Question about Spectra Precision Laser LL500 Exterior Self - Leveling Laser Level
I need new clasps for LL500 container box.
The plastic clasps that fasten the laser level box are broken. Can I get replacements?
    Scholar:
  • 87 Answers
Yes part number is Q103224 for the New LL500 blow mold case.
Posted on Sep 06, 2015
Lazer motor doesnt rotate
These are belt driven rotating heads. While the 500 series have the most robust belt in all the laser industry, they still break. Likely this is the cause. Or the connector has come off the board, it's odd, but it happens.
Aug 03, 2015 | Spectra Precision Laser LL500 Exterior...
Why doesn't my spectra troubleshooting LL 500 receiver read the laser it does not beep or notifies (HL 7000 receiver it was working just fine when all of sudden it stop beeping
Try another receiver. If the laser works with the other receiver, then it is the receiver. There is no repair for these receivers, save for cleaning the contacts and circuit board, if moisture gets is. They have a 3 year replacement warranty.
If another receiver doesn't fair any better, then your laser is either putting out no beam, or not the right beam. The laser diode could have failed, or the diode has become unfocused. If this is the case, bring it to a technician to be fully diagnosed.
Jul 20, 2014 | Spectra Precision Laser LL500 Exterior...
The off level light doesn't turn off therefore doesn't level at all,
Your vial and compensator no longer match up. Move the foot screws until you can get your laser to spin, then adjust your leveling vial until it reads level again, using the 3 screws holding the vial inplace.
Aug 18, 2013 | Spectra Precision Laser LL500 Exterior...
Laser is level but out of level light blinks and will not spin
Your compensator and leveling vial are no longer aligned. Use your foot screws to find a place where the laser spins, then use the 3 hex head screws on the vial, to adjust it to read level.
Dec 23, 2012 | Spectra Precision Laser LL500 Exterior...
Resetting LL500 SPECTRA PRECISION LAZER
If you mean you cant level the laser, there are 3 T15 torx screws that hold the base assy into the laser, accessible through 3 holes in the base plate. Unscrew the three screws and remove the base, and disassemble it, clean all the dirt out and relubricate the base with a heavy silicone lube. Reassemble and it should all move smoothly.
If you mean something else, please specify
May 06, 2012 | Spectra Precision Laser LL500 Exterior...
How to calibrate spectra precision ll500 laser
There are two brass screws under the upper most metal plate. They are the calibration adjustment screws. The manual tells you how to do a peg test. If your peg test is out, move the corresponding screw until you reach the calibration point you want.
Sep 29, 2011 | Spectra Precision Laser LL500 Exterior...
Clasp to lid console top box broken. How do you
This part is available at your local Infiniti dealer. The plastic part is replaceable.
Feb 09, 2010 | 2008 Infiniti FX35
How to remove the clasp that holds the glove box front on has broken, so it is only held by one clasp how to remove and replace with a new one. Audi A4 03 reg thanks Gary.
Look here for pics: http://www.thepontiactransampage.com/glovebox.html
  1. Open glove box door.
  3. Put in lock position and remove key.
  5. Insert key.
  6. Turn key to unlatch position and pull lock out.
  7. If the latch needs to be replace un-screw collar.
  8. Reverse to re-install.
Oct 27, 2009 | 2005 Audi A4
The clasp on the plastic dome of my bissell carpet cleaner has broken
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=538911
Generic problem for all Vacuums
Posted by amereagle199 on Apr 23, 2008
The clasp on the plastic dome of my Bissell carpet cleaner has broken
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
I would advise you to try to contact your local vacuum cleaner dealer in your area or in the yellow pages to see if they have a new or slightly used plastic dome for your Bissell
-- The used one would be less expensive but if you cannot find a good used or new plastic dome – please feel free to call the Bissell factory listed @ the bottom of the page. Make sure you give them the Brand name (Bissell) and the Model #
http://www.bissell.com/ By Phone Customer Service:
(800) 237-7691 Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 23, 2008 | Vacuums
Spectra Precision Laser LL500 Exterior Self - Leveling Laser Level Logo
126 people viewed this question
Top Spectra Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Spectra Measuring Tool and Sensor Expert? Answer questions, earn points and help others
