Question about Acer Aspire 1200X Notebook
DVD drive locked up, will not open, says its in use.
I was attempting to do a power point and the program locked up. I was able to close the program but the DVD will not let go. Says the DVD is still in use, and will not open, but no programs are running???
  • 115 Answers
Have you tried just rebooting the unit? There is also a mechanical release on the DVD drive. With the unit powered off, unbend a paper clip, look for a small hole(about size of paper clip) in the front of your drive. Slide the clip in until you feel a solid stop and then gently apply pressure until you see the drive come open. You will have to pull the tray out the rest of the way, again gently. After removing the disk, you can gently push the tray back in, or as I prefer, let the unit close it when you power it back up. Let me know if this Fixya's
Posted on Jan 24, 2009
Gateway dx4200 09 dvd drive will not eject?
Unable To Eject DVD From DVD-ROM Drive With The Eject
The DVD-ROM drive will not open to release the DVD when the button is pushed on the drive. RESOLUTION:
  1. Shut down the program that you are installing or running that uses the DVD-ROM drive.
  2. Wait 10 to 15 seconds, and then open the DVD-ROM drive by pushing the eject button on the DVD-ROM drive.
  3. If the DVD-ROM drive door still does not open, do the following:
    • Insert a paper clip or small pointed object into the small hole near the button on the DVD-ROM door.
      Gently push in the paper clip until the DVD-ROM door opens.
    • Remove the CD from the drive.
To prevent the DVD-ROM drive from exhibiting this behavior again, follow these steps:
  1. From the Start menu, point to Settings, and then click Control Panel.
  2. In Control Panel, double-click the System icon.
  3. In the System Properties dialog box, click the Device Manager tab.
  4. On the Device Manager tab, double-click the CD-ROM category.
  5. Double-click Toshiba DVD-ROM.
  6. In the Toshiba DVD-ROM Properties dialog box, click the Settings tab.
  7. On the Settings tab, clear the Auto insertion notification check box, and then click OK.
  8. Click Close.
Dec 03, 2013 | Gateway DX4200-09 PC Desktop
Key buttons will not operate locking system,i have changed battery but still no good.use master key,gets me into the car but alarm goes off and also when i attempt to drive it.
I have the same problem kinda. Lost my master key and sent my ecu off with a home made 2 button key to program immobiliser. This key works to start the engin and drive but I cannot get the key to program with the alarm and locking system. You can try the following steps as may work for you.
I can get my car into programming mode after step 1 but step 2 does not work for me. The locks do not go off at all, not once or twice. Battery in remote key is fine as LCD lights red.
Can anyone help please?
Toyota celica 2000 - 2005 remote keyless entry programming guide
STEP 1
1. Key out of the ignition. Open the drivers door , all other doors are closed . Driver door is unlocked
2. Perform these steps within 5 seconds
a. Insert the key into the ignition ( do not turn it ) take key out
b. Insert the key into the ignition ( do not turn it ) take key out
3. Perform these steps within 40 seconds
a. Close and then open the drivers door.
b. Close and then open the drivers door.
c. Insert the key into the ignition ( do not turn it ) and pull it out.
4. Perform these steps within 40 seconds
c. Close drivers door.
d. Insert the key into the ignition and leave it in the ignition.
Turn the ignition to on (as far as you can go without turning the engine over ), then back to off .
e. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should lock then unlock automatically indicating successful entry into programming mode. Return to step 1 if the locks do not cycle at this point.
STEP 2 (Does not work for me)
6. Perform these steps within 40 seconds
a. Press the lock and unlock buttons on the transmitter simultaneously for 2 seconds
b. Immediately after letting go of the lock and unlock buttons, press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door locks should lock then unlock once indicating successful programming. If the door locks cycle twice, repeat steps 6a and 6b as the remote was not accepted.
7. Open drivers door
Hope this works for you.
Hayley
Oct 03, 2010 | 2000 Toyota Celica
My dvd player says key lock.... I can power it on but it wont open or close.... I have the remote, what you think I should do? I need the key lock off! Help Me Please...
You have to point the remote to the player, then press and hold the power button for 30 seconds while the key lock message is on the display. This should turn the key lock off.
Aug 07, 2010 | Memorex MVD2028 DVD Player
Need to program a new remote
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Here are the instructions for programming the 99-02 4Runner Keyless Entry factory remotes:
1. Start with the following conditions: you are in the vehicle
a. Key is out of the ignition
b. Drive door is open ( all other doors are closed)
c. Driver door
is unlocked (other door locks don't matter)
2. Insert the key into the ignition (don't turn it) and pull it out.
3. Perform these steps within 40 seconds:
a. Cycle the power locks 5 times. Use an even pace and try
to go relatively fast.
b. Close, then open the drivers door.
4. Perform these steps within 40 seconds:
a. Cycle the power locks 5 times (same as before).
b. Turn the ignition to ON then back to OFF.
c. Turn the ignition to ON then back to OFF.
d. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should cycle (automatically)
6. Perform these steps within 40 seconds:
a. Press the LOCK and UNLOCK buttons on the transmitter
simultaneously for 1 second.
Within 3 seconds, the door locks should cycle ( LOCK then
UNLOCK) once-- indicating successful programming. If
the door locks don't cycle, or cycle twice. Repeat steps
6a and 6b--this
remote has not been accepted.
c. Repeat steps 6a and 6b for EACH transmitter that will
operate the vehicle. Including any old transmitters.
7. Close the driver door.
Hope this helps you, it did me greatly-- Good luck,
Mar 04, 2010 | 2000 Toyota 4Runner
Dvd rom drive does not work
Try to open control panel then click add hardware. If you have entered the dialogue box, answer whatever is asked according to what you're searching. Then click whatever hardware your PC would like to detect then click finshed. After the detection, close the wizard box then try to open your DVD ROM and try it.
Hope this answers your question.
Feb 18, 2010 | Artec 16X DVD-ROM 48X CD-ROM Drive with...
The drive drawer keeps opening after you close it. even after 10 attempts it still will not close!
usually means the drive has gone bad or the tracking is off.. May need a new drive sorry but no easy fix for this
Aug 13, 2009 | Dell DVD-rom DVD Drive
My laptop (Samsung R60plus) DVD drive door stays open while powered on, but remains closed while shutdown. D OS recognises it, i can play cd and install programs while holding d door. Pls what can i do to...
The problem is the micro switch that opens the door is allways on.... try press it 10 or 20 times to unlock the switch or try to clean it.... It will work for sure.
Jul 07, 2009 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
DVD Drive door stays open
>One solution is to TAKE A SMALL PIN AND RESET YOUR DRIVE BY POKING THE PIN INTO THE HOLE BELOW THE DOOR..
If this doesnt solve....
You need to necessarily replace the drive..
Jul 07, 2009 | Samsung SC 152 Internal 52x CD-ROM Drive
New DVD read writer not functioning
sounds like the drive lock is not seating properly, (gearing mismatch)
The drive tray lock is a peg on a round gear which locks into a groove on the underside of the tray (you can see it on the underside on the tray,
at some point this gear has "slipped" and now does not meet this groove and closes before hitting this groove,   some manual manipulation of the drive tray can solve this but it is tricky
The easiest way is to "pop" the latch,  which allows you to remove the drive tray completely This "latch" is usually a sprung toungue of plastic which normally prevents the removal of the tray,  if this toungue is lifted the tray can continue on the gear train and can be completely removed, (the eject function will roll the gears forwards and backwards without the tray).
all you do then is to press eject (the mechanism gears will roll out) then you just insert the tray at the correct point (usually at full extend) to re-allign the tray lock (sometimes it takes a couple of attempts to get this right)
Oct 30, 2007 | Computers & Internet
Acer Aspire 1200X Notebook Logo
74 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
