Question about Smeg Dishwashers
Smeg di6012 how to high or raise
I have difficulty tomake it high according to my required hight
Replace front wheel bearing 2009 Honda accord
Hello James.
I don't wish to insult you but replacing the front wheel bearing of a front wheel drive vehicle requires the sort of tool kit and skill level that if you need to ask how you do you do it you are unlikely to possess.
By the time a wheel bearing needs replacing it has been subjected to years of heat, cold and moisture and removing the bearing from the hub can be fraught with difficulties not covered by an average repair manual, difficulties which needs experience and equipment to overcome.
As if that isn't bad enough the work needed to clean and prepare the hub to accept the new bearing needs the realisation the assembly is a piece of precision equipment requiring very high standards if the replacement bearing is to have the best chance of returning a good life-span. This is also true of actually fitting the new bearing where if pressure isn't applied correctly it can be ruined in a second or have it's working life seriously shortened.
I suggest you ask an experienced someone else to fit the bearing this time while you observe.
Feb 08, 2015 | 2009 Honda Accord
Adjust high adjust of blades
There is a handle to lower or raise the blades. It should be numbered from 1 to 10 or so. Right side of driver.
Sep 15, 2014 | Sears Garden
Adjust blade hight
No nuts if a riding mower, there is a handle to raise/ lower blade.
I have a SMEG FA311X Fridge Freezer which I would like to turn into a wine storage fridge. To do this I need to raise the internal temperature significantly (I'm looking to run it at around 13 degrees C)...
you can get an after market thermal control device that would put it into the temperature range you require, contact an appliance parts supplier for your needs.
Best regards Falco
Nov 04, 2013 | Smeg Refrigerators
Re: SMEG Integrated Dishwasher ST663. I'm having
usually a screw on the striker (the bit sticking out that goes into the door) it will be a slotted adjustment so just loosen (not remove) the screw and pull it out a mm or 2.
retighten and test.
Also, clean the seal. While your at it, the sump filters and spray arms.
Oct 18, 2013 | Dishwashers
My high beams won't turn off
sounds like the selector is stuck. you can try to jiggle it on and off aggressively without too much pressure
Oct 24, 2012 | 2006 Honda Accord
Igot a1990 honda accord it idles high and low in park
check the iac valve on the throttle body, have ur car scanned tomake sure
hope this helps
Nov 17, 2009 | 1990 Honda Accord
Smeg fautly themostat - too hot, burns everything
Sounds like thermostat faulty, make sure sensor is not detached or broken in oven, if still under 1 year old, then I suggest you contact service agent.
Pleas rate my solution.
Thanks.
Oct 10, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
1989 Honda Prelude runs at hight rpms until warmed up
check for vacumm leaks or disconnected vacuumm hoses around the in take manifold!
Nov 20, 2008 | 1996 Honda Accord
REQUIRE AN INSTRUCTION MANUAL FOR A SMEGG SE378 MFX5 OVEN
You can get instruction manuals for all smeg products by following this link http://www.smegtech.com/site/smeg/myapp/libretti/index.php?lang=EN
Dec 06, 2007 | Smeg Ovens
Dishwashers Logo
22 people viewed this question
Top Smeg Dishwashers Experts
Cleverer2
Garth Jackson
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
