IDX04022E: Scanner Initialization Error
I receive this error after starting Identix TouchPrint. Scanner is also Identix. Only option is to select OK. When attempt to capture fingerprints receive "IDX28009E: Scanner is not responding. If this persists, please shutdown and reboot." I have shutdown multiple times and checked cord connections. Any recommendations?
SOURCE: Identix Touchprint Enhance Definition 3800 Livescan
have you solved the problem yet
Posted on Mar 14, 2009
  • 119 Answers
SOURCE: i need the driver for Identix BioTouch Usb 200
you can download it on the internet
Posted on Oct 19, 2009
mohanchennai
  • 490 Answers
SOURCE: Paper tray at front of scanner will not lift.
Disconnect the scanner from the Comp, Try 'page counting'. If the papers go through, then you know feed mechanism is okay. if the tray is not lifting, then you have a problem. Use Qumatool software and check if the tray is lifting. If the scanner tray if lifting then the motor is okay, if not, the lifting motor may need a check.If the motor is okay, but tray not lifting means the sensor in the paper tray is faulty. Check this out.
S. Mohan, Chennai, India
Posted on Jul 28, 2010
SOURCE: Scanning error - cannot scan error code 2,155,0 ???
i found this while i had the same error msg... apparently its actully the USB cable where its does not suffice
here is the link : http://www.fixyourownprinter.com/forums/printer/49111
Thanks
Sanjieev
Posted on Sep 05, 2010
SOURCE: This is the message i
Do you have biometric license, if not, you only need to contact me on 08132829820 or email me on biometricmasters2000-jamb@yahoo.com.
We will be more than glad to help you succeed.
Call on us today, we will cuddle you like a baby in order to help you out.
Posted on Feb 25, 2011
Hp leserjet printer error.
Service-mode functions NVRAM initialization
An NVRAM initialization will return the following device settings to the factory-set defaults:
All menu settings, including the fax header and company name
Fax numbers and names that are associated with one-touch keys and speed-dial codes
Additionally, all faxes stored in memory are cleared.
Perform an NVRAM initialization
1.
Turn off the product.
2.
Simultaneously press and hold the
the product.
3.
Wait until the message Permanent storage init. appears, and then release the
arrow buttons.
When the NVRAM initialization process has been completed, the device control panel shows the
Ready message.
Super NVRAM initialization
A Super NVRAM initialization will return all of the device settings to the factory-set defaults (generic
product mode).
NOTE:
When the product is turned on, you will be prompted to select the language and country/region
setting before the product will initialize.
1.
2.
the product.
3.
arrow buttons.
Service menu
NOTE:
An asterisk (*) symbol next to a service submenu option indicates that this is the current setting
for that option.
For more information about using the service menu, see
Access the service menu
1.
Press the
2.
Use the arrow buttons to select Main Menu Service, and then press OK.
3.
Use the arrow buttons to select the desired secondary-service option, and then press the
button.
4.
Use the arrow buttons to select the desired submenu option, and then press
ENWW
Setup
button.
Cancel
button and the right arrow button
Cancel
button and the left arrow button
Service menu on page
), and then turn on
Cancel
and right
), and then turn on
Cancel
and left
241.
OK
OK
directly from service manual
Sep 15, 2015 | HP LaserJet M1005 Printer
E-000732-0001
Error in scanner communication
Error in DDI-S communication Remedy 1. Check the connector connecting to the Scanner. 2. Check the power of the Scanner ->whether to perform initialization at start-up? 3. Replace the Rcon, the Scanner Board or the Main controller PCB 2.
Dec 09, 2014 | Canon ImageRunner 5050N Digital Copier
CODE 162,0,0 ON CANON D1350
This happens across the range of Canon Printers. The fix is to push the right button! Yeh I have a differing model, but the answer is the same. Go to the printer and select remote scan. Then invoke computer program. Some one has to be boss either the printer or the computer for scanning.
I can make the scanner printer the boss and issue a TIFF scan to the computer. Just push scan on the printer and select computer (it does a push data)
I can make the computer the boss by selecting the steps below:
Please choose what option you require. Ignore the model number.
The error codes 162,0,0, or 255,0,0, usually indicate that you have not selected a scan type at the machine. Please follow the steps below to perform a scan from the image I-SENSYS MF8230Cn:
Verify that MF Toolbox is closed on the computer and press the [SCAN] button on the printer.
Highlight [Remote Scanner] and press [OK]. The screen will show, "Remote Scanner. Waiting online...".
On the computer, open the MF Toolbox and select [PDF].
Click the green [START] button on the [PDF] window. The machine will start processing the scan.
If you receive any errors or need further assistance with the I-SENSYS MF8230Cn, we recommend that you contact us at 1-800-OK-CANON (1-800-652-2666).
Sep 29, 2014 | Canon imageCLASS D1350
I have a problem Taskalfa 250ci eror code c0640 I think at Hdd problem. But I don't know how to hdd format
Maintenance
item No.
U021
Memory initializing
Description
Initializes all settings, except those pertinent to the type of machine, namely each counter, service call history
and mode setting. Also initializes backup RAM according to region specification selected in maintenance item
U252 Setting the destination.
Refer to *1 of the maintenance mode item list about the item initialized.
Purpose
To return the machine settings to their factory default.
Method
1. Press the start key.
2. Press [EXECUTE] on the touch panel.
3. Press the start key. All data other than that for adjustments due to variations between machines is initial-
ized based on the destination setting.
4. Turn the main power switch off and on.
For errors occurred, turn main power switch off then on, and execute initialization.
Error codes
U024
HDD formatting
Description
Initializes the hard disk.
In addition, the following settings are also initialized by initializing the hard disk.
System menu (user login administration, job accounting, address book, one-touch keys and document box
etc.), shortcuts and panel programs
Purpose
To initialize the hard disk when replacing the hard disk after shipping.
Method
3. Press the start key to initialize the hard disk.
Description
Codes Description
01 Configuration initialization error
02 Counter initialization error
20 Engine initialization error
40 Scanner initialization error
2JZ/2JX/2JV/2H7-5
1-3-23
Apr 15, 2013 | Kyocera Taskalfa 250ci Color Copier...
Hp laserjet M2727nf scanner error 52
First, power the printer off, wait for about 30secs and power on. If problem persist replace the scanner.
Feb 23, 2010 | HP Laserjet M2727nf Multifunction Printer
Error code 117-363 printer starts machine is awake
only see error code 117-363 and not permited other option
Nov 26, 2009 | Xerox 6180MFP/N Printer
Initialization error
Test your webcam here by hitting "Allow" in top window and assessing your webcam in left hand panel.
If it works here, you know the hardware is OK. Now you have to configure it to any program you want to use it in
SkypeIf you have problems when you use your webcam device in Skype, you may have to configure the audio and video setting in Skype. To do this, follow these steps:
  1. Start Skype.
  2. On the Tools menu, click Options.
  3. In the navigation pane of the Skype Options window, click Audio Settings.
  4. Select your LifeCam device as the default microphone. For example, select Microsoft LifeCam VX-3000.
  5. In the navigation pane of the Skype Options window, click Video Settings.
  6. Select your LifeCam device as the default Webcam. For example, select Microsoft LifeCam VX-3000.
  7. Click Save.
  8. Test LifeCam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site: http://support.skype.com (http://support.skype.com)
I do not know the second program ( explorer express) but there will be a similar arrange for making your Hardware default
Aug 27, 2009 | Microsoft LifeCam VX-3000 Web Camera
Can't send faxes. Dials Ok but no connection to send fax
If you are unable to send the faxes, please try decreasing the modem speed and disabling the "Error Correction Mode." To decrease the modem speed, please follow the steps given below:
1. Press the "Fax" button.
2. Press the "Options" button 15 times till it reads "Advanced Fax" on the display.
3. Press the "Select" button.
4. Then press the "Options" button 10 times till it reads "Max Send Speed."
5. Now press the "Right Arrow" button and choose "9600 bps."
6. Press the "Select" button.
To disable "Error Correction," please follow the steps given below:
1. Please press the "Fax" button.
4. Then press the "Options" button 11 times till it reads "Error Correction."
5. Now press the "Right Arrow" button and choose "NO."
May 19, 2009 | Lexmark X4270 All-in-One Multifunction...
Initialization failed - Unable to acquire TWAIN-compliant device
I have seen your message stating that "Initialization failed - Unable to acquire TWAIN-compliant device" error is received when trying to connect USB-Parallel type to your Laptop.
Well,  Printer  Panasonic UF4100, recommends to use only " Printer/Scanner Interface as Bi-directional Parallel (IEEE1284) " means you need to use Parallel cable to connect Printer to the Computer/Notebook.  You may receive some communication error messages if you are using a  "PORT REPLICATOR CABLE"( USB TO PARALLEL connector).  The error message that you have received is related to the communication error. Futher, if you use same USB- Parallel cable for long time the Printer Hardware functionality might go bad, since Printer memory gets confused and will not read or detect the Cable , since it is not a cable to use  mentioned by Panasonic Manufacturer.
Let me tell you, general functionality of Printer like Printing would work even if you use USB-Parallel cable. But it is not a case with Scanner and Fax functionality.
Hence, I recommend you to use only Parallel cable to connect your Printer to the Laptops.
I hope that this will resolve the issue for you.
You can email me at thumuvikram@rediffmail.com if you need further assistance.
Bye.
Oct 17, 2007 | BafoTech BAFO BF-1284 Parallel Adapter
37 people viewed this question
jasbo
jasbo
