Set washer to just spin
Hotpoint ultima1200 wm72 how do you set washer to just spin wet clothes i have no manual
  • Washing Mach... Master
  • 3,463 Answers
Set timer dial to the final spin position,approx 8-40 position by clock time you will then hear the pump come on , and it will do just the last final spin.
The spin symbol is marked with a large squirl.
To get a copy of instructions go to
On the list click on Manuals-user guides-handbooks
In the search box enter your washer model number, and download the instructions.
Plz rate my solution.
Posted on Jan 24, 2009
Hotpoint pump
Is the machine not spinning? May need new bushes. Sited underneath and wear down by making contact on drum.
Feb 05, 2012 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint aquarius extra 1000 spin washing but when spinning, clothes coming out still soaking wet. Help!
Check the machine filter, clean it and this problem might go away. Use manual for locating the filter.
Feb 28, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
My washer spins out very slowly and the water drains but the clothes are very wet.
f the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag), a worn clutch (GE/Hotpoint), or a worn motor pulley or tub bearing.
Nov 30, 2010 | Westinghouse WWS833ES Super Capacity Top...
I have a hotpoint wm54 and it is not rinsing or spinning properly, at the end of the cycle the clothes are dripping wet & soapy, however if i manually put on to rinse and spin it seems to work!
You need to check and clean the pump filter.
Remove rear panel od washer, locate and remove large black hose on bottom of drum, remove and clean filter inside the hose.
Nov 15, 2010 | Hotpoint Aquarius WF000 Front Load Washer
you have something stuck in the pump..a sock maybe or some other small article of clothing
Jan 11, 2009 | Hotpoint -Ariston VVSR1030HWO Top Load...
Clothes still wet after fast spin cycle
Belt loose or motor / motor control board possibly defective
Sep 13, 2017 | Hotpoint Aquarius WF000 Front Load Washer
Clothes wet after spin cycle
if its not the belt its your brushes in the motor that need replaced
Jan 04, 2008 | Hotpoint VBXR1090D Top Load Washer
It probably needs a new Pump, the wm72 has what they call a magnet pump and they can give false readings to the programme. Anew pump will cost sround 20 GBP. For an engineer to do it will cost around 50 GBP.
Nov 18, 2007 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
102 people viewed this question
Top Washing Machines Experts
