Question about Epson PowerLite 3LCD Projector
Iris fault on epson h294b - Epson PowerLite 3LCD Projector
What is the problem if there is an error showing "auto iris error"? thank you
The iris motor can be faulty. you have get Authorized tech support for solving the problem.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Mar 06, 2016 | Epson EH-TW420 LCD Projector
3 red blinking lights, is it ballast or iris
check your fan and sensor before anything
Sep 15, 2015 | Epson Eb-460
What causes error in Auto Iris in Epson projector
Most times cleaning the gears on the auto iris motor will clear this issue. May need to be replaced.
Oct 22, 2014 | Epson EMP-S5 Projector
What solution do you have?
What did the Epson service provider say?
Oct 08, 2013 | Epson PowerLite 3LCD Projector
Auto iris error what can be done no display out
open the cover , unplug the flexible cables and other cable connectors, open the mainboard, remove the IRIS motor unit, clean the gear after that put in super lube into the gear.then plug it in again. if the same problem replace the IRIS motors.
be sure to change the lamp.
Good luck, thanks
Sep 08, 2013 | Epson VS200 Multimedia LCD Projector...
The two red lights are flashing on the top of the projector. i cleaned the filter and that did not help. it says in the user's guide it could also be the auto iris but i do not know how to get to the...
the auto iris or cinema filter is not changing position.
This could be due to a connector problem, build up of dust around these devices etc.
If you unplug the unit and take the cover off carefully, look around the lens area for any dust or obstacles that may be blocking the movement of these two items.
Also check the leads going to them to see if they are connected properly
Apr 02, 2011 | Epson 6500UB LCD Projector
Auto iris error
that means internal iris system is not working. Open the cover, be careful not to damage the flexible flat connector to the panel control, check iris motor and gear, maybe are dirty, clean all, and put little grease
Feb 07, 2011 | Epson PowerLite 3LCD Projector
My projector shows an auto iris error.I should power off and contact my nearest epson service provider
Check the troubleshooting page for the iris error in the owner's manual of the projector. I strongly believe you will still be refered to the service provider. Nevertheless, try troubleshooting and see how it goes.
Sep 11, 2009 | Office Equipment & Supplies
Epson PowerLite 3LCD Projector Logo
32 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
