Question about Indesit W 123 Front Load Washer
Hi, my switch keeps going around and around without stopping
Hi my washer (indesit) has a problem. When i put it on to wash the switch just goes around on its own without stopping. It lets in water and then when it gets to spin it just goes around
  • chrisgunnee Jan 24, 2009
    Indesit WM12X wash selector control switch keeps going around and around without stopping
  • cjjmartin Mar 14, 2009
    I have a WM12x and the programme switch spins without clucking or engaging. Filter did have a £1 coin in it, but since cleared timer swicth is still the same. 2 kids and lots of washing! Help !!!
My machine started doing this mid-way through a wash cycle - at the drain/spin cycle.
The Indesit Manual stated this:
The programme selector knob keeps turning?
Wait a few minutes for the drain pump to empty the tub, switch the washer off, select one of the symbols stop/reset, then switch it back on. If the knob continues to turn call for assistance.
In my case this did nothing - the machine was full of water and the selector switch still kept turning. I followed the above procedure and the switch did indeed not move at the stop symbol. However I then tried setting it to drain, spin or a new wash cycle. Sometimes it would stay in place for a few minutes and then spin round continuously - other times it would just start turning around immediately.
As per the previous solution I had to manually drain the water via the filter (bottom right) and then spotted that some fine cotton had fouled around the green paddle at the back. I removed the cotton and then set the switch to a spin cycle and the machine worked again.
Posted on Feb 19, 2010
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
regards
Michelle
Posted on Jan 25, 2009
Hi, my indesit is W93T but when i start for wash...only water enter and exit Without being washed... non stop water enter and exit washing machin without any moving... please guid me thanks hossein...
This is symptomatic of an intermittent water control valve- sticks open too long or permanently open.
It needs replacing- service call ;-0(
Good luck,
John C
Mar 16, 2011 | Indesit W 123 Front Load Washer
Going through wash cycle but not spinning
my indesit starts to wash then comes up with 3 falshing lights and just keeps leting in water if i put the machine on with nothing in it it goes the wash until it gets to spin then starts to spin and agian starts letting in water
Mar 26, 2010 | Indesit W 123 Front Load Washer
Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
May 30, 2009 | Indesit W 123 Front Load Washer
Dial keeps rotating
This a common problem with Indesit washers..
It is not a timer but a programme selector switch.
What you need to do is the following.
Switch the m/c on, let the drain pump empty the water, then switch the m/c off.
set the selector switch to one of the black dots on the dial, which is stop/reset.
Then switch washer back on, if the dial still keeps going round and round, then you are going to have to call an engineer, as you have what is called an Anomaly (fault).
Plz leave feedback for this solution.
Thanks
Dec 09, 2008 | Indesit W 123 Front Load Washer
Indesit wm2x
We had similar fault.
Rectified ours by switching off at the mains and put dial to one of the dots. Switched on and it reset.
Good luck
Dec 03, 2008 | Indesit W 123 Front Load Washer
Indesit washing Machine W93
Pump or hoses still blocked,Or pump has had it,Can supply new pump by post if req.
Sep 18, 2008 | Indesit W 123 Front Load Washer
Washing machine
did you reset the machine after you checked the filter? if not put the selector switch to any of the stop positions the switch on wait till the on/off light flashes rapidly , then switch off and try again.
Aug 16, 2008 | Indesit W 123 Front Load Washer
We have a indesit wil 143s faulty
the pressure switch should be easy to replace. it will be a round unit with wires going into it and also a small clear plastic tube attached. it is usually mounted around the top edge of the case. i would also check that the pressure system is not blocked (the other end of that clear plastic tube) as blockages may keep pressure at the switch leaving it in the "full position" pop the pressure tube off of the switch and force some air down the tube to check.tony.
Jun 03, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
1,034 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
