Question about Kenmore 22422 Top Load Washer
Washer stops suddenly and water isn't drained out
Dear, I have a Kenmore washer- model 110- 10 years old. After I start the washer, I see water is filling and then the washer agitator is spinning , but after several minutes the washer stops doing anything. Therefore, there are my clothes immersing in a whole bunch of water which is not drained out. It never continue... doing the rest of its work. Thank you very much
  • puissantone Nov 10, 2008
    I came out and the basket was full of water and the washer was buzzing. I tried advancing the the external knob but that didn't help. My family used to be in the launderette biz so I know a little bit about adavancing the timer if it's similar to Maytag. Someone thought it was the belt. I like the timer idea better
  • 12 Answers
Hi tieuvodanh; Sounds like the timer has gone out. If you can advance the selector dial manualy, and the machine continues to operate as it should, then this is the problem. Replacing the timer will require some advanced knowledge of washers and the ability to use a box of hand tools. A good handy man will be able to repair this for you. Best regards; HELP2DIY Please don't forget to rate my answer.
Posted on Jul 10, 2007
I have a Kenmore washer model #110.20022011. The other day it did not spin out all the way, now it will not start at all. The fill light and lid lock light comes on, but it does not start. Water and...
A friend of mine bought a Kenmore washer model 110.20022013 a year ago. Now washer stopped in the middle of washing and a clicking sound starts, and not washing or rinse or draining
Aug 22, 2011 | Kenmore Washing Machines
Front loading washer won't spin
my amana washer wont spin and does not drain
Sep 11, 2009 | Kenmore Washing Machines
10 year old model kenmore top load washing maching won't fill.
That means that eithere the membrane water lever switch is faulty (most common) or that the drain pump solenoid is stuck on open.
Dec 21, 2008 | Kenmore 24032\24036 Top Load Washer
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Broken Washer
it could be the direct drive coupling that connects the motor to the transmission. fill it up with water and see if it will agitate, if it will NOT agitate then it is a good chance that this is the problem. 0404472.jpg
worse case scenario is the transmission is bad, but this is unlikely.
Aug 04, 2008 | Kenmore 25862 Top Load Washer
Kenmore 90 washer won't drain
ckd pump traps for debris on kenmore remove front panel on samsung i think a rear approach is best
Jun 03, 2008 | Samsung WF337AA Front Load Washer
Washer not spinning
check the sensor switch located underneath the the top washer where the door closes , make sure contacts are clean (or align for magnetic SWITCH)
May 05, 2008 | Kenmore 3.5 cu. ft. Front Load Electric...
Washer fills/agitates and stops prior to draining
If pump works fine or still pumps out water, then it is a timer malfunction. Replace the timer and you should be fine. To locate a part number for your timer, refer to www3.sears.com with the model number off your washer.
Mar 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 22422 Top Load Washer Logo
152 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
