Question about HP Refurbished MOTHERBOARD (SYSTEM BOARD) - BERMUDA-ULA - OEM WORLDWIDE HP (51853387)
Motherboard my power sw./led 5064-0346 is unplugged from the motherboard and don't know where it goes. HP XE783
  • ibarra26 Jan 24, 2009
    Hp Pavilion XE783 Model P1372A
  • Thomas F. Schneider May 11, 2010
    Give me the make and model or the HP computer and I may be able to find it.
    President:
  • 2,692 Answers
Try adding and removing hardware from the HP website:
Or look up the mother board on ther ASUS  website: ASUS CUW-AM
HP/Compaq name: Amberine-GL6E
http://support.asus.com/download/download.aspx?SLanguage=en-us
http://h10025.www1.hp.com/ewfrf/wc/product?product=81921&lc=en&cc=us&dlc=en&submit.y=3&submit.x=4〈=en&cc=us
Posted on Jan 24, 2009
Problem with the MSI 7050 v2.0 (HP dx5150) Motherboard Front panel wiring colour diagram please.... PWR LED, HDD LED, PWR SW, AND RST SW
You should read manual of the moterboard, there is wiring diagram that you need. But however, i suggest to you - take it to the expert, if you don't know how to do it.
May 20, 2011 | Intel Motherboard
I have asrock agp8x p4i65g and don`t know how connect fron power/reset buttons and fron lights. There`re 5 lines power sw, reset sw, H.D.D. led and 2 ampty
yea there are 5 lines one is power switch other is reset the power led then hdd led then in older motherboard there is provision for speaker The power switch is in the front pannel of the motherboard if you have multitester the power which will indicate 5v the power switch is to be conected to the 5v and the ground normally the front pannels details will be given in the motherboard
Mar 28, 2011 | Computers & Internet
CASE WIRES TO PANEL1 CONNECTIONS
The hdd red wire gooes to pin #1 the hdd white wire goes to pin #3 the power sw orange wire goes to pin #6 the power sw white wire goes to pin #8 The reset sw blue wire goes to pin #7 the reset sw white wire goes to pin #5 the power led green wire goes to pin #2 the power led white wire goes to pin #4.
Now the layout of the pins is the long row (5) pins are the odd number pins 9 being the odd one and 1 is the other end of the row. 2 through 8 start at the pin accross from 1 : : : : . I hope this helps you.
Aug 22, 2009 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
I don´t have the foxconn motherboard manual "661m08"
Most mobo's have the connection points printed on them. Use a strong flashlight and look for some pins that have the following words printed near them (PW or PWR, RS or RST, HDD LED, etc) They should all be grouped together in the same corner of the mobo. Have you tried googling the motherboad name to find a manual? I have done that on a few occasions and got lucky.
Apr 30, 2009 | Intel Motherboard
Configuration
Hi
The wires that read +5 -d +d and ground those are USB connectors each usb connector will have 4 wires, +5 -d +d and ground so that goes to usb pins.
The sw must be power switch
The HDD led is the load light
Reset is the reset button
Power led is the front power light
SPK is the speaker / beeper.
Can you tell me the brand and model of the motherboard? They are documented in the user manual. but generally in the bottom right corner of the motherboard you have the connectors for the leds and buttons, its all written into the motherboard with small white text. but I can get clear instructions from the user manual for you.
You can look for the motherboard details between the expansion slots and between the cpu and memory.
Thanks,
Ekse
Feb 03, 2009 | Intel SVM266A VIAP4M266A (SYNTAX SVM266A...
Computer won't power down completely
here's one solution: u may have a faulty on/off switch which u use to switch the p.c. on, open the case & trace the wiring from the on/off switch to the motherboard. to test do the following: unplug the cable from the motherboard & shut down the p.c. i hope this works for u
Sep 03, 2008 | HP Pavilion xe745 (P1508A#ABA) PC Desktop
How to connect power led ,HDD,Reset,power SW cables in hp motherboard s/n 383620-001
check your motherboard manual if you do not have it go to www.support.hp.com and look for manuals based on the model. this should give you detailed instructions as to which pins you plug those cables into. usually they are located towards the bottom of the motherboard to the right of your PCI Expansion slots
Aug 20, 2008 | HP Computers & Internet
HP Refurbished MOTHERBOARD (SYSTEM BOARD) - BERMUDA-ULA - OEM WORLDWIDE HP (51853387) Logo
296 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
