Question about Crock Pots & Slow Cookers
Prolex multi cooker
Bought this from B&M. No manual to explain what can be cooked on what settings. Only a description on how to put the item together & how to wash. Would be grateful if anyone has bought this item and could shred some light on it.
I'm sorry I don't have a solution, but having the same problem and wondered if you'd found answers? On the pitiful information it does give, it mentions a 'keep warm' setting, and an 'off' setting, mine doesn't have either! Just 0-5! 0 seems to switch it off, and 1 burns everything! Having a nightmare, and REALLY wanted the stupid thing to work.
Thanks in advance
Posted on Jun 19, 2013
Hi I bought a Prolex crock pot/slow cooker today and when I opened the box and took it out , there is a big bolt sticking out of the bottom which protrudes farther out than the legs which makes it wobble . I'm not sure what to do with it , do I take it back or just use it. I had another one but it was too big for us so I gave it to a friend it was a Judge 5.5 ltr . It didn't have a bolt protruding from the bottom of the outside of it . Does anyone have any suggestions what I should do (take it back or what ???? Thanks
Posted on Nov 08, 2013
5 Suggested Answers
pgh_pa_guy
  • 2992 Answers
SOURCE: cooking time
Here is a link to the manufacturer for replacement parts for the 4-quart cooker:
http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=802&secid=54&linkon=category&linkid=101
You can download the instructions from this page.
Posted on Nov 27, 2008
SOURCE: royal doulton multi cooker
not a solution as such but u can use it as a slow cooker on low
put it on put veg in add water then meat leave about 1 inch gap from lid and put on low for a few hours dont let it boil dry
Posted on Jan 13, 2009
  • 86 Answers
SOURCE: need cooking manual for hamilton bch 6qt prog slow cooker-
Please click the below link with leads to the download page for this manufacturer. You will need to select your exact model via the dropdown and then click "submit"
Posted on Mar 27, 2009
SOURCE: I just bought an Imusa pressure cooker at Targets. No manual
I'm not too impressed with your answer (buy a plan that will surely help
me) You didn't even address the question I asked or direct me to a
different site. Forget I asked. pleighton@rivah.net
Posted on Aug 26, 2009
Della 12 Quart 1600-Watt Electric Pressure Cooker Multi-Functional Timer Slow Cook XL Part number: 048-GM-48261 Unable to get this cooker to slow cook.
it is possible that you have misunderstood the instructions
for a slow cooker you have low medium and high
press slow cook and on low and in 8 hours the food is cooked
I see from your statements that you expect the cooker to be set on slow cook but cook at a high temperature fast
if it says slow cook --9 hours and the temp is 125 degrees , have you waited 9 hours to see if it is cooked as the slow cooking process is by the gradual build up of heat in the container that is not expelled by radiation to the air
in a pressure cooker , that build up of heat also builds up pressure and so it cooks better
other solution--- if it is not right return it for a warranty refund or if out of warranty , junk it and get a different make
Mar 25, 2017 | Crock Pots & Slow Cookers
Where can i find a manual for ultrex pressure cooker?
The company had a major recall and went out of business. No manuals appear to be available on the web.
Here are some general instructions you can use:
1 Set up your cooker. Place your Ultrex Pressure Cooker on the stove. Remove the lid and pour in no more than 2 inches of water. Depending on what you are cooking the amount of water will vary. More water will ultimately cook larger amounts of food, but you will need to refer to your specific model's instructions on this matter.
  • 2 Put in the food you wish to cook. Close and lock the lid firm to the pot. Make sure it is locked securely so none of contents boil out of the top.
  • 3 Turn on your burner to high heat for approximately ten minutes. Allow the water to boil.
  • 4 Turn the stove down to a low setting after the water is boiling in the cooker. Flip the pressure valve closed and allow your food to simmer.
  • Set the pressure valve to ten pounds. For vegetables, cook 30 to 45 minutes. For meats, cook 45 to 60 minutes.5
  • 6 Open the pressure valve and allow the pressure to discharge. Unlock and remove the lid to find your fully cooked meal.
  • Aug 25, 2014 | Ultrex Crock Pots & Slow Cookers
    How to use the slow cooker on the oval cooks essential pressure cooker
    I have a Tricity TSC09 6 litre Slow Cooker and I just love it its so handy, if your gone for even 10 hours it keeps your dinner warm after the cooking time runs out. I smashed the lid and was so gutted I tried for hours online to find a replacement lid with no luck. I went shopping and bought a very cheap 6 to 7 Quart or 6 to 6.5 litre Slow cooker / Crock pot of the same shape the removable pot and lid fit. I bought a cookworks, signature, 24 euro 6.5 litre oval dog standard slow cooker and the lid fit, now I also have a removable pot replacement as well just in case I smash that too. So happy I have my Slow cooker back again.
    Dec 05, 2013 | Deni Cooks Essentials 5qt Oval Pressure...
    Slow cooker will only stay on warm. How do I put
    This slow cooker has 3 settings LOW, HIGH, & WARM
    When you plug the slow cooker in the display should show a "0". When you press the "COOK TIME" button, the display should go to 1 then 2 then 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the "HIGH" setting. If 7,8,9, or 10 hours are selected, then the slow cooker will operate on the "LOW" setting. To start the cooking cycle press the "ON/OFF" button. To interrupt the cooking cycle at any time, press the "ON/OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the "WARM" setting. If the "ON/OFF" button is pressed when the the digital display shows "0", then the slow cooker will automatically start on the "WARM" setting.
    If the "COOK TIME" button does not change the display numbers then unplug the slow cooker and hold both buttons down as you plug the slow cooker in. Keep the buttons pressed for a count of ten, then release them and the slow cooker should work correctly
    Feb 11, 2010 | CorningWare SC60 Slow Cooker
    Need a manual for the corningware sc60
    The manual basically says... This slow cooker has 3 settings LOW, HIGH, and WARM. W hen you plug the slow cooker in the display shows "0". When you press the "COOK TIME" button, the display should go from 0 to 1 to 2 to 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the HIGH setting. If 7,8,9,or 10 hours are selected, the slow cooker will operate on the LOW setting. To start the cooking cycle, press the "ON/OFF" button. To interrupt the cooking cycle at any tim, press the "ON?OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the WARM setting. If the "ON/OFF" button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
    If the "COOK TIME" button does not change the display numbers, unplug the slow cooker. Hold down both buttons and plug the slow cooker in and keep them pressed down for a count of 10. Release the buttons and the slow cooker should work now.
    Nov 28, 2009 | CorningWare SC60 Slow Cooker
    Technique multi- cooker model #cetgsc6 manual.
    MAKING STUFFED PEPPERS WHAT SHOULD I SET IT AT AND HOW LONG SHOULD I COOK THEM?
    Oct 14, 2009 | Crock Pots & Slow Cookers
    Need to replace the glass lid on my West Bend Cook & Tote model 84706. &/or need a parts & service center in the Houston Tx area
    You can find replacement parts from the WestBend site http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=2704&linkon=category&linkid=70&secid=54
    There are links for replacement parts on the bottom of each item description. This may not be your exact model but may help.
    Nov 11, 2008 | West Bend 84496 6-Quart Slow Cooker
    Royal doulton multi cooker
    Oct 15, 2008 | Crock Pots & Slow Cookers
    Rival SCV655 Slow cooker
    There are three settings.
    The third - as found on a new products description:
    Product Description:
    6.5 litre capacity,ideal for to up to 6 people,Removable and dishwasher safe stoneware for easy cleaning,Mlicrowave and oven safe stoneware pot,Dishwasher safe glass lid,2 cook settings,Keep warm function,Recipes included,Brushed chrome finish
    - Its a keep warm setting.
    Kind regards,
    Nicholas
    Sep 27, 2008 | Crock Pots & Slow Cookers
    On my durabrand slow cooker
    The auto mode means that the cooker will start off at high and then will switch to low after an alloted amount of time.
    Nov 17, 2007 | Select Brands SC-25 2.5-Quart
    Crock Pots & Slow Cookers Logo
    2,100 people viewed this question
    Top Crock Pots & Slow Cookers Experts
    tsalagi152
    charles
    Irene Tulloch
    Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
