Question about Hitachi 65S700 65" Rear Projection HDTV
When turned on the TV flickers screen goes black then comes back in 15min and is fine? Anyone?
Anyone??
    Novelist:
    Champion:
  • 203 Answers
Okay, I'll try. First, unplug the set for 2 minutes and retry. If you have on-screen-display when this happens, try another input and a different set of patch cables to eliminate any simple problems. Then remove rear cover and peek through to see if tubes are lighting and listen for current to the tubes. There are usually small green and red lamps on the board which will flash upon failure in the set. These are there to direct us to the failed circuit. That should get you started. Good luck, Russmann.
Posted on Jun 13, 2008
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Sony 52xbr4 screen flickering
Fault with the main power supply regulator board. Ubnormal DC voltage output from it. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and precious time.
Aug 29, 2014 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Mitsubishi tv flickering
the problem you are having is the colour wheel. it spins to correct the colour on the screen when it fails you get wrong colours and flicker... the motor on it fails after time. and will need replacing.
Mar 05, 2014 | Televison & Video
I have a RCA L32HD31YX12 TV. The TV works fine for a half hour and then the screen flickers and goes black. The sound continues. If I turn the set off for a half hour, it works again for another half
You have answered your own question, someone needs to open it and find a loose plug or broken solder connection--if it reacts to being tapped on that is the issue- a physical problem inside.
Dec 05, 2012 | RCA Televison & Video
My tv screen keeps flickering on and off
  1. Need Model # of set and the brand so I know if its a plasma, LCD, or CRT set keep me posted
Aug 23, 2009 | Televison & Video
Screen is fine when I first turn on TV, then goes black
Sounds like you dlp lamp is going out. That's a pretty old TV and if you are still running on the stock lamp this is exactly the type of thing that will happen. The lamp model for this particular tv is the ty-la1001. You can find that over here:
http://dlplamps.com/products/panasonic-dlp-lamp/panasonic-ty-la1001.html
Mar 21, 2009 | Panasonic PT-52LCX66 Projection Television
Screen goes crazy after about 1 minute
try it on tuner mode to seperate the fault from video to rf input,if gone the video pc board is at fault.
Aug 11, 2008 | Samsung HLN467W 46" Rear Projection HDTV
The TV flickers screen goes black then comes back in 15min and is fine? Anyone?
check for loose plugs or bad solder joints on the main circut board.
Espescially on the vertical output I.C.
Thanks guy9
Jul 10, 2007 | Hitachi 65S700 65" Rear Projection HDTV
Flickering of screen (comes and goes) and weird DVD/reception problems
Depending on how old this set is, there might be a bad Hyper board bad. good Luck
Jun 29, 2007 | Toshiba 43H70 43" Rear Projection...
Hitachi 65S700 65" Rear Projection HDTV Logo
81 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
