Question about Dell Dimension E510 Dual Core 2.8 Ghz (847403171179) PC Desktop
Bios problem on dell dimension e510
I turn on the computer and it will not boot up and show on screen Phoenix Ram Bios version 1.10 A02
dell DM051 series Bio version A02
in compatible processer.
How can I reset the machine. curser flashes but wont let me enter anything.
  • 1 more comment
  • james_wardle Jan 24, 2009
    how would you remove the bios
  • cav_guytech
    cav_guytech Apr 01, 2012
    were you able to fix this problem?
  • Anonymous Mar 14, 2014
    dell gx620 starts up fan kicks in but wont boot up. cant enter bios
  • 112 Answers
At first u need to remove the bios. wait for 5 minutes. then add the battery. start it
Posted on Jan 24, 2009
  • ehsan amin
    ehsan amin Jan 25, 2009
    i mean remove the bios battary. wait for 5 minute and add the battery.
How do I run a set up program
Generally, one enters the BIOS Setup screen by pressing either F2 or Del. There is usually a message on the bottom of the first boot screen that indicates what button is correct for that model.
Looking further into the details that you have given, it seems that your CMOS battery has died, so you will need to replace that. (This is what is causing the "Time of Day Not Set" message most likely.) You can get the appropriate battery at Radio Shack (if nowhere else) for about $5 or $6.
Oct 17, 2014 | Dell Dimension 3000 PC Desktop
HOW TO DETECT THE CD ROM USING PHOENIX ROM BIOS PLUS VERSION 1.10 A02
The BIOS information is typically found at or near the top of the POST screen for a very short time ALR PC non / PCI = CTRL+ALT+ESC AMD advanced micro devices=BIOS = DEL Award BIOS = DEL Dtk Datatech Enterprises Co. BIOS = ESC Phoenix BIOS = CTRL+ALT+S Phoenix BIOS = CTRL+ALT+INS Restart your computer during the boot process you will see on the screen to press a certain key usually Delete or F2 to enter setup
this will differ depending on which bios you have Press and hold that key during the boot up process to enter BIOS Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system (note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults) after windows has loaded your computer will automatically restart it might restart 2 times one to finish the installation the next will be because the operating system is loaded and will boot from your cd during the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart otherwise it will keep booting from the cd /dvd drive
If the cd rom is not being detected ?
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard. If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Feb 28, 2013 | Computers & Internet
How to reset cmos in dell e521 dimension computer
this will differ depending on which bios you have Press and hold that key during the boot up process to enter BIOS if you have changed any of the BIOS settings by mistake you can load failsafe or optimised defaults using the arrow keys you can after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart CMOS is an on-board semiconductor chip powered by a CMOS battery inside computers that stores information such as the system time and date and the system hardware settings for your computer.. this will reset your cmos
Feb 27, 2013 | Dell Dimension E521 (D10E16) PC Desktop
I would like to know which bios would be better to update in order to improve my battery life
neha dangol,
There is only one bios available for download. Their is one that is the initial release. Version A02 is available below.
I do not see where it will improve the battery life.
XPS Bios A02 Download
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Feb 18, 2013 | Dell Xps 14z - 2310els Laptop Computer 6gb...
Reset dell dm051 series bios vertion a02 password
Removing the CMOS battery usually works, but this model also has jumpers which is safe to do.
http://support.dell.com/support/edocs/systems/dim5150/en/sm/parts1.htm#wp1377780
Nov 30, 2012 | Dell Dimension 5150 (DIM515MIN) PC Desktop
When my dell e510 boots and gets past the first bios screen and shows it booting up the system components it is completely unreadable all letters are in the wrong place or distorted and the entire screen...
Sounds like it could be a graphics card problem problem is it's integrated so part of your motherboard unless you have installed a graphics card.If you have a graphics card in it take it out plug your monitor into the other graphics port and enable on board graphics in your BIOS/ integrated peripherals by pressing F12 key,..if it now works you know your graphics card is broke.If you havn't a graphics cardin it your motherboard needs replacing.
Aug 04, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Dont have post messages at boot not even bios version
sir u can go to the bios by tapping the f2 key while turning the system on immediately....
in the bios page the bios version id written.
also if the system is not booting up try disconnecting each and every device that is connected with the computer except for the mouse,monitor and keyboard.
Apr 25, 2009 | Dell Dimension 2350 PC Desktop
Dell E510 Freezes during Bios Load
u haveto reset your bios wit juper settings it is near cmos set in it 2-3 position then again in 1-2 position .
ten clear all dust from circuit then reaatch all calwe and connectors.
Jan 18, 2009 | Dell Dimension E510 PC Desktop
Dell Dimension E510 Dual Core 2.8 Ghz (847403171179) PC Desktop Logo
894 people viewed this question
Alun Cox
