Question about Radio Shack Pro-2018 Scanner
Wont Turn On
I have had this scanner for about 2 years and it has been good to me. i left one day and turned my scanner off and the next day i went to turn it on and nothing happpend. please help
    Problem Solver:
  • 8 Answers
Try moving the power supply connector around.
Posted on Jul 13, 2007
Car on limp mode- changed AC compressor-water pump-harmonica balancer- pulliies belt air cleaners-battery was flat all good now went good on test drive next day it went to limp mode after short drive now...
use a fault scanner to reset the CPU program If everything is good it should work . if not the fault codes will reappear and you will know what to fix.
Dec 25, 2014 | AC Cars & Trucks
Tablet wont turn on
My Xelio P1001A tablet wont come on
Jan 02, 2014 | Kocaso M860W 1.2GHz 4GB 8" Capacitive...
Pontiac g6 drive the car a bit went somewhere got out came back 2 hours later all it did was turn over an wouldn't start has plenty gas left it alone for a bit try to start it it fired right up. So I...
flassed less engine power wth????????? Flashed reduced engine power ! Electronic throttle control problem ! Your best bet ,take it to a GM dealer , buick , cadillac , GMC . You do not have diagnostic test equipment or knowledge to even diagnose this.
Jul 06, 2017 | Cars & Trucks
Cranks over but wont start
fuel pump went out just like mines
Feb 01, 2013 | 2002 Pontiac Montana
Have an 85 chevy 4x4. I just had the 305 engine rebuilt with a new intake and carb. It was working fine for a couple days and one morning I went to start er up and the engine just cranked and cranked,...
When you turn the key front. Listen for the fuel pump to prime. It should sound like a low humming noise that lasts about 3 seconds. If it does then check for spark by pulling one of our sparkplug wires and putting an extra spark plug in it. Place the end of the wire down somewhere safe and crank the motor. If you can't seek spark in the plug, it is most likely your coil failing. So, check fuel pump and fuel pump relays first, then spark. Good Luck.
Mar 08, 2010 | 1983 GMC K2500
Grand Cherokee wont start, clicking coming from interior fuse box
Bare or burned wire, most likely battery cable or alternator cable near exhaust system which might be making contact with a metal part somewhere, off and on, because of bumps, vibration, etc.
Jul 29, 2009 | 1995 Jeep Grand Cherokee
Saturn SC wont turn over
when it comes to DC electricity like on automobiles. DC current wants a really good connection. check and make sure the wires at the alternator you just installed are tight. check the tightness of the battery cable connections at the battery. check the tightness of the main cable that goes straight to the starter. small things like the dome lights ect.... will still work many times when the connection is not so good, but big current items like the starter need a good hard connection to work. sometimes when the connection is sub par, the starter will just make a clicking noise but wont turn over the engine.
Jun 11, 2009 | 1992 Saturn SC
LG hdtv lcd wont turn on will only go to blue screen
How old is the set.. If you its relatively close to being out of warranty LG will probably cover the repair. Contact them at 800-243-0000.
Dec 07, 2008 | LG 42LC2D 42 in. LCD HDTV
Display turned off, but i can make and receive calls
If you take the battery out then with the battery out plug in the charger, this worked for me.
Jun 15, 2007 | Motorola Mobility RAZR V3
Radio Shack Pro-2018 Scanner Logo
48 people viewed this question
Top Radio Shack Radio Communications Experts
Greg Cann
Greg Cann
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
