Question about Ricoh Aficio Mp C2500 Copier
Ricoh C2500 service code SC 561 - Ricoh Aficio Mp C2500 Copier
5 Suggested Answers
Bubbabear64
  • 2794 Answers
SOURCE: RICOH 2015 error code sc 500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
It can be a lot of troubleshooting to do.
Posted on Oct 19, 2008
  • 1294 Answers
SOURCE: ricoh 1045 error code sc 672, 961
Controller to operation panel comucation error at start up.Check the controller stall,controller board installed correctly operation panel connectors.Enter im the service menu ,press the SP mode,open the front door,turn off the copier,unplugged the machine.Wait 10 seconds,plugged on the machine,close the front door,turn ON the copier and make a copy.
Posted on Dec 28, 2009
  • 161 Answers
SOURCE: Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Posted on Jan 16, 2010
SOURCE: ricoh C2500 error code SC397
ricoh 2030 error 397
Posted on Sep 08, 2012
WHAT IS ERROR SC 397?
the colour drum drive is overloaded.... probably one of the drum units has siezed
Dec 01, 2014 | Ricoh Mp C2500
What is sc 532 on aficio mp c2500 and what if the machine shows your that your fuser settings error
"Fusing duplex motor locked" check the fusing duplex gear box or clean if not so you can change duplex motor.
Sep 01, 2014 | Ricoh Aficio Mp C2500 Color Laser -...
How to FIx Code SC 561
Defective thermopile. If replacing the fuser does not help it will need to be replaced.
Aug 10, 2014 | Ricoh Aficio Office Equipment & Supplies
Code sc 101 mp c2500
Optics problem check to see if mirrors are dirty. Will need to clean mirrors be carefully you can cause mirrors to fall out or become miss align . Buy a can of air blow them off . Turn off copier before you start then turn on and copier will move optics back into position.
Jan 15, 2014 | Ricoh Aficio Mp C2500 Copier
Ricoh MP C2500 Error Code SC 561 what is this?
sc561 on an MP C2500 is a thermopile error. The thermopile may need to be replaced, but first make sure it is connected properly and hasn't been moved or loosened.
You'll need to go into service mode and execute SP 5810 in order to clear the sc561 code.
Jul 02, 2010 | Audio Players & Recorders
Ricoh Service Code error - Service Code SC-300
I am a Ricoh tech and my service manual doesent have a 300 code,
Jun 09, 2009 | Ricoh Aficio AP3800C Laser Printer
Service code 561 error
Hello sir; Just follow my direction, it will reset your machine;
1, press "clear mode", "107", then press and hold down "clear/stop" key.
2, touch "copier SP" on the screen.
3, enter "5810-001" press enter.
4, set value to 0, then turn power off and back on again.
May 15, 2009 | Lanier Office Equipment & Supplies
Service code SC 548 on a Ricoh Aficio SPC 811dn printer, what is it and how to correct?
I have sc 548 error code also. I was following your instruction, but i couldn't enter to service mode. How do i prepare it? Please write this instruction to me step by step.
Apr 23, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Service Call SC 553 on Ricoh Aficio SP C811DN Printer.
No.
Type
Details (Symptom, Possible Cause, Troubleshooting Procedures)
553
A
Heating roller overheat (software error)
The detected heating roller temperature stays at 230°C or more for 1 second.
• Defective PSU
• Defective lOB
• Defective EGB
Related SC code: SC 543
1. Replace the PSU.
2. Replace the lOB.
3. Replace the EGB.
This is the simptoms of the service manual , you should check that your power output is stable and double check if there is not anything like paper stuck some were in the fuzing unit wich could also cause the fuzer to over heat
Nov 11, 2007 | Ricoh Aficio SP C811DN-DL Printer
Ricoh Aficio Mp C2500 Copier Logo
190 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
