Question about AEG 23 in. Favorit 50750Vi Built-in Dishwasher
Dishwasher keeps cutting out
My Dishwasher keeps tripping the electric halfway through a cycle
  • 258 Answers
Has the door got heavier recently?
Mine had a spring break which fell onto the electrics and shorted them. Unplug and empty it, then tip it up to see if you can see a loose spring. If it is then replace or re-fit the old spring, I have posted instructions and pictures here:
http://www.howtofixanything.co.uk/howto-260.html
Posted on Jan 30, 2009
Westinghouse dishwasher sb916sk runs 22 minutes then cuts power
Is it on a dedicated circut? A dishwasher needs to have a 12Ga two conductor with ground line that is dedicated to ONLY the dishwasher and possibly share with the garbage disposal.
Also, it should be on a 20 Amp breaker.
Mar 11, 2014 | Westinghouse Dishwashers
Hoover HD73M dishwasher keeps tripping the circuit breaker
Have condensation in the electrical connector .It is grounding .Call an electrician to repair ground and short circuit.
May 10, 2012 | Hoover 24 in. HD73M Free-standing...
Power is connected but dishwasher will not start
Make sure (with and electric field tester/2-prong tester/DMM/VOM) that there's 120VAC to your
dishwasher. You can also check the circuit breaker - it may be OFF or TRIPPED.
Its easy to see when a breaker is OFF, but harder to see a TRIPPED breaker - the toggle
stops halfway between ON and OFF when a breaker trips, and its easy to miss in the dim
light of a typical garage or basement (this electrician knows from experience). To reset
a TRIPPED breaker, you must throw the toggle
switch to OFF, then reset it by throwing the toggle to ON.
If your residence has a fuse panel, check you fuse and consider buying a reset-able screw-in
replacement from your local electrical supply.
Feb 20, 2011 | KitchenAid Dishwashers
Hi my dishwasher keeps tripping the electrics. it's always the same place in the cycle. there doesn't appear to be anything blocking the filter. there's always water in the bottom after a trip and the...
Hello there, If this unit is tripping the breaker lets say on the pump out drain cycle, then you for sure have a problem in the motor and pump assembly.Anytime a breaker trips, if the breaker isn't worn out, it indicates that it is drawing more amps than it is rated for due to an overload problem and so on.You're motor and pump needs to be checked out on site with the proper electrical tools and so on. Wish I were there to help.
Good Luck, Shastalaker7
Nov 05, 2009 | Dishwashers
AEG Favourit 446
Our AEG dishie also tripped the light regularly. Turned out there was a water leak by the motors and the cut off device wasn't working and when the water filled up too much it tripped. Move the dishie and if water 'sloshes' out the back, then you know the problem, or if not, take the side panels off so you can see underneath, if there is water at the bottom of the machine. Hope you find the problem.
Aug 11, 2008 | AEG 24 in. Favorit 40310 Free-standing...
My dishwasher when switched on keeps throwing the trip switch
i had this probem and apparently there's a 'float switch' in the bottom of the machine. This switch is a safety cut off and when activated can not just stop the machine but trip the electrics in the house. the reason for it activating is when food clogs up the drainage bit water can not drain and fills up the bottom of the machine. this then activates the 'float switch' as a kind of safety cut off.
the way to sort it is to disconect the machine from the mains and drain and water. empty the clogged up food from the drain bit. then tip the machine back and a load of water will pour out (may need a load of towels for this bit or take the machine out the back and do it)
once this is done, plug it all back in and give it a try - works for my machine, good luck.
Oct 09, 2007 | Indesit 24 in. D63 Free-standing...
Dishwasher keeps throwing circuit breaker halfway thru cylce
Most likely cause is a minor leak shorting acroos the wires, check in base for water stains. Regards Advisor
Aug 31, 2007 | Maytag 24 in. MD5600 Jetclean II Built-in...
Dishwasher trips RCD electrics
fault is probably heating element but you need a megga to test it. other disconnect element, tape up wires then check on wash cycle. be carefull!!
Mar 20, 2007 | Electrolux 23 in. ESL624 Built-in...
AEG 23 in. Favorit 50750Vi Built-in Dishwasher Logo
917 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
