Question about Polaroid TDX-01930B 19 in. LCD HDTV
Blue Screen No Signal it what tv says
Called Verizon, they walked me thur the steps and said I.ve done something to the tv because they are showing a strong signal.
Mine did the same i just pushed the tv button on the remote to make sure it is not looking for an out side input like a vcr/dvd or cam corder then hit menu to go to the main menu then scane for all working channels also see page 42 in the book
Posted on Mar 03, 2009
Try a different port for verizon. Mine did this with comcast and I had to switch to the rear port. These tvs arent too good
Posted on Jun 16, 2009
What part needs to replaced on Element TV?
I have three of these TVs in the shop. They are less than a year old. The signal board is good, the T-con board is good, and the power supply is good. The panel (once called picture tube) is bad. Much too costly for repair. Thanks for asking me.
Oct 12, 2014 | Element Electronics Televison & Video
What happened to my color on screen?
I experienced a similar problem with my 52" Sharp Aquos TV. I called and spoke with Sharp service dept. and they walked me thru the process of resetting the TV to it's original "default" values. It worked great once I completed the steps while on the phone with them.
suggest you do the same thing with JVC.
Aug 15, 2014 | LG 42LC2D 42 in. LCD HDTV
Ilo won't work with ps3
The set receive no signal at all. It will be best get it repaired by any experienced service technician.
Apr 22, 2012 | iLO 3200 32 in. LCD Television
Sylvania (SRD3900) DVD Player / VCR Combo i can't seem to plug in the red/white/yellow cables into the right places directly to my old toshiba tv to play either tapes or dvds. can you instruct me? thanks.
Greetings - It's very simple so I'll show you how and then I think it may be another problem (nothing broken).
You need to plug the corresponding color cables into to outputs on your player I've circled above and then into the corresponding inputs on the TV. You've probably done this correctly.
PLUS - You have to, using the remote for the player, set the source to either DVD or VCR and then you have to, finally, on your TV set the input (with the remote) to what is called probably VIDEO or VIDEO1. If there is still nothing on the screen keep (with the DVD or Tape playing) hitting the TV remote input button until you see an image or you've come around to where you started.
Unless something is broken (unlikely) you should be able to watch DVD's or Tapes depending on what input you select on the player.
If it's not working you've somehow missed a step or the Video input on the TV is called something else. If that happens come back here and give the player AND TV brand/model info and someone will be able resolve your problem.
Good Luck and thanks for using Fix Ya.
Mikeywaf
Apr 21, 2011 | Sylvania (SRDD495) DVD Player/VCR
I was watching tv and the screen went blank. It
You would have to try an INIT and see if it causes the tv to be operational again. It is something that you have to be walked through step by step by step and can erase the memory of the tv if done improperly. Call Sharp tomorrow morning at 9AM CST and someone can walk you through one. Call 800-237-5277 or if you have an aquos advantage model call 87-332-7867
May 15, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Cant use fios remote to power/volume
Yesterday I called Dynex at 1-800-305-2204. The rep gave me 0463 which didn't work when I called VERIZON FIOS but the Dynex rep did inform me during the call that if it didnt that Dynex is comparible with Orian, Emerson, Memorex, Sansui, Sylvania and Zenith. So any of these tv codes should work. The code of Orian which is 0490 indeed worked!!!! And when you call Verizon make sure when they help you program your remote that they do the second step if they dont tell you which is add the code 799 which will let you just push STB then Power to cut on/off the tv. My bedroom tv, I always pretty much had to use the tv remote to cut on and off but when the Verizon rep gave me that step for the original tv I was having problems with told me this step, I had her walk me through the other tv remote and add that code and its great. She said that alot of technicians just been taught the other way. Hope this info help you.
May 23, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Router problem
I didn't fix the problem with the router(I disconnected the thing) but I did find out that I needed a new filter that connects to my phone jack. No problem so far with my internet connection and it has been 12 hours now. lol I am wondering now if I hook my router back up if that filter WAS the total problem. Now I am scared to hook the thing up again!! This was a lotttttttt of trouble and very frustrating.
Dec 27, 2008 | Belkin (F5D9230-4) Wireless Router...
HDMI crap out
I got the solution. Contact Customer Service, ask for LEVEL II Tech, and ask them for the old firmware. It will take a lot of pressuring, but they will send it to you and then it will work fine!
Feb 02, 2008 | Televison & Video
JVC 36 inch televivision i bouhgt it about 6 years ago
The lightning probably zapped the tuner in you set. If no signal is present the screen is muted (BLUE).This is a feature to prevent your seeing snow on the screen. Stargazer
Jun 14, 2007 | JVC TM-2703SU 27" TV
Polaroid TDX-01930B 19 in. LCD HDTV Logo
1,255 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
