Question about HP OfficeJet 4255 All-In-One InkJet Printer
Error oxfoaf8005 blinking light
I have a Panasonic TC-P65ST50 which recently began shutting down and displaying 7 blinking lights and 8 blinking lights. Most of the time 7 blinking lights are displayed.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Feb 25, 2016 | Panasonic TC P65ST50 - 65" Class 64.7"...
Whirlpool dishwasher model# gu2200xtss3 normal light flasing all the time turning power off does not help in a few minutes back on flashing
The light blinking is an error code--usually it will blink a certain number of times, pause, then blink another sequence(ex. 4 times, then 3 times)in a binary error code. There is a chart in the service manual to decipher the code(s) and locate the issue. It could be anything from a heater circuit failure to the drain pump being jammed. Try to see how many times the light blinks, and which ones blink--there could be, on the first part of the sequence, normal light, then, 2 or 3 lights blink-- I need to know which ones are lit. Thanks! You can try to look up the light combinations on the net with a search for your model number and error codes.
Oct 12, 2015 | Whirlpool Dishwashers
Turn on power hear it come on then turns it self off and power light starts blinking
Blinking light may be a error code----look closely and see if blinks in a sequence---3 blinks, pause 3 blinks or 5,5.
The blinking light means set is in protective shutdown, Do you see a sequence to the blinks?
I am here to help.
If needed, unplug set and plug it back in and try to turn on---watch for likely error code.
SD TECH
Sep 17, 2010 | Panasonic PT-56HX41 56" Rear Projection...
My both red light is blinking continuously what i do help me
both light are blinking at the same time or blinking alternatively ?
if both blinking same time, it's a fatal error.. means it could be something wrong with the carriage or board or encoder belt...
if the light blink alternatively, it means the waste ink counter need to be reset and ink pad need to be replaced.
May 26, 2010 | Epson Stylus Photo R200 InkJet Printer
The error light came on and I don't know whats wrong
What is the error light
Step one: Identify the specific printing problemIf your All-in-One won't print, first you need to identify the specific issue or symptom. What exactly happens when you try to print? Do you see an error message or do the lights on the printer start blinking (flashing)? Does nothing happen at all? Follow these steps to identify your unique printing issue before troubleshooting. If you can identify a symptom based one of these methods, make a note of the symptom, and then continue to the next step. Method one: Look for blinking lightsLook for any blinking lights on the front or top of the All-in-One. Sometimes just the power button can blink, or a small indicator light on the printer can blink, or a combination of buttons can blink all at once. Example indicator lights on the printer Attention lights Wireless indicator light Cartridge lights Error Lights c01890693.gif c01890694.gif c01890695.gif c01890697.gif c01890698.gif c01890699.gif c01890700.gif c01890701.gif Example blinking lights patterns
c01890702.gif Method two: Look for error messagesPrinting problems are usually accompanied by an error message of some sort, usually on the control panel display (if your All-in-One has one), or on your computer monitor. Check both places for specific error messages. Error messages might or might not be accompanied by an icon representing the error. Following are some examples of error messages you might see on your computer screen or control panel display.
  • c01890703.gif 'Printer is Offline '
  • c01890704.gif 'Align Cartridges '
  • c01890705.gif 'E ' (error condition)
  • c01890706.gif 'Document(s) pending ' (Roll your mouse over the product icon in the lower-right corner of the computer screen.)
Jan 16, 2010 | HP DeskJet F380 All-In-One Printer
Error Message & blinking lights
Jul 21, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Kyocera FS-1020D lights blinking but doesn't respond
Fuser error (6000 error)
Contact your Kyocera Mita dealer.
Unfortunatly there is not much You could do Yourself
This error means that the fuser is either damaged or not connected properly to the rest of the printer. If its connection error You could try to fix it but in most cacses the fuser is just broken ie. overheated due to not enough air flow.
May 28, 2009 | Kyocera Mita FS-1020D Laser Printer
Error:Oxfoaf8005
Try to unplug and plug your printer..in this way you will reset all the settings of your printer...
if the still exist:
uninstall and reinstall printer driver.
May 13, 2009 | HP OfficeJet 4255 All-In-One InkJet...
Konica Minolta 2400W Magicolor. Error light blinking
Ready indicator Error indicator Condition Action
Green Orange
Blinking Blinking Communication Check The Printer
error cable
____________________________
Print over-run Turn off the printer.
After a few seconds
turn on the printer
change to a lower
resolution.
________________________________________________________
This may help if not...let me know........Whytfang
Mar 25, 2009 | Konica Minolta magicolor 2400 Laser...
HP OfficeJet 4255 All-In-One InkJet Printer Logo
26 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
