I have a new HP desktop with windows 8, and an older HP desktop with windows Vista. I used speedtest.com. Both computers pings and upload speeds are roughly the same. The download speeds are way off. The new Hp is averaging 3.8 Mbps, while the old is at 20 Mbps. Both computers are wirelessly connected to a Linksys 2.4 Ghz router. Both have strong signal strength. Both have netgear wireless. The new HP has the n300. The new HP has Norton antivirus, while the old one has no protection as of now. When I disabled the Norton antivirus on the new HP, the download speed did not change. Any suggestions what the problem may be?
SOURCE: One computer on network can't open internet pages
Have you change something in the web utility of WRT300N router. If not then I suggest take the wireless card out of you computer and reboot it. Try to configure your network connectivity through ethernet card, which is comparatively easy as to configure wireless network.
Run the disc that came your router and configure your network connectivity through its utility. Once you established network then you can try connecting wireless card back into your computer and take it from there.
SOURCE: Computer cannot access the internet
Try to disable wireless card on your desktop. With both the wireless and cat-5 socket enabled, "WITHOUT" the proper bridge settings, they will conflict and not be able to read.
SOURCE: Internet Explorer cannot display the web page
try to use the internet tools option and delete cookies, delete files and clear history then close the internet explorer and try to open it again. Good luck!!
SOURCE: My old linksys router has
try the following
1. check the linksys website for a possible update of the firmware..(get the specs on your router before updating the firmware.. if done wrong you may end up with a useless router)
2. also try to reset your linksys router to factory defaults..
SOURCE: I purchased a new EL 1850G EMachine. I have
Hello Linda!
It sounds like a firewall is blocking the connection. I assume you`re using Windows, so go to Control Panel > Windows Firewall and disable it.The next step is, if your not using a proxy. Open up your browser, if you`re using Firefox go Tools>Options > Advanced> Settings... (Connection) and make sure the 'No proxy' option is checked, restart your browser. For Chrome go to Options>Under the Hood>Change proxy settings (Network) a new window will come up from here you select LAN settings(Note: This will change the proxy settings for your whole system) and select automatic if it`s on manual. Finally disable your antivirus software just for a short amount of time, and try to browse the web, just to make sure that it`s not interfering with the connection.
