Question about Xerox Phaser 6110 Laser Printer
A red light all the time on xerox phaser 6110.
I have a problem with xerox phaser 6110. It doesn't print. There is a red light all the time. I checked cables, paper and ink ; all of them are good. So I don't know what to do. Help me, please.
Thank you alot
  • 1 more comment
  • toctoctoc Feb 02, 2009
    ditto - exactly
  • Anonymous Feb 03, 2009
    same here
  • comu_graf Feb 09, 2009
    Tengo una Xerox phaser 6110, se queda en rojo y no imprime
I think I might know what this is. Mine did the same and I removed the waste toner cartridge (grey L shapped unit to the right of the colour cartridges under the front panel) I noticed it was quite full but a rocked it from side to side to settle the contents (be carefull as they can come out) and when refitted the light stayed off when powered up. I'm not sure if this waste cartridge needs to be replaced or you can simply tip it out into a bin, but I'll try that tomorrow when I can empty out side.
Posted on Feb 20, 2009
  • RSoper Feb 20, 2009
    Sorry, correction, the waste cartridge is on the left..... :o)
  • 37 Answers
Connect the machine with a USB cable and install a utility called "Status Monitor". It came on the disk supplied with the machine, or you can download it from the Xerox Support website. When you try to send a print job, the status monitor software will tell you what the red light means.
As an alternative, if the machine is on a network, you can browse to it using it's IP address. This will also show the current status of the machine with any error messages, but in my opinion it is best to use the USB option.
Please see my other post on this.
Posted on Jun 16, 2009
Prints light on one side
Are you low on toner?
Else try reinstall the printer.
Phaser 6110 Support Drivers
Aug 21, 2014 | Xerox Phaser 6110 Laser Printer
When the red light blinks on the printer what does it indicate-model-xerox phaser printer 6110
The blinking toner cartridge is low. Order a new toner cartridge. You can temporarily improve print quality by redistributing the toner. See "Redistributing Toner" on page 5.2
from the manual online as pdf: http://download.support.xerox.com/pub/docs/6110/userdocs/any-os/en/Guide_XP.pdf
Apr 06, 2011 | Xerox Phaser 6110 Laser Printer
I get a paper jam every time I use my Xerox 6110 MFP Printer. It jams on every document while printing or copying.
same problem here expert at Xerox adviced to clean black rollers on the papertray
maybe it works for you, not for me though ;-(
Aug 11, 2010 | Xerox Phaser 6110 Laser Printer
How to install xerox phaser 6110? I do not have any driver
This page has drivers for your Xerox Phaser 6110:
http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=6110&Xlang=en_US&Xcntry=USA&prodName=Phaser%206110
Apr 28, 2010 | Xerox Phaser 6110 Laser Printer
Mac OS 10.6 Snow Leopard: Printer Driver Update for Xerox Phaser 6110 does not work ! Xerox/Apple is providing a most complicated instruction to circumvent the problem that I am not able to...
    1) Change the “Xerox” Folder Permissions:
    • Navigate to Applications > Utilities and open a Terminal window.
      • Type the following command: sudo chown -R root:admin /Library/Printers/Xerox
    • You will be prompted to enter your password.
    2) Install Rosetta from the Snow Leopard DVD:
    • Insert the Snow Leopard Install DVD
      • Select Optional Package
      • Select “Rosetta only” from the list of optional packages
      • Click install and follow instructions to complete installation; there is no need to reboot
    3) Reset Printing System:
      • Navigate to: System Preferences> Print & Fax> Xerox Phaser [6100, 6110, 6110MFP]
      • Right click on the printer
      • Select Reset Printing System
    4) Install Printer (without removing the driver):
      • Select +: add the available Xerox printer
Mar 18, 2010 | Xerox Phaser 6110 Laser Printer
Red in xerox 6110
check the waste toner (it's on the left side of drum unit when you open the front cover) cartridge or paper jam if blinking!
Dec 04, 2009 | Xerox Phaser 6110 Laser Printer
Not printing
Hi ,
There may be several causes for this problem.
I will tell you one by one, and you try it.
CAUSE: 1
The printer is not
receiving power.
SOLUTION:1
Check the power cord connections.
Check the power switch and the
power source.
CAUSE:2
The printer is not
selected as the
default printer.
SOLUTION:2
Select Xerox Phaser 6110
Series as your default printer.
CAUSE:3
Check the printer for
the following:
• The printer cover is
not closed.
• Paper is jammed.
• No paper is loaded.
• A toner cartridge is
not installed.
SOLUTION:3
After locating the problem, clear it.
If a printer system error occurs,
contact your service representative.
• Close the printer cover.
• Clear the paper jam.
• Load paper.
• Install the toner cartridge.
CAUSE:4
The printer may be in
manual feed mode
and out of paper.
SOLUTION:4
Check the message on the Status
Monitor program window, add paper
to the tray and press the
button on the control panel.
CAUSE:5
The connection cable
between the
computer and the
printer is not
connected properly.
SOLUTION:5
Disconnect the printer cable and
reconnect it.
CAUSE:6
between the
computer and the
printer is defective.
SOLUTION:6
If possible, attach the cable to
another computer that is working
properly and try to print a
document. You can also try using a
different printer cable.
CAUSE:7
The port setting is
incorrect.
SOLUTION:7
Check the Windows printer setting
to make sure that the print job is
sent to the correct port. If the
computer has more than one port,
make sure that the printer is
attached to the correct one.
CAUSE:8
The printer may be
configured
incorrectly.
SOLUTION:8
Check the printer properties to
ensure that all of the print settings
are correct.
If u still cant find the remedy, go for the support from XEROX,
www.office.xerox.com/printers/color-printers/phaser-6110/serv-enus.html
Hope my info solves your problem,
Thanx for using fixya.
Oct 01, 2008 | Xerox Phaser 7760/YDX Laser Printer
Xerox phaser 6110 mfp
sir,
clean the LSU(Laser Sensing Unit) with a dry cloth.
Sep 25, 2008 | Xerox Phaser 6110MFP All-In-One Laser...
Xerox Phaser  6110 Laser Printer Logo
3,633 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
