Question about Hitachi CP-SX1350 Multimedia Projector
Darkness I am using two of these projectors simultaneously on two different sides of the room. I just changed the lamps in them. All the settings are the same yet one of them is noticeably darker.
  • 105 Answers
Some variation between units is normal, but if the dimness is extreme, check to make sure the new lamp is seated properly. A small difference in mounting position will make a big difference in brightness. Note that, if the old lamp exploded in the unit, the optics may require cleaning, in which case, take the unit to a service facility to have this done.
Posted on Jul 16, 2007
SOURCE:
How to reset projector hours for Infocus IN72 P720
Hello
To reset lamp hours:
Menu => Settings => Service
In this window; you can select Lamp reset.
Press Enter or OK.
Oct 04, 2011 | InFocus IN72 Multimedia Projector
Have an infocus litepro 580, lamp and speakers works fine. Projector will only show the "infocus systems" opening display without changing to my video source. All cables are correctly in,...
Go into the settings menu of the projector and turn off the auto source function, then select the input that you are using.
if using a laptop you may have to simultaneously press your FN and relevant 'F' key to send the signal out to the projector. The 'F' key usually has an image of two side by side monitors or it says LCD/CRT. Wait a few seconds each time for the signal to be sent to the projector. Sometimes you may have to repeat this action 3 times to get the image on both your laptop and your projector.
good luck
Mar 08, 2011 | Office Equipment & Supplies
I do not have remote. Church inherited projector.
Hello
Thank you for using
FixYa for your problem
  1. you need to enter factory Menu.
    You do so by doing the following:
    1).Start the projector.
    2).Press keypad <Source> and <Auto> keys simultaneously, enter " Lamp Hour info" layer
    3). Press <Source> and <Auto> keys simultaneously again, then enter factor menu.
    Do not change anything till you reach Lamp Layer where lamp hour and usage hour is given. If you reset, then all data revert to default - factory reset. you may chage here or under (2).
    Let me know if this solves your problem.
  2. - Press exit for 3 seconds
    - The Menu to reset the Hours rises up
    - Folow the manual on your screen
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 19, 2009 | NEC VT460 Multimedia Projector
Flashes change lamp after a couple of hours run
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Oct 02, 2009 | Sharp ANXR1LP Projector Lamp for XR1X,XR1
How to change sharp xv-120zu bulb
Jun 07, 2009 | Sharp (RLMPF0005CEZZ) Projector Lamp for...
How to reset the timer on a sharp BQCXVZ1001 when changing bulb
Jan 05, 2009 | Sharp BQCXVZ100001 Projector Lamp for...
4805 Lamp & Remote
This symptom can be caused by a few different conditions. Do you hear the fans running? If not then possibly the over temp protection switch has failed.
or the lamp cover is not securely in place.
If the fans are running (you can feel air flow) then either the lamp has failed prematurely or the lamp power supply (ballast) has failed or you have replaced the lamp and failed to reset the lamp timer and it has reached it's limit which can be reset by pressing both the volume up and volume down buttons on the the projector simultaneously for 10 seconds.
This will reset the lamp timer.
SagerTronics
Nov 29, 2008 | InFocus ScreenPlay 4805 Multimedia...
Resetting lamp timer
Try the following:
ry this:
Jun 09, 2008 | LG RD-JT30 Multimedia Projector
Tech support for Sharp PG-B10S
Reset The Lamp Timer.
While simultaneously holding down (+ . >) and AUTO SYNC on the projector, Press ( I ) ON and ( - . < ) on the projector.
NOTE..... Make sure only to reset the lamp timer only when replacing the lamp. If you reset the lamp timer and continue to use the same lamp, this may cause the lamp tp become damaged or explode...
Sinista
Apr 15, 2008 | Sharp Notevision PG-B10S Multimedia...
Overheating
Set the lamp to economy mode, make sure it is being used in a cool room with easy air flow thru the projector. If the problem persists, there are two fans inside and a thermistor that takes the temp reading, there is small adjustment POT on the board to increase the operating temp if needed.
Dec 19, 2007 | Toshiba TDP-S20U Multimedia Projector
100 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Steve Allison
Steve Allison
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
