Question about Tandberg Data Computers & Internet
Disk won't eject - Tandberg Data Computers & Internet
5 Suggested Answers
Ironfist109
  • 3018 Answers
SOURCE: 2007 ford fusion cd player
  • I have see so much of this problem from these players. When you get so many errors for this CD player/changer the unit is done. Dealers stock these by the hundreds to warranty out. Poor quality and poor quality control.
  • Some people, very few, have had success with removing the radio and removing the connectors for a few minutes and then reconnecting. This may reset the radio and while on occasion this has worked it is a rarity as the problem is due to component defects deep inside the unit.
  • Those that opted to send the radio that were not covered by a warranty often payed $300 - $400usd for the repair. The messed up thing is that despite thousands of these needing replaced they were never recalled and they should have been.
  1. Your choices are to have it replaced under warranty if still under warranty.
  2. Pay the dealership to install a new one for you.
  3. Send the one you have into Ford.
  4. Buy an aftermarket CD player/changer
  • Hope this helps and thank you for using FixYA.
Regards, Tony
Posted on Jul 29, 2011
Acadiemedia
  • 131 Answers
SOURCE: hey my mac won't eject
Resolution Tip: Make sure the CD or DVD disc is not in use. Quit all applications that are using files on the disc.
  1. Press the Media Eject key at the top-right corner of the keyboard.
  2. If that doesn't work, drag the disc's icon to the Trash.
  3. If that doesn't work, restart the computer, then hold down the mouse button or trackpad button while the computer is starting up, until the disc is ejected.
    To restart, choose Restart from the Apple menu.
Posted on Aug 16, 2011
SOURCE: PS3 won't accept certain disks. A few disks i
I think its not a hardware problem, it might be the settings especially the region settings, try (search in google) a region free lock. It may work.
Posted on Oct 03, 2011
bronk50
  • 27725 Answers
SOURCE: Computer won't run disk
If this is a cd/dvd drive you are referring to
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem
"you only need to do the following"
if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Nov 04, 2012
Can not get the mac pro osx 10 5 8 to start with the utility disk or with regular start up my on pilot lite keeps blinking
Put the Mac install disk back in. Try pressing command-option-escape to force quit. If nothing happens, then press command-control-power to force a restart. If that doesn't work, press and hold the power button for five seconds or so until the computer shuts down. Power up the computer again, and hold the option key so you can select the instal disc for startup. Run Disk Utility again. Sometimes you get a tangled file reference that requires several tries to undo - this could be calling the sleep routine instead of what it's supposed to do.
May 28, 2013 | Computers & Internet
Mac 0sx 10.5.8
The disk might not have a working OS on it.
It you have successfully run the disk utility the disk probably in full working order. I think that the OS on the disk is either missing, corrupt or not compatible with the computer you are running it on.
May 28, 2013 | Apple Leopard 10.5 Osx Mac Operating...
Disk won't eject
Normally all readers have a mechanical system that can be accessed from the front or the back of the reader to open using a small tool. Normally it's a little hole (like on smartphones) where you can insert a metal piece and push on it to eject the drawer.
May 30, 2017 | LG RHT599H 500GB HDD DVD Recorder with...
DVD won't eject or play
Use a bent paperclip and insert it into the small hole on the front of the player. This should cause the disk to eject. Reload the DVD and try again.
Jan 25, 2013 | Coby TF-DVD1540 15 in. TV/DVD Combo
Samsung blu-ray won't load or eject
Someone is going to have to open it and look to see if the disc inside is out of position or jammed in some way----sometimes you can gently move it a little back into the position where it will eject the disc--which could be your entire issue.
May 28, 2012 | Televison & Video
Disc won't eject
Dirty or damaged disk. remove screws in back of player (carefully) and gently slide disc out, do not force. Or take player back to store and ask them to fix or replace it.
Joe Don
May 25, 2012 | Toshiba XDE500 Player
I can't get my DVD disc to eject. It will play but won't eject? Any suggestions
You should try unplugging the DVD player from its power source then plugging it back in. Now try to open it and if that doesn't work than you'll probraly have to take it apart to get the disk out but sometimes the DVD players can get worn out or if you have a cheaper DVD player it might just be freezing up on you. I have had these problems before. I just took the DVD player apart to get my disk and then trashed it.
Jan 23, 2012 | GoVideo DV2150 DVD Player/VCR
PS3 won't accept certain disks. A few disks i have won't play in my ps3. it happens to both blu-ray movies and games, and it seems to only happen with blu ray disks. i'll put the disk in, and...
Hello
The noise is actually a product of dust from a blue ray disc.Over time these discs heat up and leave a residue on the blue ray lens.
Try using a lens cleaner to remove dirt and clean lens.
Also i read an article that using a wireless controler can also cause freezing of the blue ray.
Oct 01, 2011 | Sony Playstation 3 (PS3) Console
Hey my mac won't eject a disc. i have tried a lot of stuff and nothing happened. when i restart it the disk spins and doesn't sound stuck and when i used disk utility it said there was an error...
Aug 16, 2011 | Computers & Internet
The disc tray on my iView 4000KR won't open. It has a disc inside that plays fine, but won't eject. This has never happened in the 18 months I've had the player.
Under each disk tray is a very small hole; this hole is for use when you experience the problem like yours.
Get a paper/money clip and straighten the wire; push the wire into this hole and your disk will open.
Regards
HCF
Jun 22, 2011 | Computers & Internet
Computers & Internet Logo
27 people viewed this question
Top Tandberg Data Computers & Internet Experts
David Payne
David Payne
Are you a Tandberg Data Computer and Internet Expert? Answer questions, earn points and help others
