Question about Lands Phones
No instructions I can't locate the instructions that came with the iretrofone Bluetooth wireless charging base. There for can't set it up. There doesn't seem to be any support for it either on the box I.e. manufacturer, phone, or web address. I'd really like to use it but have no idea how to get it going. Can someone please help.
CORDLESSGURU
  • 106 Answers
SOURCE: Registering a base station of Siemens Gigaset 2415 Cordless Phone
To register your handset to that base station, you must put the base station in registration mode at the same time you put the handset in registration mode. This is how you do it. At the handset you push OK when it asks you to register. If it asks you for the pin enter 0000 (factory pin) and push OK. The handset should say "registering base 1". Then at the base press the page/reg key down until it flashes (its to the immediate right of the cradle where you rest the handset for charging). That puts the base in registration mode and now its looking for the handset and vise versa. Now watch your handsets display. If it asks to to select an intercom number, then push ok and your done. If it says "invalid pin" then you need to reset your pin on your base (thats a different problem see below). If the handset times out and never registers, you need to repeat the process a couple times, you may have a bad base or it needs to be defaulted. If you need more help you can download a manual for free or get free technical help at the link below.
http://www.barclayent.com/manuals/Gigaset%202415%20User%20Guide.pdf
If you need to default your pin, you can do so but it will default the base station to factory settings. To do so remove the power from your base, hold your page/registration key down, and apply power back to the base. Count to 15, then let off the key. Turn off the power, count to five, then apply power again and follow the steps again to register the handset and you will need to reregister every handset that was previously running on it.
Posted on Feb 10, 2008
SOURCE: help! I've no idea!
fold the boom up, push and hold down the central button until it turns violet, open the boom and then let up on the button. The central button should stay violet without blinking. Then go through the pairing routine on your phone.
Posted on Mar 04, 2007
  • 274 Answers
SOURCE: wired base unit
Try a simple thing, replace the phone cord that goes from the wall to the phone with a new one. That'll make sure you still have a good phone connection. Cords cheap.
You have a power transformer that plugs into the wall.  See if you can find a replacement at a surplus store or Radio Shack (a different store)  Take the old one with you so you can match the voltage/ampere and connector.  If its new it will work fine.  If its surplus, it's hit or miss.
If that does not work  or you don't want to bother buy as new phone.  With the constant upgrades you might find one with better features you'll like more.  Who knows.
Good luck
Posted on Oct 25, 2007
stephenc21
  • 8 Answers
SOURCE: Pama Sigma Sun Visor 2300 Bluetooth password/code
hi the factory password on the sigma pama is 1234 if you enter this on the phone once you find the sigma via bluetooth search it asks to enter the code to connect to the sigma most other devices ie bluetooth headset the code is 0000 hope this helps, regards smc
Posted on Jan 17, 2009
Zagg keyboard doesnt work
Mine went dead after about 3 weeks. Once I realized there was a charging port which is not IPhone, but droid type. Began charging. Would not recognize until I went to blue tooth setting and said forget device. Then turn bluetooth on and then hold bluetooth key down on for 3 seconds or so on keyboard. Then it worked. I guess dont let it run till it dies.
Apr 16, 2013 | ZAGG New Apple Ipad 2/ Brand New Ipad...
My hed set not sapprt
Headphones are a convenient way to experience audio-rich entertainment on your own terms. Headphones allow you to customize your listening level without disturbing other people in your general vicinity. Headphone cables can be a hassle, however, so many new headphone models feature a wireless connection. PCs tend to be wire jungles, so eliminating one wire from a potentially jumbled mess can be an intriguing feature of wireless headphones. Connecting wireless headphones to your PC allows you to take advantage of the benefits of listening to your movies, music or games through headphones without the struggle of the headphone cable.
Charge up or place batteries in your headphones and transmitter. Wireless headphones require power to function. Many wireless headphones come with a charger base. You need to charge your headphones before you attempt to connect them to your PC. Some wireless headphone models require batteries, which you must install before you connect the headphones to the PC. Connect the transmitter to your PC. The transmitter may connect via the PC's headphone jack or USB port. If the transmitter connects to the headphone jack, plug it in and check your headphone's user guide to verify how to synchronize the headphones to the transmitter. If the transmitter connects via USB, you will likely need to install software to use your wireless headphones. If your wireless headphones are Bluetooth-compatible, continue to the next step. Pair your headphones via Bluetooth to your PC. If your PC is not Bluetooth-equipped, you will need to install a Bluetooth USB dongle. Turn on your headphones and open the Bluetooth software on your PC. Scan for Bluetooth devices from your PC. Your headphones should appear. Select the headphones and follow any further instructions to complete the pairing process. Test the headphones. Pick out a song or a video and play it on your PC. Connect your wireless headphones and verify that you can hear the audio. Find the volume controls on your headphones and adjust them to make sure the volume changes correctly. If your headphones are not functioning properly, verify that the headphones are turned on. If the headphones are on and you do not hear anything, verify that your transmitter is functioning properly and that you have your volume turned up on your PC. Recharge your headphones when you are finished using them. To ensure that the headphones are ready anytime you need them, you must always place them on the charging base when you are finished using them. If the headphones are battery-powered, be sure that you always have spare batteries on hand. Hope this helps.
Dec 20, 2012 | Computers & Internet
Bluetooth interference
Unfortunately, Bluetooth and 802.11b/g are always going to interfere with each other, but you can try a few things to help minimize it:
1. Set your WAP11 to run on channel 11, or 1. Bluetooth hops from channel to channel rapidly, setting your WiFI to 11 or 1 (the 'edges') leaves the most open space for it to hop around in.
2. If your bluetooth devices/adapters have some sort of '802.11b coexistence' option in their advanced settings, turn it on, but only a few things will have this option.
3. I know this isn't the software-based solution you wanted, but seriously, if you can move the WAP11 about 2-3 meters away from any bluetooth stuff, this will solve most if not all your issues.
Oct 17, 2012 | Linksys Instant 802.11b Wireless Network...
I can't hear the other people on my plantronics cs 70 which is connected with my cisco ip phone 7941 phone
• Check that all cords and jacks are connected correctly.
• Check that the base has power (red indicator light) and the headset battery is fully charged.
• Try other phone configuration dial settings on the base unit. Ensure the selected number is in line with the position indicator.
• Ensure you are in headset mode. Press the call control button to select correct mode. The talk indicator light on the base is green.
Good luck from Headsets Direct!
Sep 09, 2011 | Plantronics Explorer 220 Bluetooth Headset...
MPlantronics Backbeat 903 Bluetooth Wireless Stereo Headphones Headset red light flashing problems
The red flashing indicates a low (or check) battery. The instructions on page 4 in the link below for the Plantronics Backbeat 903/906 will show you how to charge it up. On page 8 you'll see how to power down and then up the headset to reset it.
Plantronics Backbeat 903/906 User's Guide
Aug 02, 2011 | Plantronics Backbeat 903 Bluetooth...
Just recieved my plantronics 903 backbeat headset plugged it in to charge and just blinks red llight left charged for 5hrs and when unplugged wont come on
Try resetting the headset and see if that helps. Here is the users guide, the reset instructions are on page 10.
Below is the link for the Backbeat User's Guide for more information.
Plantronics Backbeat User's Guide
May 14, 2011 | Plantronics Backbeat 903 Bluetooth...
After working for 2 days it will not allow us to connect to the internet then after i unplug the power then hook back up it works
In order to set wireless printer in Windows 7-based PC, you need to position it in a central location away from metal objects. Now, find out if it a Bluetooth or Wi-Fi as most new printers are equipped with either Bluetooth or Wi-Fi technologies. After, that enables the sharing of your printers by informing computer’s operating system about adding printer to its network. Also, install drivers for the same. Hence, in this way you can set up wireless printer on Windows 7-based system. You can also set up other computer systems in the network for using wireless printer get more information for Set Up Wireless Printer on Windows 7 .
Sep 06, 2010 | Linksys Wireless-G Broadband Router
How to activate bluetooth on dell vostro 1700
turn on the bluetooth using the wireless switch located on the left part of the computer. make sure it is on the 1 position not on 0
Feb 19, 2010 | Dell Vostro 1700 Notebook
Programming bluetooth wireless head set model PBH-8W
If you need a copy of the instruction page, I can send you a pdf. ss061092@yahoo.com
Pairing your headset and cellular telephone:
1. Ensure that the headset is off.
2. Press and hold the multifunction button until the indicator light
turns on in blue (approx.8 seconds).
3. Set your Bluetooth-Compatible Phone to discover the headset by
following your phone's guide.
4. Typically, the steps involve going to a "setup"connect" or
"Bluetooth" menu option on your phone.
5. Select the option to locate, find or discover Bluetooth devices.
6. Press and hold the multifunction button on the Wireless Headset
until your cellular phone locates the device.
7.Your phone will find "-PBH-8W" and ask if you want to pair with it.
Confirm by pressing Yes or OK.
8.Your phone may ask for the password to the headset. Enter
"0000" (four zeros) for the code or passkey
9.Your wireless device will operate up to 30 feet from the wireless
telephone.
TECHNICAL ASSISTANCE:
Contact GNBI: GnbiTech@aol.com
Telephone
# 1-800-541-GNBI (4624)
Reference # PBH-8W
Sep 13, 2008 | Cell Phones
Lands Phones Logo
124 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
