Question about Sony PCV-RS620G PC Desktop
I have a V2Premier computer (Tower) the power button fell
The power button fell off and is down in side the case. Can I take the casing off and replace the button? It is in the on position.
  • 1 more comment
  • fsalt2 Jan 24, 2009
    Thank you. I will try, just take off the case and try to put it back on?
    Thank you so much, I will go to the website.
  • bbfidler
    bbfidler Feb 22, 2013
    Just pry off the front of case and replace and let me know where you got the replacement
    President:
  • 2,692 Answers
Sure. You can even replace it with any momentary switch (Normally Off position switch) from radio shack or like places.
Posted on Jan 24, 2009
Power button switch
Send a request to the following email address. Mention the exact model number like you did in your question and request a replacement front panel on/off switch. rma@raidmax.com
Nov 19, 2013 | RaidMax AURA ATX-927WB Black SECC Steel...
Tip
How to repair Computer Fan
<p>1. Remove the mini-tower computer cord and unplug the power. Disconnect the cable from the back of the computer for a note in which they were set to be fast to restore.<br /> <p><br /> <p>2. Unplug the connector on the back of the computer. Tighten the screws on the back of the computer, back up the side with a screwdriver. Slide the computer case and put it out of your way.<br /> <p><br /> <p>3. Locate the fan in the box near the back and then connect the power cord where it is on the motherboard. Unplug the fan motherboard manual. Remove the four screws holding the fan on the bottom of the box with a screwdriver to secure.<br /> <p><br /> <p>4. Remove the PC case fan and set aside. Turn the fan of the new mini-tower in the back of the cabinet with screws and plugs wire connector on the motherboard.<br /> <p><br /> <p>5. Place the rear plate side of the computer and secure it with screws. Connect the power cord to power on the back of the case and connect the cable to the computer case.<br /> <p><br /> <p>6. Connect the power cable from the mini-tower outlet and turn on the computer.<br />
on Jun 21, 2011 | Computers & Internet
Tip
How to take apart a tower computer
<ol> <li> <p>Unplug everything. Unplug all of the wires, computer cables and power plugs from the outside of the tower. After this, it's a good idea to pick up the tower and put it on a clean flat workspace, on its side.Open the case. Discharge any static electricity. If you are worried you may have a lot of static electricity, you can use an ESD strap to discharge it. Remove the sides of the tower by unscrewing the screws in the back of the case that hold them on. This is usually two screws on either side, but may be more. On the side where the computer parts are removed, the side may be screwed in with thumbscrews. Lay the computer down so that all of the components are exposed.Remove the cards. The cards usually consist of, the sound card, video card, network card and maybe a few others. Some of these devices are now integrated on the motherboard, so you may have few or no cards at all. You can remove the cards by unscrewing them from the back of the computer. They usually only have one Phillips screw holding them in. Remove the card by pulling it slowly and carefully; you will have to apply some force though.Take out the drives. The drives are in bays in the front of the tower and are screwed into the framework of the tower or in removable bays. You will need to unscrew several screws from this side of the tower and you will need to flip the computer over and unscrew the drives from the other side as well. Unplug all of the power cables and computer connections from the back of the drives. Pull the hard drives out of the back work area. Floppy and optical drives can now be pushed out the front. Some computer cases, such as certain Dells, have a system for the optical drives to come right out by pushing in releases on the sides of the drive and no unscrewing is required.Disconnect the brains of the computer. Remove the memory by unlocking the white end clips and pulling up on the memory carefully and unsnapping it from the connection. Remove the CPU fan by unsnapping it from its connection to the motherboard. Unlock the CPU holder by unlatching the small metal clip. Lift up and remove the CPU.Remove the power supply. Never open the inside of the power supply, as it may cause severe injury. Simply unplug the power supply from the motherboard. This is usually connected by a long white rectangle and requires a clip to be pinched to let it loose. Make sure the power supply is not connected to anything else inside. All that's left is to unscrew four screws on the back of the case that hold the power supply in place. Lift out the power supply.Detach the motherboard. The motherboard should be screwed in with between 6 and 9 screws, simply unscrew them and lift the motherboard out at a good angle so that it fits out the side of the computer. The motherboard may have to be pulled out of the back of the case with some pressure, where the connections for the computer cables are. You should now have an empty tower.<br /></li></ol>
on Dec 05, 2010 | Computers & Internet
Remove outer casing from desktop PC
Usually just two screws or thumb screws on the back edge. Then lay the tower on the big side. Push down into the case and back and it should slide out. This is most cases. Some will have latches or buttons.
Jan 27, 2013 | Viscom V2 Premier 17'' LCD Computer...
Open emachines el1352g-41w
Open the eMachines EL1352G-41W computer case?
Unplug the computer from power. Unplug all cables. Turn the computer tower around so the back faces you.
Look at the Left side. This Side Panel removes.
There is a handle for your fingers, formed out of the Side Panel's sheet metal.
Above the handle along the edge, and towards the Top, there is a Philips head screw. Loosen this screw. (It isn't supposed to come all the way out)
Down below the handle, and towards the bottom, is another Philips head screw. Loosen this screw.
Use the handle in the Side Panel, to pull back on it. Pull towards the back of the computer tower.
The Side Panel may only pull back so far. There may be tabs which stick out of the Side Panel, and go into slots in the computer tower's case.
For this style the Side Panel will only pull back approximately 1 inch, or so.
Then the Side Panel is brought straight out away from the computer tower, and laid aside.
[ NOTE*
Do NOT forget to observe Anti-Static Precautions BEFORE reaching inside your computer, and working on it.
Computer on a table, computer unplugged from power, computer case open.
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
Should you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
For additional questions please post in a Comment.
Regards,
joecoolvette
Dec 02, 2011 | E-Machines eMachines Desktop PC
Unable to remove cover from dell dimension 8400 desktop pc
This Dell Support, and the Service Manual for the Dimension 8400,
http://support.dell.com/support/edocs/systems/dim8400/SM/index.htm
In the Service Manual main menu, left-click on - Opening the Computer Cover
1) Computer off, and unplugged from power. (Always unplug the power cable from the surge protector. Then if the power cable needs to be removed from the computer, do so)
2) Remove all cables to the computer
3) Lay the computer on it's Right side.
(As you face the computer, your right side is the computers Right)
4) There is a Release button on the Top of the computer case, and a Release Button on the Bottom of the computer case.
These are located at the Rear of the computer.
The preferred method of opening the computer case, is to press one release button in at a time, and slightly lift up on the side of the computer case, where that release button is located near.
Then go to the other side of the computer case, press this release button in, and lift up on the computer case.
The computer case opens like a clamshell. The computer case is hinged at the front.
Example:
Computer laying on it's right side. Press the Top release button in, and lift up on the computer cover located near the Top.
Now press the release button on the Bottom. Lift the computer case up.
The computer case opens from the back, towards the front, like opening a car hood.
Feb 18, 2010 | Dell Dimension 8400 PC Desktop
Problem with connecting power button to MB.
jsut remove and re-insert the all cable
www.compudesk.in
Sep 14, 2009 | Chenbro Xpider PC61166 Mid-Tower...
What is Mini Tower ATX Cabinet
A mini tower is a PC desktop case which is approx half the height of a full size desktop tower case. ATX probably refers to a ATX switch mode power supply.
Sep 10, 2009 | ASUS TM-220 (generic) Micro ATX Mini Tower...
Gateway Model 0019401806 Tower - Power button fell into case
there are tabs inside the case that you depress to pull the front cover off. once pulled off you should be able to replace the switch.
hope this helped
please rate well.
Mar 06, 2009 | Sony PCV-RS620G PC Desktop
Power button fell off
open the case and rejoin the power button.
Jan 24, 2009 | Sony PCV-RS620G PC Desktop
Sony PCV-RS620G PC Desktop Logo
572 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
