Question about E-Machines T1090 PC Desktop
A an Emachine T1090 with 128mb of RAM. System takes forever (10 minutes) to boot up. Once up and running it performs much better. Are there any known cures? Would adding RAM help?
  • 41 Answers
Adding RAM would definitely help. What operating system are you running? You could run msconfig and try starting with a diagnostic startup. If the computer loads much more quickly, you could remove some of your startup items. Ask someone before removing anything though!
Posted on Jan 24, 2009
Slow boot HP Pavilion zv6131us
Eric,
There are a lot of factors that can be a cause to slow boot up times. Sometimes it is a lengthy process to figure out what or why the boot time takes so long.
In Windows XP the first step that I would perform is to click on Start>Run and then type: "msconfig" and click OK. (Don't put in the " marks.)
Once you are in the System Configuration Tool, click the Startup tab. Disable all of the items in that list. Then click the Services tab. Check the Box for "Hide all Microsoft Services" and then disable all.
After clicking "OK" you will be prompted to reboot the computer. Do so. Time the boot/startup time. If it has significantly improved, then half of the troubleshooting is done. Next, you will need to go back into MSCONFIG and go to the services tab and enable a few of the services. Then apply and reboot. Make sure to write down which services you've re-enabled and make sure to time your bootup.
Through the process of elimination, you should be able to find out which service is slowing the system down. If you have rechecked all of the services and the system is still booting with an acceptable speed, then begin checking the startup items. Do the same process of checking just a few items at a time, writing down which ones you are checking. After rechecking just a few, apply and reboot, timing the boot up time.
Through this process you should be able to find the services or startup items that are slowing your computer down. Once the offending services or startup items are identified, you will need to make a decision of whether to leave that item out of the startup process or possibly reinstall that program.
If you find the offending item, and are unable to identify it by name, you can always go to Google and type that item's name into the Google search and it may give you an indication for what that startup item is, or what it is part of.
Sometimes, if you have a virus or malware, you may find the items listed in startup. If you do find a suspicious item, then you will need to make sure to run a full malware scan to remove any of those items that are unwanted.
Hope this has helped steer in the right direction to find out why your computer is running so slowly!
Nov 20, 2011 | HP Pavilion zv6131us Notebook
Taking 7 minutes to boot up
You may have a virus infected. I would get it checked out or try to trouble-shoot yourself.
Please follow this guide for how to install a good anti-virus program that is free forever.
http://www.fixya.com/support/r5317428-actually_free_antivirus_software_windows
If this doesn't speed things up please write back.
Jul 16, 2010 | eMachines T5274 Desktop PC
Emachine running SLOW and Freezes - 1 year old
Here are some suggestions: First of all . Do you have an anti virus installed on your husband's machine ? Viruses can slow the machine and even kill it permanently ( so be careful) . Just install an anti virus and you'll solve the problem . If you are already have an anti virus , then just run a full system scan and watch what will happen and follow the recommended steps that will be given by the anti virus [ There are a lot of anti virus softwares in the market ] but if you suspect that your system is already infected i recommend you to use (Avast professional edition) because it can make a boot scan , that means after you install it , it will ask you if you want to make a boot scan , just agree with it and it will reboot the system and start a boot time scanning , meanwhile you should watch it and give it the right orders if it detected a virus infection . Here is another suggestion : There is a certain software you could install it . This software can help your machine and detect any problem on your husband's computer but viruses . this software is called (TuneUp utilities) . You can download it from here www.tune-up.com . just try it and you'll be satisfied with result . if that didn't help just contact me again and i'll help you as possible as i can .
good luck .
Jan 29, 2010 | E-Machines eMachines Desktop PC
My laptop is slow and wont reboot
Put the Windows Op Sys CD in the drive and boot the system, Interrupt the boot process and go to the BIOS. Select the first boot up device to be the CD/DVD drive and then save the settings. Exit from BIOS and reboot the laptop. Windows should start from the CD. You will see an option to repair etc. Select the R Repair option and follow instructions. Once this has completed, and it may take some time depending on how full the HD is go to www.ashampoo.de and download the 30 day free trial application of Ashampoo and run this over your system to clean it up. Then run the defrag option in the MODULES tab - Optimise Performance Option- Defrag 3. Once completed your system will be cleaned and optimised. In order to make the performance even better - add additional RAM to the unit - you can never have too much and make sure that the HD has a minimum of 10% space remaining otherwise the laptop will slow down in operation.
Oct 13, 2009 | Computers & Internet
Emachine shuts off when Windows starts to load
what os are you running? if xp try booting to repair console and run "fixboot" and or "fixmbr".
Jul 15, 2009 | E-Machines Emachine T5026 power supply **...
Come on, boots up, then shuts down 5 - 10 minutes later.
check your power options make sure you don't have hibernation enabled, its in the system control panel. try booting from a linux live cd like Ubuntu which you can download for free. If it runs fine under linux, its a windows problem, if it keeps shutting down its a hardware problem. Could be bad ram, or CPU overheating.
May 09, 2009 | Computers & Internet
I have issues with my lap top (Dell inspiron) Vista operating system. It takes way to long to booth up. The internet takes forever to come up. The performance shows that most of the memory is being used up
hi,
if you have 2Gb+ memory and the issue is same there could be two problems,
1) could be a virus
2) it could be that you are running too many programs in the background
here is a helpfull link
http://windowshelp.microsoft.com/Windows/en-IN/help/83ec0ffe-ee04-4d53-8b87-25d1f05c954e1033.mspx
further queries are welcome
if you think my solution was helpfull pleased do rate me
Mar 23, 2009 | Dell Inspiron 1501 Notebook
Slow booting & low performance
It may be a disk related problem.Repartition may be useful on your hard drive.
Regards
ucp_pru
Jul 23, 2008 | Microsoft Windows 2000 Professional for PC
Emachine Wont Load Windows
Delena
problems like this is associated to RAM malfunctioning.
1.your RAM might not be sitting properly on the RAM slot,you will need to resit the RAM by opening the system unit and remove the Ram and resit it firmly.
2.if step one prove abortive,check the RAM for compatibility and the RAM health of such Ram.if it continue,
3.consider replacing the RAM with a known good one
Apr 24, 2008 | E-Machines eMachines Desktop PC
Inspiron 1150 Slow startup, slow printing, unable to run 2 programs at once
What Operating System do you run? If it is Windows XP SP2 (Home Edition or professional), here are some things you can do to speed up your system. 1st you should remove all programs that are not required from the start menu. Start > Run > Msconfig > startup tab. Unselect all that are not necessary. Also Right click on my computer > properties > Advanced > Performance settings > Adjust for best performance. This should speed things up a little. I would recommend atleast 512 MB of memory to run Windows XP and its applications decently. You should consider an upgrade.
Dec 20, 2007 | Dell Inspiron 1150 Notebook
E-Machines T1090 PC Desktop Logo
115 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
