Question about Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum
Kenmore progressive/direct drive-- roller stopped turning
It was working then abrutly stopped. i changed the bag and hit the reset button but it won't pick up, I have suction when I check the hose..
  • 2 more comments
  • lillyambar Jan 24, 2009
    Thanks, I did all that and it still won't move.
  • lillyambar Jan 25, 2009
    The roller brush doesn't move. It has no belt and I checked everything else so I just don't know what else to do.
  • lillyambar Jan 26, 2009
    i'VE
    I've tried the reset button several times still no luck. the roller still won't work. It's free of any debree. I do have suction in the hose!!
We have the same vacuum & had the same problem. As the vacuum ages & the hose is periodically removed from the nozzle to use with the attachments, the white switch, adjacent to the nozzle connection, wears. If the hose is not fully reinserted or if the attachment notches are inadvertently aligned with the white stitch, the agitator may not work reliably. Assuring the hose is fully inserted, with the locking notches away from the switch has eliminated this problem with our vacuum cleaner.
Posted on Mar 26, 2009
    President:
  • 1,214 Answers
Look in the throat of the bottom head for an obstruction. Either looking into the hole that the suction hose attached, or by removing the bottom plate and looking up inside.
Posted on Jan 24, 2009
  • 1 more comment
  • Mark Egan Jan 24, 2009
    What does not move? You indicated in your OP that it would'nt pick up.
  • Mark Egan Jan 26, 2009
    There is an agitator reset button on the left hand side (as your standing at the vacuum holding the handle as though you were vacuuming.). Pressing that should get the agitator running again.
    Next issue, I assume, is suction. Do you have suction of dirt and dust from the floor after getting the agitator working?
    If the roller turns freely, and you've reset the reset at the front left (as opposed to what looks to be a motor reset on the back), then either there is a broken wire, or the agitator motor has failed.
My purple proggesive kenmore upright motor works but beater not beating help thank you
I just had the same problem - reset button didn't trip - cleaned the roller - ultimately found there is an override switch at the point where the hose attaches to the base of the vacuum - it disables the roller when you use the attachments. The hose had become loose (but not disconnected) enough to trip the switch. An easy fix after alot of tinkering... p.s. All those "experts" that said to change a belt obviously don't understand that this model is beltless...
Nov 09, 2009 | Kenmore 31913 Progressive Direct Drive...
My roller do not spin
There is also a circuit protector which trips if something gets caught in the roller, so that might be the problem. There is a very small red button on the right side at the bottom of the vacuum (IT'S VERY TINY), and you just push that in and it will reset the circuit.
Aug 22, 2009 | Kenmore 31913 Progressive Direct Drive...
Vacuum roller stops turning
with cleaner plugged in and turned on, push the little reset button on the side of the lower base of vac. Remember that the brush will not turn in the upright position. release your handle and you should be in business. hope this helps. please let us know. thanks renevacdoc
Jul 22, 2009 | Kenmore 31913 Progressive Direct Drive...
Motor on our kenmore progressive agitator is not
Look for a reset button on the motor and press it in. If it clicks, then it was tripped. An excessive load on the motor can make the reset trip. Try turning the motor shaft to make sure that it is not bound up. Run the machine empty for a short time to see if it works. Good luck!
Jul 16, 2009 | Kenmore 31913 Progressive Direct Drive...
Vacuum roller will not spin. Reset button does not workl
The warranty should cover you for a year unless something you inadvertently sucked up caused a jam, whihc you may be able to determine or fix yourself. See if the agitator is easy to turn - if not, something is probably jamming it; if it turns in one direction, but not the other, something may be wrapped around it. If it turns easily, it's possible the motor either died early due to a defect or a broken wire.
Jul 03, 2009 | Kenmore 31913 Progressive Direct Drive...
Kenmore 31913 Upright
same problem.... roller won't turn, nothing stuck in it.... no solutions?
Jun 20, 2008 | Kenmore 31913 Progressive Direct Drive...
Kenmore Progressive 100
Check the brush roll ends, make sure they turn freely, if not then replace it. The belt may look ok, but they stretch after a short time and should be replaced.
Mar 24, 2008 | Kenmore 31912 Progressive Direct Drive...
Carpet function rollers don't turn
Most likely a broken belt. If the brush roll is turning freely, then check the belt.
Mar 02, 2008 | Kenmore 25812 / 25813 Progressive Bagged...
Kenmore direct drive will no longer self-propell
There may also be a reset button. If the brushes get stuck the unit can shut off power to the brushes to keep a total melt down from occurring. The reset button should return power in these types of vacuums.
Aug 17, 2007 | Kenmore 31913 Progressive Direct Drive...
Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum Logo
801 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
