Cant connect to available wireless networks
HP tx 1138
My laptop wont connect to the router, even though the laptop beside me will. There is a list of available netwotks but won't connect, and when I ask to diagnose the problem it gives no solution!
  • 871 Answers
Hey bohsever
the way you explained the problem suggests that you are using windows vista right?
if your laptop cant connect while others can, you may need to uninstall your wifi devices and reinstall them just to be sure. if this still wouldnt work, pls look for an update for your wifi software and driver. this usually is the common problem with some laptops that i know.
hope this helps
Posted on Jan 24, 2009
Cant connect to a new labtop
1, You should always secure your Wireless. 2, try different channels, setup the dual-bands as 2 SSID, 1-2.4 and the other as 5.0 with diferent channels. I would suspect it's the laptop, Disable the UAC and the Anti Virus. Is the wireless adapter, on the laptop turned on? Do you see the Wireless listed in Available Wireless Networks? For dual-band setup :http://www.pcworld.com/article/229521/dlink_setup_a_wireless_router.html
Jan 09, 2013 | Computers & Internet
My Hp G62-225DX with windows 7 can connect through ethernet cable but wont connect wirelessly even though wireless and router are on the computer says no connections available
Hi
A good idea would be to contact your service provider and ask him to help you to lead you through all the numbers so that the router has your laptops correct gateway.
all thebest
kolla
Aug 29, 2011 | Computers & Internet
Cant get wireless router to work on laptop
First, try to connect your laptop hardwired to the router, if it works fine, its just the wireless configuration. Make sure you are using the correct wireless network key to connect to your wireless network. Go to the Control Panel > Network Connections > Right-click Wireless Network Connection > Properties > Wireless Networks Tab and delete all the names listed under Preferred Networks box. Click Ok. Right-click on Wireless Network Connection again > View Available Wireless Network > Choose your own network and click Connect. If it asks you to type the network key, type in your WEP or Wireless Network Key and press connect. That should do it.
Oct 06, 2009 | Computers & Internet
I have a Dell XPS 1330 laptop and a DI-524 wireless router.
Unsure what your problem is exactly but here is something to try. Power off all computers, modem and router. Power up the modem first, and wait until it is completely up before proceeding. Next power up the router and wait until it is completely up, the only light that probably wont be lit is the LAN light. Then power up each computer, they can all be powered on at the same time, that part really doesnt matter. See if that fixes the problem.
Aug 11, 2009 | D-Link AirPlus DI-524 Wireless Router
Cant connect to wireless network
hi
i think you are continuing with an old question, instead of posting this as a new query again you can go to the old query and post these as comments to comtinue with the old
happy to help though, anyways lets me try n reply
could be couple reasons
just to check first have you enabled the wireless on the two laptops ;p
check on what channel the router and the laptops are communicating this you would find on the CONFIGURE settings of the wificard on the laptop
on the properties tab of the network settings go to the Wireless Networks tab and there just above the OK n Cancel buttons u would see an ADVANCED button click on that to see if the radio buttn is set to any available network
then in the Prefered Networks area if u see your wireless network name which was previously added then click on properties and put a tick on the check box which says
"connect even if not broadcasting"
also pls do check to see if there are any access restrictions like if you have enabled MAC ID recognition on the router
have you checked on the laptops if you would require any DNS server settings or Proxy which can be gotten from your ISP
cheers
pls rate if this was any help
Jul 09, 2009 | D-Link DI 514 Wireless Router (DI-514)
My HP mini laptop will not connect to my wireless network.
check you wireless router settings if the wireless is enable on the router then , if this is done disable the firewall on your wireless laptop and if you cannot still connect to the wireless uninstalled and reinstalled your wireless driver software.
Adeyiga Shitu
Apr 17, 2009 | HP MINI 2133 NOTEBOOK PC - 1.6GHZ PC...
Can connect via Ethernet but not wireless
well its unfortunate,,intel 2200 WLAN cards{oldest cards launched till now by intel} face this problem,the problem is with the differnce of wireless standards between the router and the wireless card.go for a wireless usb adapter,,install it and it wud work absolutely fine
Apr 12, 2009 | Intel PRO/Wireless 2200BG 802.11g/b
Hp Pavilion dv6929nr not connected with D-link DI-624
There are a number of factors that can cause the signal of your access point to deteriorate and the performance of your network to fall under par. Practically any appliance that operates on the same frequency level (2.4 GHz) as 802.11b or 802.11g can cause interference with your wireless network. Be sure to keep cordless phones, microwaves and other electrical equipment at least 1m away from the access point. Try changing channels on the access point and test it out on one of the clients. To change the radio channel on the access point login to the configuration (usually a web based interface) and go to the Wireless Settings (will vary depending on vendor) section, select a different channel and save settings. On the client, go to Device Manager, right click your wireless network adapter and go to Properties. In the advanced tab select the Channel Property and change the Value to the same number as the one you chose on the Access Point. Disable and then re-enable the wireless connection. Also you can try by select the speed manually 802.11b or 11Mbps on your laptop wireless properties.
PLZ GIVE RATING BY CLICK ON YES or NO.
Mar 21, 2009 | HP Computers & Internet
Setting up wireless connection
First check to see if your windows can see the wireless router. Does it see the router? Click view wirelss networks to see a list of available networks. If you cant see any make sure your wireless network is switched on.
Also which manage s your wireless network, the windows or the wireless cards own software?
Aug 14, 2008 | Computers & Internet
Netgear wireless router
Hi!
Try these:
1. Go to CONTROL PANEL > MANAGE WIRELESS NETWORKS
2. Remove all the preferred networks
3. Restart your laptop
4. Reconnect to your network
Hope this helps!
May 04, 2008 | NetGear WGR614 Wireless Router
Computers & Internet Logo
138 people viewed this question
David Payne
David Payne
