Question about Bose Av3-2-1 Series Ii Media Center Receiver Dvd Av 321 Av321 Works Perfect
Disc tray will not open?
Connected all speakers to receiver and turned on. disc tray will not open and makes a humming sound??
    Top Expert:
  • Bose Master
  • 44,161 Answers
There could be a disc jammed in the tray. The humming sound is the tray open/close motor trying to work
Posted on Jan 16, 2013
  • 2 more comments
  • Robin Roberson Jan 16, 2013
    There is no disc in there. It opened and closed one time but now it won't open at all.
  • Tom Chichester Jan 16, 2013
    The tray could be binding. Try poking the "door" to help open it it
    OK, will try that. Thanks for helping us!
    The receiver is also making a humming sounds that the volume changes up and down. Very strange.
Whats wrong with my stereo
How old is your HK receiver? The power supply capacitors can get old and tired, and cause the hum and shutoff. Repair is an option.
May 03, 2015 | Harmon Kardon Harman Kardon AVR1600 50W/CH...
Dvd door will not open or close when eject/open button is pushed. I can open door and slide tray out by hand, howevery when disc is inserted in tray and pushed back in, system does not read disc as being...
The low humming sound is the motor that opens and closes the drawer. It is moving, but the movement is not being transferred to the door by a pulley, a belt or a gear, When you open the drawer completely, it should stop. When the drawer is closed completely it continues to run until the disc is in the proper position to play. As long as that motor is running the DVD will not work because the disc is not in the proper position,
Feb 03, 2018 | Panasonic PV-D734S DVD Player/VCR
The Unit Has Started to Hum on Startup
Do you get audio from all channels(speakers)or are some not working? If some are working and some are not and the hum is only on some speakers and not on others then you most likely have a problem only in the audio amplifier section that supplies that speaker(s) if the hum is on all speakers and present with the volume all the way down it could be a power supply problem such as bad electrolytic capacitors.This may take some detective work to track down.
Feb 26, 2012 | Harman Kardon AVR 7200 Receiver
I have an Onkyo TX SR 700 receiver, Bose Acoustic Mass 10 speakers, Panasonic Viera 52" flat screen with my computer connected to the receiver. The computer uses a high end sound card. The flat screen...
Hi, what causes hums from speaker is when there is no ground shield from either the power supply or from the cable you plugged into the socket from the power supply.
So you will need to check that out and replace untrusted cables for connection..
If after doing this troubleshooting exercise, you will now need to test the speaker with another set to be sure the humming sound is not coming from there.
I guess that will Do.
Have a nice day...
Feb 18, 2011 | Bose Acoustimass 10 Series IV Home...
Think I have it all connected correctly, but there is no sound
Hello Sir, Hi try to check the usual, like mute? or is the cable good? check the menu if the unit is on mute. or use another cable. you can check the unit by simply listening to the speakers soft HUM. this HUM should be present, the hum is most loudest at full volume (even if there's no music). A missing hum means two things, you have the speakers not connected or open (burnt). or you have problems with the unit. please check them both. let me know your progress.
Jan 17, 2011 | Pioneer VSX-D309 Receiver
Speaker makes a rather loud humming noise.
You can go buy a audioquest SUB-X subwoofer cable with a additional ground wire on it an connect the ground cable to the ground slot of the receiver an the other end to a screw on the sub or into one of the high output terminals on the woofer if it has them an this will take that humming sound right away but the cable is around $90
Mar 28, 2010 | Velodyne HGS-10 Subwoofer
My home theater speakers make a constant hum whenever my receiver is on. The loudness of the hum changes with the volume control, and goes away entirely when the system is muted. All components are plugged...
jd40,
Sounds like a grounding issue. The first two places to look into is the powered subwoofer and antenna. During your last test, did you leave the FM antenna and subwoofer connected? Many times the hum is directly related to the antenna and/or the subwoofer and to how they are grounded; creating a ground loop through the receivers ground on the outlet. If the antenna is grounded to the dwellings wiring, hum is inevitable and sometime you can get a ground loop hum from how or how & where the subwoofer is grounded. Try taking them completely out of the loop.
Also try taking it further back to the basics, start with the receiver plugged into a known good grounded outlet with no surge or line conditioner in the loop and nothing connected to the receiver, nothing. Use one speaker and different wire to test each speaker output while in tuner and any other mode but phono. With no signal, you will either get nothing (no hum or static) or just static in the tuner mode. No hum is a good sign. Some systems will mute the speakers if no signal is connected to eliminate the static from being produced through the speakers but a ground loop hum will most likely still be produced even in mute. If you get a hum when nothing is connected to the receiver, try looking into getting a better grounded outlet, even maybe to a different dwelling.
-Chris
Jan 30, 2010 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
Dec 16, 2008 | KLH HTA-4906 System
Humming from speakers when CD player running
Yes, The humming is always there you just can hear it better when the cd is playing. The humming is caused by the electrical system in your car. There is an inline filter you can buy and insert it between the car's power source and the head unit. I had a head unit I bought that was absolutly terrible until I installed that filter. Also if you did a do it yourself job on your amp wiring it is usually best practice to run your RCA cables on the opposite side of the car as your power cable. You can also purchase shielded spark plug wires which is a source of noise usually of a different kind tho. First make sure you have a good ground. This means that you have grounded your amp to bare metal not painted metal. If that didn't work put in the inline filter on the head deck as they are only $20 available at radioshack. If that doesn't work, go back an wire your car right this time and put the power and RCA on opposite sides of the car. If you still have that hum it may be the spark plug wires but that sounds more like static than hum. You have a text book case of alternator hum... Hack
Jul 11, 2007 | Xtreme Sound WMS336 CD Player
Bose Av3-2-1 Series Ii Media Center Receiver Dvd Av 321 Av321 Works Perfect Logo
100 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
