Question about Music
54-Keyboard Electronic Organ MQ-5409 - Music
Where can I find a user manual for a Baldwin MCX 1500 spinet organ?
I have that organ (trying to sell it on Craigslist) and have the manual. I can make a copy of it and mail it to you. Cost would be $10. Here is the Craigslilst link, where you can see a picture of the manual.. Baldwin MCX 1500 Electronic Organ Digital Keyboard Orchestra
Sep 10, 2015 | Music
QS8 keyboard. Why is volume in organ mode much louder than piano mode when I switch between modes without touching volume slide?
On organ mode, in general, almost all brands of the modern keyboard, velocity setting is not enabled. Setting velocity is used to determine how much the level of the sound that follows how strongly you press the keys. It is really just to imitate the sound of vintage organs, which in the past, electronic organ technologi not use the velocity on the keys. So, how strong / slow we press the keys, the sound level will remain the same.
At the Piano mode,modern keyboard using setting velocity. This also to imitate an acoustic piano, which, if we press the keys slowly, the sound level will be slow as well, and vice versa.
So, in your case,at the same volume slider, try to play on the organ modes, note level. Moving to the piano mode and press the keys securely powered (full power). Then the sound level should be equal to the organ mode.
On modern keyboards, also included organ sound that added velocity setting. Usually found on the user bank.
Sep 01, 2015 | Alesis Music
Alesis QS8 keyboard. The volume of the organ is much louder than the keyboard when I switch between both modes without touching the volume slide. How can I fix this.
Can I ship an organ on it's back?
Depends on the make and model. A all electronic organ with very little mechanical components should be fine. The older Hammond organs do not like to be tilted to far of the vertical. What make do you have?
Dec 21, 2013 | Music
Technics organ will not play
Need more info.... using line out or does it have built in speakers, make sure if it uses an ac power adapter that it is the correct one (AC vs DC output and voltage\amp rating makes a difference). Is it moved often, was anything dropped or spilled on it, etc? Age... model number and you say organ I'm guessing it's actually an electronic keyboard?
Jul 04, 2013 | Music
User's manual for the Lowrey Organ Holiday Deluxe w/Magic Genie?
Here is a site to download manual:
http://www.lowreyforum.com/lowreymanuals.htm
A Leslie is special speaker system that is spun to break up the sound so it doesn't seem to come from a single point.
Sometimes the Leslie speaker is in a seperate cabinet fromthe organ, and SOMETIMES it is a simulated Leslie that is done with multiple speakers and electronic switching. If the Leslie is an external one, it usually attaches via a cable that often has either 9, 11, or 13 pins.
Dec 06, 2009 | Music
Music Logo
22 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
