Question about Epson Expression 10000XL Flatbed Scanner
How do I replace the glass platen on an epson 10,000 xl scanner?
4 Suggested Answers
ginko
  • 19396 Answers
SOURCE: epson expression 1640 xl scanner
You can order the lamp from website below:
Parts for the Epson Expression
Posted on Jan 23, 2009
SOURCE: scanner glass clean
Cleaning the glass is rather simple. Take the 2 screws under the cover out. Now gently lift the top part of the scanner (some force may be needed). Then the scanner is in 2 parts and the glass can be cleaned inside and outside with a wet wipe glass cleaning pad. Dry the glass with a towel and inspect the glass with a lamp, that no cleanser remains are left. Now install the scanner in reverse order.
Posted on Feb 14, 2011
e-Guru
  • 3917 Answers
SOURCE: I just got an epson
Hi
Remove the transparency adapter from the top of the scanner and take notice of the two small screws where the adapter was unplugged. Remove the screws with a small Phillips driver, and this is where you must be careful. Lift the rear of the glass frame approximately one inch from its base and firmly push it forward to remove it from the base. There are two plastic hinge retainers at the front of the glass frame that must be shifted forward to free the frame from the base. If the base is lifted to high after the screws are removed these plastic hinges could be damaged. After the glass frame is removed clean it with a water vinegar solution and replace it with the same care with which it was removed.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Apr 07, 2011
How to attach loose scanner glass
The glass plate in scanners is almost always held in by some kind of 2 sided adhesive tape AND plastic clips. Th adhesive probably failed, but the glass plate is probably at an angle and not resting on the plastic clips correctly. These act as a failsafe in this very situation, so the glass plate doesn't break or damage the scanner guts.
Anyway, if you want a permanent repair, this is the tape you should use: Amazon com 3M Scotch Heavy Duty Mounting Tape Clear 4010 Double Sided...
It will definitely support the weight of the glass and then some. Be careful with this stuff, it will remove paint (or worse) from drywall. You should only need 4 strips, one for each edge of the glass. Apply it firmly to the glass, then stick the glass onto the plastic bracket.
Apr 13, 2014 | Epson Perfection 1240U Flatbed Scanner
Black vertical line prints on the right side of every page.
Good Day Tkidwell!
Better check and clean the ADF platen glass and the flatbed scanner glass.
Use a lint clothe moistened with alcohol or water and gently wipe the dirt in the glasses of the ADF platen and flatbed scanner.
You can also try cleaning the roller by performing the deep cleaning.
Jul 12, 2011 | HP Photosmart C7280 Printer
When making a copy, be it A4R or A4 Lines cross horizotally from left to rigth
Good Day Lucamoses!
Maybe it is time for you to clean the scanner glass and or the ADF platen glass.
Remember a small dirt, usually a dried ink in the scanner glass or platen glass will leave a horizontal black lines in your copied paper.
I hope the problem you have Lucamoses is just as simple as cleaning the glass to solve it.
Good Luck!
Jun 10, 2011 | Computers & Internet
Our HP 3015 fax is not sending a readable fax at the receiver's machine. About half the page is readable, and the other half has a series of horizontal lines which makes the balance of the page unreadable....
it only happens when you have something on the scanner
Over time, specks of debris might collect on the scanner glass and white platen, which can
affect performance. Use the following procedure to clean the scanner glass and white platen.
1. Use the power switch to turn off the product, and then unplug the power cord from the electrical socket.
2. Tilt the device control panel forward.
3. Clean the glass strip and the white platen with a soft cloth or sponge that has been moistened with nonabrasive glass cleaner.
hope it solve the problem, if so rate the solution
Nov 22, 2010 | HP Office Equipment & Supplies
Getting a black vertical line on paper when using top feed, does not do it when placed on scanner
1. Check the Automatic Document Feeder for any debris (paper, lint, etc.)
2. Open the top cover to reveal the platen glass.
3. Look to the far left, you'll see a thin strip of platen glass seperate from the bigger plate where you place flatbed scans on.
4. Check the thin strip of platen glass for any marks (correction fluid, marker ink, etc.)
5. Wipe glass with a damp cloth and some Window cleaning detergant.
Does the line still appear now when you scan using the ADF?
BD
Sep 22, 2010 | Brother DCP-7020 All-In-One Laser Printer
How do i clean underside of platen glass Canon MP160
for mp160, flip the cover open, the one that you open to gain access to the ink cartridge. you will see two screws at the underside of the scanner base. unscrew both. gently pull down at the front control panel and pop up the front lip of the plastic that holds the platen glass. then, at the back of the printer, adjacent to the paper loading tray, just below the platen glass cover, you will see two clip like stuff. remove the tray by pulling it upwards vigorously but firmly. then, get a flat screw driver to pry these up to release the lock. then, facing the printer, gently pull the whole of the platen glass, together with its plastic frame, towards you. do this while gently rocking the platen glass up and down, or left and right. to return the platen glass, reverse the process.
Jan 12, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Dell 1815 dn printer scanner issue: single line appears in scans
Do you get the same line when you use the adf for other purposes?
If so, check the scanner glass just before the platen for something like white-out on it. Clean both the scanner glass and platen glass with Windex.
That is a common problem on all ADF scanners.
Good Luck
Nov 15, 2008 | Dell 1815dn All-In-One Laser Printer
How do I clean the INSIDE glass/platen?
You mean the inside of the scanner glass? (The platten is a part of the print unit),
You'll have to remove the sides and read cover. Unplug the scanner wires and remove the scanner assembly. Separate the document feeder from the scanner bed. Open the covers of the scanner bed (usually there are screws holding it together). Remove the glass and clean it. Reverse the process to reassemble.
Be careful. Canon multipasses are built a little like a Chinese puzzle box. There are little snaps everywhere as well as screws. Watch out you don't force anything and cause the snaps to break.
Nov 05, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Dirty platen
My suggested solution was to become an Elite Expert and to consult myself.
Feb 13, 2008 | Epson Perfection 1670 Flatbed Scanner
Inside platen glass needs cleaning
http://www.nifty-stuff.com/forum/viewtopic.php?pid=32066 use this link for disassembly it gets the printer and scanner apart but does not show how to disassemble the scanner.
Nov 27, 2007 | Canon PIXMA MP760 All-In-One InkJet...
Epson Expression 10000XL Flatbed Scanner Logo
537 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
