Question about Everex StepNote NC1500 Notebook
I have two partitions and I only want one
Some how when I used recovery disk I ended up with two partitions
I only won't one. how do I undo this second partition
    Scholar:
  • 155 Answers
The recovery disk does it automatically. If you want to just hav eone partition, you need to manually reinstall windows. You need to have a windows reinstallation cd. Boot from it. It will give you an option on how you want the partitions to be created.
For windows xp, you can refer to this link.
For windows vista, click this.
Posted on Jan 24, 2009
Smart recovery problem on every boot
Since you used a program to resize the partitions it probably corrupted the file and\or made it unusable. I would recommend doing an entire system format of both partitions then backing up onto the separate hidden partition again and it should work.
May 12, 2013 | LG X120 Netbook
Lg smart recovery
Resizing the partitions has affected the partition size of the hidden recovery partition. This is why the recovery does not work.
You need to get a Recovery CD for your model LG laptop from the LG WEB site so you can restore your laptop.
You maybe able to download the recovery CD from this site : -
www.notebook-driver.com/lg/lg-notebook-lm40lm50-driver/
May 12, 2013 | Computers & Internet
How do you remove the recovery partition in windows 7
To remove the partition, you can use a tool called GParted. GParted can be downloaded and booted to and you can remove the partition using that tool. I will warn you that this is an advanced tool and could potentially corrupt data. Backup important files before proceeding.
Also if you have an OEM Windows 7 disk, you can boot to that and install Windows from scratch. When it boots, it will give you option to change the partition table on the drive which means you can remove it. This process will completely wipe your system and the partition, leaving you with a clean windows install. Always backup important files before proceeding.
Also know that the recovery partition is put there for a reason! Manufacturers create recovery partitions to include factory restore files. If you wipe out the recovery partition and do not have backup factory recovery disks, you will have no way to restore your PC to factory specs. You can still restore it from an OEM windows disk, it just won't be loaded with the factory bloatware...which isn't necessarily a bad thing!
Sep 18, 2012 | Sony VAIO VGN-AR870NB Notebook
Need to reboot
if it has a recovery partition ..just press f11 on start and start to reinstall from it (completely ) ..if it is not working try from boot menu ..(press f12 on start 0 ..and in the menu choose recovery partition .
In case you do not have such partition .try from a recovery disk if you have ..or if this is not available too ..try to use a boot-able disk with a operation system image on it ..and reinstall it ..
To do so ..you need to download an image of the OS , after that burn it on the disk using a image burner ..and end up with a boot-able disk ..
Insert the disk and restart ...press f12 to bring up the boot menu ..select CD /DVD drive and enter ..it will boot from the disk and ask you to press any key to confirm ..After that will start loading files and go on with the process of installing windows.
Good luck !
Dec 23, 2011 | Computers & Internet
MY BUFFALO EXTERNAL HARD DISK HD PXTU2 IS SHOWING 297 GB UNALLOCATED. I THINK ITS PARTITION IS CORUPPTED
Hi guy,
You can try a partition recovery software to recover your corruptted partition.I have succeed to recover deleted partition with Tenorshare data recovery.It can recover deleted,formatted,corruptted partition after deeply scanning your hard drive to look for lost data.
Anyway,you can download a trial version and scan your hard drive for free to check out whether your partition can be recovered. http://www.any-data-recovery.com/index.htm
Jun 18, 2011 | Computers & Internet
Hard disk error code 2000-0146
If happens that's the message it gives you by the machine, most likely its already a hardware problem but if you want to make sure try to do HDD scan, you can just go to any computer local center have them check if the HDD failed and if it failed you can purchase a new one.
Apr 21, 2011 | Computers & Internet
I use vista home edition 32-bit, registrated. My son accidently installed a linux-system on thze full partition! How can i undo this? If its possible...
It cannot be undone without a LOT of expense, think CIA sleuths and even then most will be lost.
You have lost everything, data wise, that you had on that disk. You can use your recovery disks to restore the system to factory settings. If you don't have the recovery disks, most manufactures will sell them for a small fee.
Oct 02, 2010 | Computers & Internet
I want to downgrade my desktop acer aspire x1800 vista to xp pro everytime i run set-up it always showing me an error could not proceed,.
Most like ly the hard drive has a Vista recovery partition. That partition has got to be deleted. You'll need to open a command prompt and follow the guide very carefully or irreperable damage could occur.
Here’s the trick to delete and remove the EISA recovery or diagnostic partition in Vista. Before proceeding with the deletion action, make sure that at least a set of Recovery Disc Media has been created. Else, you won’t be able to restore your computer to working and factory default condition when any problem on PC requires reinstallation.
  1. Open a command prompt as administrator.
  2. Run Diskpart application by typing Diskpart in the command prompt.
  3. In the “Diskpart” prompt, enter rescan command and press Enter key to re-scan all partitions, volumes and drives available.
  4. Then type in list disk and press Enter key to show all hard disk drive available.
  5. Select the disk that contains the partition you want to remove. Normally, with just 1 hard disk, it will be disk 0. So the command will be:
select disk 0
Finish by Enter key.
  1. Type list partition and press Enter key to show all available and created partition in the disk selected.
  2. Select the partition that wanted to be deleted by using the following command, followed by Enter key:
select partition x
where x is the number of the EISA based recovery partition to be removed and unlocked its space. Be careful with the number of this partition, as wrong number may get data wipes off.
  1. Finally, type in delete partition override and press Enter key.
Once the partition has been deleted, exit from Diskpart, and now users can use the much familiar and much easier Disk Management tool in Windows (diskmgmt.msc) to manipulate the freed unallocated partition. Users can create a new volume (partition) with this space, or simply merge it to existing partition by extending the size of the existing partition.
Oct 08, 2009 | Computers & Internet
D2d recovery
Hello Sir / Madam,
Many Acer systems come with the ability to press ALT+F10 to kick off the Acer Recovery applications from a special hidden recovery partition. Sometimes this won’t work and there can be a number of reasons.
1. D2D Recovery is “Disabled” in the BIOS (Main menu).
FIX: Enabled it and try pressing ALT+F10 again as the computer boots.
2. The Acer hidden recovery partition (PQSERVICE) has been removed or damaged. If the disk drive is a replacement drive then you won’t have this partition.
FIX: Unless you have previously imaged the PQSERVICE partition it will not be possible to use D2D recovery. You will need to restore from the Acer Recovery CD/DVD.
3. You have converted the FAT32 partition on the hard drives into NTFS. Acer D2D recovery won’t be available if you perform this conversion. Ironic that NTFS is a more desirable disk format to use but Acer won’t support this in their systems!
FIX: Restore your system from the recovery CD/DVD media.
4. The special Acer Master Boot Record (MBR) has become corrupt or has been overwritten with an non Acer MBR. As long as the PQSERVICE partition is there or you can get your hands on a couple of Acer service files for your model, then you can remake the special Acer MBR. Let’s cover how this is done.
  1. Disable D2D recovery in the BIOS. Can be found in the “Main” menu section. Save the BIOS settings and exit.
  2. Log into Windows with an “administrator” level account.
  3. Download ParTEDIT32.ZIP (registration required for download).
  4. Extract PTEDIT32.EXE from the zip archive and run it.
  5. Identify the PQSERVICE partition by its type or size. It is likely to be 12 or another custom value and is likely to be reasonably small in comparison to the other normal partitions - see the example below from a working factory default Acer. Click the Link below see the image full size. http://www.roundtripsolutions.com/blog/wp-content/uploads/
  6. 2007/10/AcerDiskRecoveryBroken_F031/hidden.jpg
    Change the type to “07′ (Installable File System NTFS, HPFS) and “Save Changes”.
  7. Reboot the computer and login with an “administrator” level account.
  8. You should then be able to open up a command prompt and navigate to the PQSERVICE drive.
  9. Enter the following command at the command prompt:
    mbrwrdos.exe install rtmbr.bin
    - You may have to search for these files and change into the relevant directory.
    Note: This step writes the Acer MBR, with mbrwrdos.exe and rtmbr.bin being the special service files.
  10. Close the command prompt window and reboot.
  11. Go into the BIOS again and enable D2D Recovery. Save the BIOS settings and exit.
  12. ALT+F10 should now start Acer Recovery as the computer starts.
  13. The Acer MBR ensures the PQSERVICE partition is hidden therefore there is no need to reset the partition type back to 07 - well there shouldn’t be if all has gone well. If you need to manually reset it then run PTEDIT32.EXE again, set the partition to 12, or whatever the original value was, and save the changes to complete the process. Reboot and it should now be hidden.
If Windows is unbootable, due to whatever issue, you can always use the Ultimate Boot CD for Windows (UBCD4Win) along with a copy of PTEDIT32.EXE to achieve the same results. Likewise, use UBCD4Win along with PTEDIT32.EXE if the PQSERVICE partition is being changed back to a hidden one by the existing MBR. We’ll leave that as an exercise for those who need to do it! It has been pointed out in the comments that UBCD4Win already has an application that will do partition maintenance, so checkout TestDisc if you go down that road.
If this is a new drive or someone has completely wiped the drive, including the hidden partitions, it may be necessary to use partitioning software to recreate the partitions that the Acer Recovery system is expecting! You’ll also need to restore an image of the recovery partition from a previously made backup, so it is worth making that backup image straight away while the laptop is still new and shiny, and certainly well in advance of any problem.
A final word or two of caution: take great caution when playing around with partitions on an Acer system… you have been warned… and remember to make the backup media disks as soon as you fire the computer up for the first time!
Thanks
Good Luck
Don't forget to rate the Solution!!!!!!!!
Mar 19, 2008 | Computers & Internet
Everex StepNote NC1500 Notebook Logo
56 people viewed this question
Top Everex Computers & Internet Experts
Jerry Umali
k24674
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
