Question about Levelone FCS-1010 Network Camera
Fcs 1010 update firmware
2 Suggested Answers
  • 20 Answers
SOURCE: how do i donload saftware fo fcs 1010
Here is the link to the download page for the FCS-1010 drivers. http://global.level1.com/downloads.php?modelstr1=FCS&modelstr2=1010&dlsearch.x=38&dlsearch.y=9
Posted on Oct 15, 2009
I need a driver for my internet camera fcs-0010
http://global.level1.com/WCS-0010/p-2457.htm
Go to section "downloads" and you will find firmware. drivers, manual and other stuff there
Mar 09, 2012 | Levelone Level One LevelOne CamCon...
What is latest firmware for UN19D4003
Don't do it. I made the mistake about 15 minutes ago and it downgraded the firmware. Now since the small set isn't wifi, I either wait for an email with a restore update or a tech will come to my home, I'm not sure. It didn't feel right upgrading to a lower number, but like you said, it was on the website...
Feb 26, 2012 | Samsung UN19D4003 TV
P0178
This is a failure code for a fuel composition sensor and man are they proud of these sensors. Last time I put one on the price for the sensor was almost 500.00. This does usually not cause a driveability problem. Here is a circuit description
Alcohol content and fuel temperature information is supplied to the powertrain control module (PCM) from the fuel composition sensor (FCS). The FCS has an ignition 1 circuit, a signal circuit, and a ground circuit. The FCS uses a microprocessor inside the sensor to measure the ethanol percentage and fuel temperature, and changes output signals accordingly. The signal circuit carries both the ethanol percentage, and the fuel temperature within the same signal. The signal is both variable frequency and variable pulse width. The frequency signal indicates the ethanol percentage, and the pulse width indicates fuel temperature. The PCM provides an internal pull up to 5 volts on the signal circuit, and the FCS pulls the 5 volts to ground in pulses. The normal range of operating frequency is between 50-150 Hz. The normal pulse width ranges between 1-5 milliseconds. If the PCM detects a signal less than 45 Hz DTC P0178 will set.
Your stall when put in gear is most likely due to a dirty throttle body (carbon build up). Remove the air intake tube to the throttle body & use a spray can of carb spray & a shop towel to clean the carbon from the throttle bore & plate.
Fuel Composition Sensor Replacement - Removal Procedure
Turn OFF the ignition.
Relieve the fuel pressure
Raise the vehicle.
Remove the fuel composition sensor fuel composition sensor (FCS) attachment nuts (1).
Disconnect the FCS inlet and outlet pipes from the FCS.
Disconnect the FCS electrical connector (1).
Remove the FCS and bracket assembly from the frame rail.
Remove the FCS bolts and remove from the bracket.
Installation Procedure
Install the FCS to the bracket and install bolts.
Tighten
Tighten bolts to 10 N·m (89 lb in).
Install FCS and bracket assembly to frame.
Install FCS bracket to frame nuts.
Tighten
Tighten nuts (1) to 17 N·m (13 lb ft).
Connect the FCS inlet and outlet pipes to the FCS.
Connect the FCS electrical connector (1).
Lower the vehicle.
Start the engine and check for fuel leaks.
Hope this helps.
Sep 02, 2011 | 2002 GMC Yukon XL
I'm using d-link dwl-3200 ap ( three) Received Frame FCS Error Counts indicate a problem? ___________________________________________ WLAN 802.11G Traffic Statistics Throughput Transmit...
Transmitted Error Count 4734440
Ack Rcv failure Count 15269951
  • As per the above there are error on Transmitting the packet and also for receiving the acknowledge packet.
  • Please check whether any disturbance in the link
  • Each PPP packet has a checksum attached to ensure that the data being received is the data being sent. If the FCS of an incoming packet is incorrect, the packet is dropped and the HDLC FCS count is increased.
  • Another reason for seeing too many FCS errors may be that the remote end has stopped talking PPP.
Feb 27, 2011 | D-Link AirPremier DWL-3200AP 802.11g/b...
Hi! Im just wondering for what use the (compact flash) memory card is, when installed in a Kyocera Mita FS-1010? (Beside firmware updates)
Found this in a manual.
Insert the memory (CF) card into the card slot located on the rear of the printer. A memory card is a microchip card that may contain option fonts, macros, forms, etc. The printer reads the contents of the card into its internal memory when printer is turned on. The presence of this data in the printer memory can be confirmed on the status page printout. For details of available memory cards, contact your Kyocera Mita dealer.
1 Turn off the printer. Never insert or remove a memory card while the printer power is on. Failure to turn the power switch off will immediately halt the printer with the four indicators turned on. It also could result in damage to the printer’s electronic parts or the memory card. Turn the power switch on again to restart the printer.
The only thing I have seen it used for (other than firmware) is to store certain info or fonts for forms (ex. tax paperwork or medical).
Hope this helps.
Jul 04, 2010 | Kyocera Mita FS 1010 Laser Printer
I need a driver for hp laserjet 1010 printer
click on the link and select os to download it
DOWNLOAD
Sep 01, 2009 | HP LaserJet 1010 Printer
Instructions to replace fuel composition sensor
  1. Turn OFF the ignition.
  2. Relieve the fuel pressure
  3. Remove the fuel composition sensor FCS attachment nut.
  4. Remove the 2 FCS attachment bolts.
  5. Remove the FCS from the frame rail.
  6. Disconnect the FCS inlet and outlet pipes from the FCS.
  7. Disconnect the FCS electrical connector.
  1. Connect the FCS inlet and outlet pipes to the FCS.
  2. Connect the FCS electrical connector.
  3. Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  4. Install the attaching nut.
  5. Tighten
    Tighten the nut to 17 N·m (12.5 lb ft)
  6. Install the 2 FCS attachment bolts.
  7. Tighten
    Tighten the bolts to 17 N·m (12.5 lb ft)
Jun 27, 2009 | 2005 Chevrolet Avalanche
Levelone FCS-1010 Network Camera Logo
37 people viewed this question
Top Levelone Computers & Internet Experts
micky dee
Prashant M
Prashant M
Are you a Levelone Computer and Internet Expert? Answer questions, earn points and help others
