Question about Home Security
I forgot my password for DVR model LTD7704HT from LT Security Inc.
Please give me an advise how to reset to factory password :(
ginko
  • 19396 Answers
SOURCE: security code for nec lt 260
The procedure is the same for LT220, LT240 and LT260.
Here is the user manual
LT260/LT240/LT220 User’s Manual
Posted on Sep 09, 2008
  • 7 Answers
SOURCE: I forgot my password and I cannot do anything.
Factory Reset Hidden Key :Mode Key + CH 2
The Password and all setting value will return to the initial default value.
Default Password is ‘4321’., Refer to 6-10p, 6-12p of User manual
I hope this helps.
Posted on Jul 09, 2009
  • 10 Answers
SOURCE: I have an Eyemax DVR 9120. I forgot the admin
c:\windows\dvr2 i think is the file that saves the password
Posted on Apr 08, 2010
SDsherm
  • 14 Answers
SOURCE: need to reset my intermatic inc security alarm
It is very simple to reset your Intermatic SP130.<br /> <br /> 1: Remove SP130 from the wall/door by lifting upwards about 1/4 inch.<br /> 2: Remove the battery cover and one (1) battery.<br /> 3: Decide on a four (4) digit code. You must enter your desired code within 5 seconds of reinstalling the battery.<br /> 4: Reinstall battery and immedately enter your desired 4 digit code.<br /> 5: Reinstall battery cover and remount to wall/door<!-- from fixya rte -->
Posted on Aug 13, 2010
Sebin
  • 712 Answers
SOURCE: I forgot the password for my Defender Sentinel1
It can be reset only by the company and not others. Contact the care center to reset the password.
Posted on Oct 08, 2010
How to reset my pass word on my Samsung Security Video System SDH-B74041
For nearly all Samsung Security DVRs, the default password is 4321. If it hasn't been changed since setup, then you can just use that to access the DVR. The default password is included in the reset procedures for completeness. If you have changed your password or access code for your Samsung Security DVR since it was setup, or if you changed it during the initial setup, use that password in place of the default password. The password will be the latest password that was set on the DVR. If no password has ever been set, then it will be the default.
Samsung Security DVR Reset Procedure #1
  1. Reset the unit to factory by pressing both [MODE] and [PTZ] button for 5 seconds
  2. Then enter the 4321.
Samsung Security DVR Reset Procedure #2
  1. Reset the unit to factory by pressing both [MODE] and [CH2] button for 5 seconds
Samsung Security DVR Reset Procedure #3 This reset will work on Android based DVRs only. All steps are performed on the device itself.
  1. Turn the device Off
    Wait 2 minutes
    Press and hold the following buttons
    • POWER,
    • HOME
    • VOLUME UP
  2. The unit should power on. Once it does, you can release power.
  3. Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
  4. Activate the reset using the HOME button.
    When the DVR goes through it's setup again, it will be at factory defaults. The password will be 4321.
Samsung Security DVR Reset Procedure #4 This reset will work on SDR models. It may also work on other models.
  1. With just the cameras showing, press the following in quick succession using the remote:
    • Freeze
    • Alarm
    • Freeze
    • Alarm
    • Freeze
    • Menu
    • Enter
  2. Make sure you press them quickly, one after the other. If it doesn't work the first time, try doing it several times. It can take many tries to get the timing right. If/when it works, you should get a screen that gives you the option to reset.
Samsung Security DVR Reset Procedure #5 This reset will work on SDR models where procedure #4 failed. It may also work on other models.
  1. Press the DVR Button to place the system in DVR Mode
  2. Press:
    • Freeze
    • View
    • Return
As with Procedure #4, you may need to press Freeze, View, and Return in in quick succession a few times to get it to work. The timing can be tricky.
These reset procedures cover many Samsung Security DVRs, but not all. I will add reset procedures to this article as they become available to me. By design, Security DVRs are made to be secure, and not all of them can be reset by the consumer. If you have an urgent need related to your Samsung Security DVR, you should contact Samsung directly at their support page Samsung Support, or by calling: 877-349-3149. For less urgent matters, you can email them directly at Email Samsung Support. Support is available 7 days a week, 9:00 am - 9:00 pm EST.
Jan 08, 2017 | Samsung Home Security
Sentient DVR, model el821. How can I factory reset?
find the on board battery in the DVR remove it for 10 sec and plug it back this gonna reset your setting
Mar 31, 2016 | Home Security
I forgot my username and password
Every router I have ever seen allows you to reset the configuration to factory default - but not allow you to retrieve a forgotten password and maintain your settings at the same time. This is often referred to a "factory" or "hard" reset.
When you initiate a factory / hard reset, typically by pressing & holding a button on the router - or behind an opening in the router case - all the changes you've made to it will be returned to the factory default. Wifi becomes "open" with no password (on most devices), the login username / password also go back to default settings (common ones are: admin / admin, admin / password, <blank> / admin, <blank / password, etc.). Consult your router's set up guide or online documentation to learn what the factory / hard reset procedure and the default settings.
Once you gain access to the setup pages of the router, configure it as best as you can remember, and lock it down with good security settings. At minimum - this should include changing the router's username / password, the WiFi's SSID and do not broadcast it, add WPA or WPA2 encryption and secure it with a security key (use a mix of numbers, letters, symbols etc.).
I suggest recording the settings on paper and then tape it to the bottom of the router. There it will remain out of sight - but ready when you need it.
Oct 17, 2014 | Computers & Internet
Qihan dvr super password
Forget the DVR password, how to generate a new one with software ...
www.hkvstar.com/.../forget-the-dvr-password-how-to-generate-a-new-one-with-softw...
Nov 4, 2013 - If you forget the DVR password, you can use the password generation software to get a new super admin to unlock the DVR.
Reset DVR password to Factory default - • CCTV Forum
www.cctvforum.com/viewtopic.php?t=39460
Jan 26, 2014 - 15 posts - ‎4 authors
I have a DVR shown below and I am not able to reset the system to the factory default. It is an 8 ch standalone, unbranded, no make or model ...
How to - Zmodo DVR Resetting to Factory Defaults - YouTube
? 0:46
https://www.youtube.com/watch?v=rT-cUgWbHQM
Sep 24, 2009 - Uploaded by CCTVHotDeals
This video shows how to reset your DVR to factory defaults. ... Reset PasswordDVR H.264,AHD, With Super ...
CCTV H264 DVR password reset superpassword super password ...
https://dashcamtalk.com > Home > Forums > General Forum > Off Topic
Jan 2, 2015 - 12 posts - ‎7 authors
I was searching on internet for this problem because I set the password one year ago, I forget it and I want to reset the password. I have a ...
How to reset password ?
support.qube.asia/127247-How-to-reset-password-
STEP 2- Open the cover of the DVR. STEP 3- Remove the CMOS battery. STEP 4- Power On the DVR. STEP 5- Enter a password. Username: As given.
[PDF]Qihan NVR manual
www.riasztobolt.hu/pictures/down/en_tmanual_quihannvr.pdf
Support modifying the user's authority and password. Subdivide the authorities (preview, ... DVR: Digital Video Recorder. IPC: IP Camera. IP PTZ: Network High ...
Aug 13, 2014 | Home Security
AlienEko 308 DVR forgotten passwords.
Here is the operations manual. I believe section 12.7 gives instructions on how to reset to factory defaults.
http://www.lymebayalarms.co.uk/?wpdmact=process&did=OS5ob3RsaW5r
Jan 12, 2014 | FPS 4 Channel Standalone DVR system,...
How do you reset the admin password on a truvision dvr 30 16 channel.
how do i reset admin password on a truevision dvr.
I have changed it and i forgot it
Jun 29, 2011 | GE Security Kalatel TVR3008500 TruVision...
I forgot my password and I cannot do anything. What is the solution? SHR-1040 DVR security system.
I hope this helps.
Jul 09, 2009 | Samsung SHR-2042 4 Channel Stand Alone Dvr...
Forgot my security password
do *2767*2878# this will reset it back to the default.
Feb 07, 2008 | Cell Phones
Home Security Logo
107 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
