Question about Microwave Ovens
KitchenAid KHMS2050SSS 1200 Watts Microwave Oven stopped heating
  • 3,051 Answers
Hello there and welcome to fixya
there are a few things than may have happned i will post the most common ones first ok If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
Next ks the thermal fuze
If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
and finley
If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually a faulty door switch or within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Posted on Jan 16, 2013
scottowa
  • 87 Answers
SOURCE: Whirlpool MH1150XMQ 1000 Watts Microwave--NO HEAT
About 95% of the time it is the magnatron. If the microwave is under 5 years old that part is often covered under warranty. I would check your manual. If not the p/n is 8206335 and it's about $80 and fairly easy to install. I just looked and the magnatron is covered.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0523111.pdf
Labor to replace it would be about $125
Posted on Mar 04, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: The number display on my Sharp R-515EK 1200 watts microwave oven
We regularly repair these control / display units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on Aug 31, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: GE JES1358 1200 Watts Microwave oven that does not heat
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At
our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
Here are some links you or someone you know can use (in order given) for high voltage section test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted or burned looking, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even though mag is bad!)
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Accessing some parts may require you to pull the oven from the wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have
two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If it's within the magnetron portion of the warranty G.E. will send you the magnetron to do it yourself. Call them at 888-239-6832.
Be persistent. You may have to speak with a supervisor.
Posted on Nov 29, 2009
heatman101
  • 43501 Answers
SOURCE: Amana ACM2160A 1100 Watts Microwave oven doesn't heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
56ik
Posted on Sep 30, 2010
heatman101
  • 43501 Answers
SOURCE: Thermal fuse needs replacing.
heatman101
hjkj
How-To Replace The Door Handle On A Kitchenaid Microwave Hood
behind door their is trim round the door use flat knife go between the trim will pop out and open 2 sc
Feb 01, 2015 | KitchenAid KHMS2050SSS Microwave Oven
How do you replace the fuse for model KHMS2050SSS KitchenAid microwave?
my microwave did not have a fuse. are you sure it is not a switch?
Oct 10, 2014 | KitchenAid KHMS2050SSS Microwave Oven
MY EMERSON MW1119B STOPPED HEATING
Sounds like it's broken. Go for Panasonic next time, they make better microwaves. Here's one I was looking at http://bestmicrowavereview.com/panasonic-nn-sn651b-genius-1-2-cuft-1200-watt-sensor-microwave-review/
Jan 04, 2013 | Emerson MW8102SS 1100 Watts Microwave Oven
KitchenAid Architect II KHHC2090S Stainless Steel 1200 Watts Convection / Microwave Oven. Microwave quit heating. Inverter and magnetron replaced by the repairman. Still no heat but the magnetron gets...
Perhaps the "repairman" should take another look at it. A lot of microwave ovens have an aerial that directs the energy out to the load or food to be heated.
Maybe...maybe not but worth a look behind the waveguide cover I would say.
Mar 24, 2011 | KitchenAid Architect II KHHC2090S ...
Microwave starts and stops in 2 second intervals
The microwave sounds like it has keypad control problem, behind the pad is the micro-controller board which controls vital areas of the oven, it needs to be checked out.
Feb 04, 2011 | KitchenAid KHMS2050SSS Microwave Oven
Microwave panel and lights work but the fans do not and nothing is heating
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 29, 2011 | KitchenAid KHMS2050SSS Microwave Oven
IT HAS STOPPED HEATING. WHAT CAN I REPLACE TO FIX THE PROBLEM
Basic
heatman101
Jan 24, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
My unit turns on by itself and recently it stopped heating up anything you put in
heatman101
Aug 31, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
heatman101
hjkj
Apr 18, 2009 | Daewoo KOR-630A Microwave Oven
Microwave Ovens Logo
95 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
