Question about Emerson MW8168B Microwave Oven
Microwave Emerson Model MW8168B just died, plugged in another outlet check circut breaker nothing. Is there a fuse I can check? how do I find it?
  • thomasm6 Mar 13, 2009
    The unit just quit and I checked the circuit and it is working.
    I just want to know the safe way to remove the cover and replace the fuse.
I threw it out and bought a new one
Posted on Jan 25, 2009
Emerson MW8168B microwave fuse
Good job, and thanks for passing along the information.
Aug 31, 2012 | Emerson MW8168B Microwave Oven
My microwave has no power
Is the unit plugged into the outlet.
Check to see if the outlet has power by plugging in a working light.
If no power check fuse/circut breaker.
Aug 02, 2009 | Microwave Ovens
Our Emerson microwave died and I bought a new one. Plugged it into the same socket and it immediately shorted out and died. After the new microwave died I plugged a blender into the same receptacle and it...
I believe you have a bad circuit breaker or fuse. If you have a delay fuse contrilling this circuit, that would explain the spotty availability of power to the outlet. Also, a faulty circuit breaker can operate in an irregular way, as you describe.
A microwave oven requires a lot of power, relatively speaking. If your microwave is a 1200 watt model, for example it draws 12 amps of power, which could well be almost all of the power available at that outlet, providing that other appliances were not also drawing power from that circuit at the same time.
I can assist you further, but if this information is all you need to proceed that is fine too. Get back if you need more assistance.
Jul 02, 2009 | Microwave Ovens
Replace Emerson Microwave Ove Fuse
Most of the manufactory has put them in the back where the power cord comes in.
Mar 13, 2009 | Emerson MW8168B Microwave Oven
Microwave died and started spewing smoke
Sorry but it sound like a component in the power circuit, transformer/capacitor/diode?.
if you feel capable to do the testing I can guide you
Feb 22, 2009 | Emerson MW8168B Microwave Oven
NO POWER
Inside the microwave is a fuse. If you can, try plugging the microwave into a different outlet (use an extension cord). If it does not power on, you have likely blow the fuse. If you are technical, you may look into replacing the fuse yourself (you will have to remove some parts of the microwave exterior to get to the fuse). Otherwise, if no longer in warranty, you will need to have a shop or handyman replace fuse.
Mar 29, 2008 | Microwave Ovens
It just seemed to turn off
yes,unplug the unit ,remove the outer case ,follow the plug inside to the fuse ,read the amperage ,test the fuse with an ohm meter should read shot or 0 ohms if not replace whit same type and amperage,
Dec 01, 2007 | Emerson MW8168B Microwave Oven
pls check fuse replace with since there were no noises seems pretty straight forward
Jul 30, 2007 | Emerson MW8168B Microwave Oven
Emerson MW8168B Microwave Oven Logo
297 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
