Question about Stanley FactoryReconditioned Bostitch UCAP2060P 105 Amp 2 Horsepower 6 Gallon OilFree Pancake Compressor
I have a 6 gallon bostich air compressor and runs high pitched and doesnt buil pressure
May have gotten wet in hurricane sandy. It worked since but now is louder like its freewheeling
    Problem Solver:
  • 8 Answers
A blocked air filter will have this effect. Remove the air filter and try again If the compressor starts pumping air you have found your problem. If not the valves could be stuck open, shut or broken If there is oil or a lot of air being blown back out the oil filler hole the rings have worn or have been damaged. Either way if taking the filter off doesn't work someone has to pull the pump down and see the problem. I would check Bostichs site to see if there are parts available but if you have a tradesman you can trust get them to quote to fix.
Posted on Jan 17, 2013
3 Suggested Answers
compman66
  • 169 Answers
SOURCE: My Bostich CAP60P compressor will build pressure
sudden loss of capacity like that usually indicates broken or leaking valves in the head, or a blown gasket between inlet and discharge side of the head. if nothing is found there, then look at the piston and or cylinder bore for damage.
Posted on Jan 17, 2010
willinois
  • 77 Answers
SOURCE: My Bostich 6lb 2 HP oil free compressor was
The regulator on this model is prone to stripping and a kick would do it. Call the toll free number 800.556.6696 with your receipt and you should be able to get a replacement regulator.
Posted on Jan 11, 2011
Motor switch replacement Stanley model#swk-PAC 150h air compressor
For safety reasons work on mains voltage switches must be preformed by a qualified electrician.
Aug 02, 2015 | Stanley Air Tools & Compressors
How to change a regulator on a bostich pancake compressor
Usually they are just threaded into the unit, Empty the air, then remove it,
Oct 11, 2014 | Stanley Bostitch CAP2000P-OF 2 HP Peak 6...
Hitachi ec89 will not shut off
IF it is building up to the correct pressure then the pressure switch has malfunctioned. The part number for a new switch is 160580.
Parts and owners manuals are located at this link near the bottom of the page;
Hitachi EC89
Aug 19, 2012 | Hitachi EC89 4 Gallon Twin Stack Air...
I have a bostich cap2060p that stays at 80 psi. it wont build pressure past that but doesnt shut off either. there are no leaks that i can find in lines etc. and head gasket is good. could the pressure be...
My guess is the pressure switch is stuck. Unplug it take the cover off where you turn it on and tap around the contactors lightly with a screwdriver. Then plug it back in and try it.
Feb 03, 2011 | Stanley NEW Bostitch 2 HP 6 Gallon...
My Bostich 6lb 2 HP oil free compressor was running fine until it kicked while I was using it as it sometimes does and would not stop. It actualy made a high pitch noise and began to smoke for a second...
Oct 19, 2010 | Stanley FactoryReconditioned Bostitch...
Compressor pressure only to 60 lb psi and no more
not sure but it sounds like the piston ring is worn out or you might have a bad valve.
p.s. its not your typical valve like in a car.
is it a wet compressor, check the oil.
Feb 21, 2010 | Coleman Powermate 27 Gallon Air Compressor
Coleman powermate compressor doesnt hold air
CHECK YOUR TANK PRESSURE ADJUSTMENT KNOB ON TOP A LOT OF TIMES THERE NOT SET AT THE FACTORY.HOPE THIS HELP'S
May 22, 2009 | Coleman Powermate 11 Gallon Air Compressor
Stanley FactoryReconditioned Bostitch UCAP2060P 105 Amp 2 Horsepower 6 Gallon OilFree Pancake Compressor Logo
189 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Mike
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
