Question about Vtech 5.8GHz Cordless Phone with Digital Answering System
Replaced battery and phone stays in 'searching' mode when off bas
I bought replacement batteries and place on base to charge. When I pick up the phone the display reads 'Searching' and none of the functions work.
  • 1 more comment
  • ranman257 Jan 24, 2009
    I actually replace batteries in two of my phones, one on the base and one on the spare charger. Tried suggestion...no change.
  • LN804 Feb 01, 2009
    All phones say "place in charger" or "Connecting". None have a dial tone.
  • Roberta Smith
    Roberta Smith May 11, 2010
    place the phone into the actual base not the spare charger for a couple seconds... you should see the light flicker on the base... then try it.
Unpluged the base for a couple of minutes....problem solved
Posted on Jan 25, 2009
My phone is display out of range
  1. hi..
  2. When you pick up your GE cordless phone and press a button, the phone should beep as a confirmation that a button has been pressed. If the telephone handset does not beep, or if it does not respond to any buttons, the battery may be in need of a recharge. Verify that the cordless phone base unit is plugged in to an electrical source, then place the handset into the charging cradle. If no lights illuminate on the phone, or if charging fails to correct the issue, clean the metal charging contacts on the cordless handset and place the phone back on the charger. If it still fails to respond or to charge, the unit may need to be serviced or replaced.
  3. If the cordless phone charges up and appears to be ready for use but dies after only short periods of use, the internal rechargeable batteries may need to be replaced. Replacement batteries are widely available at electronics and discount retail stores. Note your phone's exact model number, as this number will be necessary when purchasing a replacement battery.
Jan 03, 2011 | Uniden Cordless Phone
The original battery stopped working. Whenever we picked up the phone it just made a very loud noise in our ears. Now I ordered replacements batteries from ebatts. The red light is always on, slightly...
place the phone in the BASE for several seconds then try it. make sure it is the base and not a stand alone charger. if this does not correct it ensure you have the correct replacement battery for the phone. be aware the first time you charge it ... it has to be charged for at least 12 hours
Dec 08, 2010 | Dual Maxus 5.8GHz Handset Cordless Phone
Bought a replacement battery for extra handset and used the adaptor from the base unit to try to charge the battery. This did not work. Charging notice did not appear in the display window and the charge...
:.. extra handset ..." implies you have another handset. Try the battery from that handset in the "extra." If it works, the replacement battery you bought is defective.
Sep 17, 2017 | Panasonic KX-TG6072B Twin Cordless Phone
My phone is fairly new and almost immediately after I pick up the phone it starts beeping for low battery. Also it searches for a signal all of the time and cuts off conversations because it's searching...
It is searching for a signal because its signal is so weak it cannot find the base. If it cannot communicate with the base, there is no conversation.
New or not ... your battery is either faulty, prematurely dead or not charging. I am leaning toward not charging ... do you have it plugged into a hot outlet (not switch controlled)? Can you measure the power coming OUT of the transformer? Is there a charging light on the base unit that would indicate a charging condition?
Jun 05, 2010 | Lands Phones
My GE 27909EE1 cordless phone's batteries will not stay charged. I've replaced batteries 3 times in 6 months since I bought the phone. Help!
Well, depending on how much you use the phone will determine how long the battery stays charged. However if you not using it enough to run the battery down, my first guess is that the "charger" is the culprit and not the battery. If you have a seperate charge cradle perhaps try to charge it in there.
Apr 17, 2009 | Uniden Cordless Phone
AT&T hanset indicates "Searching for base"
how long since the handset battery was replaced anything over 12 monts may be a battery problem
May 15, 2017 | AT&T 2455 Cordless Phone
Cant get one of the phone to get dial tone says unavalibel
All you have to do is put the phone that does not get a dial tone on the MAIN CHARGING BASE for 20 seconds! it will then sync up!
Jul 17, 2008 | GE 25931 Trio Cordless Phone
Uniden phone
That sounds like the battery is not charging properly. When in the charger there is enough voltage passing to power the handset, but when pulled off the charger it must rely on just the battery. I suspect you replaced your battery because you were having a problem, right? Your problem may be dirty charging contacts. Try taking a pencil eraser to your charging contacts on your handset and base. Try charging your handset again, and ensure your charge light comes on when doing so. Let it charge overnight. Hope that helps. CG
May 26, 2008 | Uniden Cordless Phone
Motorola MD760 dies after 5 minutes of use-- from being charged for days on base
this is a battery prob replacing battery will solve this prob hope this solves your prob make sure the battery connectors are conected propery securely first before replacing if ok then replace batt and prob should be solved check then conectors are clean where the phone sits on base and check phone sit on base properly if it does then it is def the batt replace.
Nov 15, 2007 | Motorola Mobility MD761 Cordless Phone
Vtech 5.8GHz Cordless Phone with Digital Answering System Logo
190 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
