I have an admiral television/vcr combo model # JSJ12316. I also have the reomote for it. The remote will no longer change channels, turn tv off, or change the volume on it. When i push the button the lights flash but do not do anything. The tamper proof light is on and I do not know what to do to get it off. Can you please help me solve this problem.
techman
  • 3130 Answers
SOURCE: tv wont turn on
I looked this set up, and Unfortanatly there is no universal remote that will unlock the set and also theres no way to do it without the original remote. Sorry to be the one with bad news. Also the right remote is available at 1-800-remotes or http://www.remotes.com for about 52 bucks + shipping. Good Luck
Posted on Jul 04, 2006
  • 192 Answers
SOURCE: TV Picture Freezes and Turns Off; Cannot Use Remote
My shop had this problem yesterday. We had to change the DMD to correct it. One of the data lines was being drawn down intermitently. This doesn't eliminate the digital PCB, but, we have seen the DMD do this more than a digital. You should have an authorized shop do the repair. Contact Samsung at 1-800-SAMSUNG or contact by email: http://samsung.com/ContactUs/ContactUs.htm Hope this helps.
Posted on Apr 01, 2007
Slinteriors
  • 8617 Answers
SOURCE: 52 RCA DLP 1080P Television with NO picture and buttons flash
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
Posted on Jan 15, 2008
MikeMaierTV
  • 206 Answers
SOURCE: TV Snow and Static Sound
Sound like its all cabled wrong So its from the source, (wall satalight Whatever ) to VCR in then VCR out to TV, Now when the VCR fires up it tunes the RF output to Chanel 4 and has a strong signal, that over rides just about every thing. Simply way to stop this is one of two ways, press the TV/VCR button on the VCR, or simply turn off the VCR to let the signal pass through.
Posted on Mar 06, 2008
  • 319 Answers
SOURCE: tamper proof ????
call tech support
Posted on Mar 11, 2008
I own a older model citizen tv vcr combo. it is the box style and i cant watch any channels on it. the only channel it allows me to view is ch 2. i can watch a movie aswell. also if there is not a movie...
You need to autoprogram your channels with the Remote that came with the VCR combo. The Tape issue is common with many older TV VCR combo units. Put a tape in that is rewound and hit stop and then tune in your channels.
Jan 19, 2011 | Televison & Video
What is the universal remote control code for this TV
Hello
Three digit universal reomote code for Syphonic are:-
520 904 906 033/ 053/ 189
Four digit universal remote code for Symphonic are:-
0053 0189 0227 0456 0024
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
NB: Switch OFF and ON your TV with its front panel power switch [NOT BY THE REMOTE CONTROL HANDSET]; each time before trying and other code.
OK.
Dec 22, 2010 | Symphonic SC3813 13 in. TV/VCR Combo
Phillips 19 inch TV/VCR combo --no remote--can't change channels
I cannot be sure of the exact model but... Press and hold the TV's volume up and volume down buttons simultaneously. On many older televisions, this opens the device menu without the use of a remote. Otherwise, use the menu button, which you can navigate in a similar fashion.
Also, somewhere should be an input button. Press it multiple times times to switch between various inputs (the input must match whatever input you are using). Usually after these menus are opened you can use vol up vol down to change things.
Jul 13, 2017 | Philips CCC193AT 19 in. TV/VCR Combo
Zenith TVBR1352Z TV/VCR combo. I cannot get a code to allow my Philips/Direct TV remote to control the TV/VCR. All I really need it to do is control the volume
Turn on your TV (or other device). You will have to do this manually until you program your Philips remote control
Look for the "Setup" or "Code Search" button on the Philips remote control. Which button your remote has will depend on the exact Philips remote control you are using. This button may be a different color or may be labeled.
Hold either the "Setup" or "Code Search" button for about 10 seconds. If your remote has a light, the light should begin blinking. If there is no light, you can just count to 10 and then let go of the button.
Press the "TV" button on the remote to program the Philips remote to your television set
Find and press either the "Up" or "Down" channel button on the remote. Continue pressing either button until the television channel changes. This may take several minutes. Once the channel changes, press the "Power" button on the remote to turn off the TV. Your Philips remote will now be programmed to your television.
Jul 09, 2009 | Zenith TVBR2562Z 25 in. TV/VCR Combo
How can I turn to AV without a remote control (Samsung TV/VCR 19in Combo)
you might try going to channel 00
If you cannot just dial the number 00, go to channel 2 and then channel down.
Does not always work, but without the model number of the TV it is hard to advise further
Mar 12, 2009 | Televison & Video
RCA TV VCR/VCR combo
(1). Go to dollar store buy 4in1 remote control has all codes for all tvs cost $5.00 also you can enter menu on front of tv press menu button on front of tv when menu comes up use your channel up and channel down for up&down menu -- use vol- & vol+ to change settings
Jan 27, 2008 | RCA B27TF680 27 in. TV/VCR/DVD Combo
VCR plays tape with only sound and some channels seem deleted.
Needs the vcr heads cleaned, and get a universal remote with a menu button to change the tuner setup.
Jan 25, 2008 | Toshiba MV13P2 13 in. TV/VCR Combo
Admiral tv/vcr, innovage jumbo remote
YOU CAN USE EMERSON CODES FOR YOUR ADMIRAL TV AND TV / VCR COMBOS, MY COMCAST REMOTE ACCEPTED 11911. SOME REMOTES NEED FIVE NUMBERS AND MY ADMIRAL ONLY HAS THREE. SO I USED AN EMERSON CODE AND IT WORKED MOST OF THE BELLS, NOT ALL WHISTLES WORKED BUT I DIDN'T HAVE TO GET UP TO TURN IT ON, CHANGE THE CHANNEL OR THE VOLUME. MY KIDS WON'T DO IT ANY MORE!!
GOOD LUCK!!!!!
Dec 26, 2007 | Televison & Video
Remote control no longer works
an original remotes available for ya at http://www.remotes.com for 30 bucks + shipping
Apr 23, 2006 | Sylvania 6319CC 19 in. TV/VCR Combo
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Electro Med Services...
