Question about Max-Fridge Refrigerators
Chill max fridges
Doesn't seem to be chilling to the right temperature
  • 9 Answers
SOURCE: Amana refrigerator will not chill
That model number does not come up for me.
Click on and enter model number
http://www.searspartsdirect.com/partsdirect/index.action
Posted on Jan 10, 2009
miket756
  • 2702 Answers
SOURCE: the freezer is not working, doesn't chill any
could be the compresor not working,,
the thermostat has given up,,
or it needs a regas,,
what ever it needs a repair man to fix it up for you,,
sorry,,,,
Posted on Oct 27, 2009
  • 324 Answers
SOURCE: I have a Frigidaire wine fridge and it is running
please check the fan motor weather its working perfect or not
Posted on Jan 10, 2010
  • 117 Answers
SOURCE: Hi my Samsung fridge freezer
some good stuff on youtube re
samsung fridge freezer help
also samsung diy video help
Posted on Oct 19, 2010
SOURCE: My Miele fridge freezer KFN8762SDED
Hi Jean, Sorry I have no solution - but have an identical issue with my Miele fridge freezer... - In case you have managed to find a solution, I would be grateful if you could let me know what it is, to save me from running around... ?? Best wishes in any case, Guy
Posted on Feb 15, 2011
GE monogram refrigerator too cold
There is a balance between the freezer and fridge. Reduce the freezer temp and see what the fridge temp does. By reduce I
mean make the freezer warmer. If it is set too cold the fridge gets colder.
Nov 25, 2013 | GE Monogram ZISS480DRSS Stainless Steel
CHILL ZONE IN DODGE CALIBER NOT WORKING
There is a small plastic cover on the roof of the "chill zone"....if you pull it towards yourself it allows a small amount of a/c to flow into that small compartment inside the glove box......keeping it "chill"......as long as the a/c is on.....oh, and the vent is open :) It's cool.....I've had my 07 caliber since 07 and just now found that vent myself.
Jun 08, 2012 | 2007 Dodge Caliber SXT Sport Hatchback
I have a k-tel quick chill ice cream maker but have no recipe book. I'm interested in simple vanilla or the simple recipes thankyou!
I was reading on a Fixya post about K-tel Quick Chill from around 3 years ago. They were stating that they called K-tel and the instruction manual/recipe book was emailed right out to them. I don't know if it is still true for today. Here is the contact information for that they seemed to get good results from:
http://www.ktel.com/contact.php
Hope this helps
Aug 11, 2011 | K-Tel Quick Chill Ice Cream Maker
The lower part of my samsung cooltech fridge is freezing all food.
Hi nalin, sounds like you may have a problem with with your defrost timer. Defrost timers can fail due to wear and tear. If this happens during the cooling mode, it will allow excessive frost to accumulate on the cooling coils causing the refridgeration compartment to over shoot its chilling operation in turn causing everything to freeze. Best bet would be to call up a local Appliance Service Technician while the fridge is still manageable so you save on time and money. Also it wouldnt be a bad idea checking the thermostat rotational knob on the rear inner wall of the fridge (if there is one) just to make sure that the machine isnt fully dialed to max chill, hope this helps.
May 01, 2011 | Samsung Refrigerators
My Miele fridge freezer KFN8762SDED has a problem in the fridge section. The temperature varies between 4 and 13 degrees. If I put on the super chill the temp comes down to normal, 4 degrees only to rise...
Jan 12, 2011 | Miele KFN8762SDED Bottom Freezer...
Water dispenser does not dispence water
need to replace the water inlet valve. the part number for this model is 4389178
Jun 18, 2010 | KitchenAid Superba KSRG25FK Side by Side...
I have a samsung side by side fridge, and the fridge side is not staying cool, but the chill drawers are keeping the right temp??? The Model# is RS267LABP
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
The chill drawers are probably staying cold because there is a vent to the freezer in the wall for the cold air to seep through.
Nov 03, 2009 | Coffee Makers & Espresso Machines
MY Bosch Refrigerator (KGU3420GB) does not seem to chill the top fridge compartment but the freezer seems ok(-18). Any suggestions as to what might be the problem. I suspect the thermostate control. I have...
you will find either 1) there might be a ice blockage on the evaporator. This in turn can stop the evap.fan motor which is supposed to circulate the frost .Defrost with a hairdrier once panel is off or switch orr for at least 2 days to defrost. (insulation is very good. retry.or 2) sometimes you have an auger at top of fridge compartment. If it sticks, reduces ability to cool.Also switch off. use hairdrier to remove ice build up at auger outlet. retry. .
Sep 20, 2009 | Refrigerators
New fridge not cooling
Check the warranty, call the company.
Jul 16, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer won't chill beyond fridge temp
compresoor sounds like its tryin to start but cant, should be covered under 5 yr manufacture warr.
Feb 21, 2008 | Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ...
Refrigerators Logo
252 people viewed this question
Top Max-Fridge Refrigerators Experts
Dan Stewart
Dan Stewart
Level 1 Expert
Tom Chichester
mike simpson
Are you a Max-Fridge Refrigerator Expert? Answer questions, earn points and help others
