start > run > and type cmd.exe and open. (If the above method does not work, using "msconfig", your "System Configuration Utility" program should open on your screen.
5. Click on the "General" tab on the utility program. Select the "Normal Startup" option. Click "Apply" and "Ok" to confirm the change back to normal mode.
6.
Follow the on-screen prompts to restart the computer. Your computer should reboot normally.
7. IF
this doesn't work: Click on the "Boot" tab in " msconfig" > the "Safe boot" option should be unchecked.
IF that doesn't work, go to "msconfig" again and click the Startup tab. Disable all startup programs or, if you know which one is causing the problem, just a single program.
Hope this helps! Godspeed
Feb 06, 2014 | E-Machines Computers & Internet
I let the HP asst. Install a bios update and the install is stuck at 40%. What can I do to get out of the update?
Turn on the computer and begin hitting the "F8" key when you see the BIOS screen.
This will take you to the Safe Mode menu.
Use the arrow keys to highlight "Safe Mode," then hit "Enter" on your keyboard.
This will boot your computer in Safe Mode, a minimalist manner of operating Windows that runs only essential Windows files.
If using Windows XP in Safe Mode, click the "Start" button and then click "Run." In the box that pops up, type "msconfig" and hit "Enter."
If using Windows Vista or Windows 7, click the Windows logo in the bottom left corner of the screen, type "msconfig" in the search field and then hit "Enter."
This will open the System Configuration Utility.
In the System Configuration Utility box, click the "Services" tab, check the box that reads, "Hide All Microsoft Services," click "Disable All" and then click "Apply."
In the System Configuration Utility box, click the "Startup" tab, click "Disable All" and then click "Apply." Next, click the "Close" box.
A box will pop up that prompts you to restart your computer.
Select "Restart" and let the computer restart itself, allowing it to boot to Windows normally.
If the computer still stalls when trying to boot to Windows, restart the computer and boot to Safe Mode again.
Run your antivirus program in Safe Mode, deleting any files that are flagged as viruses, spyware or malware. Restart the computer and boot to Windows normally
hope this helps
Sep 29, 2012 | Computers & Internet
Windows update error code 8024a000 in windows vista 32 bit system won't allow any microsoft programs or service to install after manually downloading them either.
o overcome his error do the following.
  1. Go to Start then Run menu.
  2. Type MSCONFIG and press enter
  3. Under the 'BOOT' tab, tick the 'Safe Boot' box and select 'Minimal'
  4. Press OK and proceed to restarting the computer when prompted
  5. Once computer restarts log in and open Window Explorer
  6. Navigate to your Windows directory and look for SoftwareDistribution folder
  7. Rename this folder to SoftwareDistribution.old
  8. Go back into MSCONFIG and turn off 'Safe Boot' and restart
  9. Run Windows update again.
Good Luck!
Jul 15, 2011 | Computers & Internet
I cannot get out of safe mode
Hi! Welcome to FixYa,
If the affected computer/laptop has Windows XP, please do the these steps:
Click Start, Run and type MSCONFIG
1. Select the Boot.ini tab
2. If you have dual-boot setup, select the appropriate entry under [operating systems]
3. In the Boot Options section at the bottom, uncheck /SAFEBOOT option
4. Click OK
5. Restart Windows
Or if it has Windows Vista or 7 please do the following:
1. Please go to Start Button and on the search bar please type msconfig then on the result on the top please click on Msconfig.
2. System Configuration Utility Window will show up.
3. Please go to Boot tab and uncheck Safe Boot.
4. Click OK and restart.
Hope this helps and you have a great day!
Jun 20, 2011 | Toshiba Computers & Internet
I cant seem to get into safe mode on my comp
When you first turn the computer on Keep tapping F8 if that doesnt work Try F5.
If you can get into Windows then you can make the computer boot into Safe mode next time you start it up using MSConfig.
If you have XP you will need to Start > Run > msconfig.exe Windows Vista / 7, Start > (Type in the start search box under All Programs) msconfig, you will notice it come up and the top of the box > Click on it and when prompted by UAC click Continue / Yes.
Now that you are in MSConfig under the general tap select Diagnostic Startup, press apply then OK, you will not be prompted to restart the computer. Restart and it will put you into Safe Mode.
Apr 25, 2011 | Computers & Internet
Gigaset 567 wireless router. unable to connect from desk top to laptop
try to disable the antivirus software and try to connect again, if this doesnt work try to go to safe mode w/ networking
to go to safemode w/ networking you can try this options:
when using windows XP, Vista and Windows 7. try to restart the computer as soon as the computer turns on immediately strike F8 key continuously, in advance menu option or advance boot option use the arrow key to highlight safemode w/ netwokring and hit enter ( if you see you operating system just hit enter again )
or try this one:
for windows XP,
click start
click run, type in msconfig
in msconfig click the tab for Boot.ini click safeboot at the bottom and choose network, hit enter
click apply and ok
for windows vista and windows 7
click start button or the pearl
type in msconfig in the start search and hit enter
click the Boot tab
click the safeboot and choose networking
click apply and ok
i hope this helps
Pls rate my resolution thanks!!
Mar 04, 2010 | Siemens Computers & Internet
This seems to be a common problem. The device seems to be trying to start or "boot" but will not function. The power button will not light up and the device does not respond to commands from computer. What...
Hi..
I suggest you to disable all HP related items, which will not startup at system boot up and might not cause any issues.
For Windows XP
Disabling HP Applications from MSCONFIG:
1. Click Start and select Run.
2. Type MSCONFIG and press Enter.
3. Click the Startup tab.
4. Clear the checkboxes for all HP related applications.
5. Click OK.
6. Restart the system.
You can restore any of the removed items by repeating the above steps and replacing the checks for the designated applications.
For Windows Vista
Turn off the Terminate and Stay Resident programs MSCONFIG in VISTA
1. Click the Start icon.
2. In the Start Search text box located above the Start icon, type msconfig and then press Enter.
3. On the User Account Control window, click Continue. The System Configuration window displays.
4. Click the General tab.
5. Select the Selective Startup check box.
6. Verify that the Load Startup Items check box is not selected.
7. Click the Services tab.
8. Select the Hide All Microsoft Services check box.
9. Click Disable All.
10. Click OK.
11. Click Restart to apply the changes. The computer automatically restarts.
NOTE: After the computer restarts, a System Configuration message might display. If it displays, Ignore this message.
I hope this helps you...
Thanks..
Roger
Oct 11, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Cant acess safe mode in windows xp, just cycles startup screens
Here are some steps to use MSCONFIG to force your computer into SAFE MODE
  1. Click on Start and then Run.
  2. In the text box in the Run window, type msconfig and click OK. This will open the System Configuration Utility program.
    Note: Do not make changes in the System Configuration Utility other than those outlined here to avoid causing serious system issues. This utility controls a number of startup activities other than those involved with Safe Mode.
  3. Click on the BOOT.INI tab located at the top of the System Configuration Utility window.
  4. Check the checkbox next to /SAFEBOOT and click OK.
  5. You will then be prompted to either Restart, which will restart the PC immediately, or Exit Without Restart, which will close the window and allow you to restart the PC manually.
  6. After the restart, the PC will automatically boot into Windows XP Safe Mode.
    Note: Windows XP will continue to boot into Safe Mode until the System Configuration Utility is configured to again boot normally.
  7. When your work in Safe Mode is complete, click on Start and then Run. Type msconfig in the text box and click OK.
    This will again open the System Configuration Utility program.
  8. Choose the Normal Startup radio button and click OK.
  9. You will then be prompted to either Restart, which will restart the PC immediately, or Exit Without Restart, which will close the window and allow you to restart the PC manually.
  10. After the restart, the PC will boot into Windows XP normally and will continue to do so.
    These instructions were written by About.com
    http://pcsupport.about.com/od/tipstricks/ht/smsysconfig.htm
May 24, 2009 | Microsoft Windows XP Media Center Edition...
Hp doesn't start. Always open xp window saying gathering info Please wait while windows configures scan. Installed cd with no problem.
As soon as you start rebooting your computer, hit F8 over and over again until you get into a boot menu. Pick "Safe Mode."
It should boot. This is a temporary fix.
When you're in, click Start, then Run. Type in "msconfig" without the quotes. Hit Enter.
A new window pops up. Click on the Startup tab. Find a file called hpqtra08.exe and undo the checkbox. Hit Apply and OK. msconfig will ask you if you want to restart with the changes; you do.
Your computer should boot normally. When it does, msconfig will ask you if you want that menu to appear next time you boot; you do not.
Dec 05, 2008 | Computers & Internet
Computers & Internet Logo
26 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
