Question about Stanley Bostitch MiniSuite Electric Desktop Stapler 18 Sheet Capacity Black/Silver -- Sold as 2 Packs of - 1 - / - Total of 2 Each
Bostich minisuite electric stapler won't work
5 Suggested Answers
  • 6 Answers
SOURCE: I can't load staples in a borrowewd SX150 stapler
check the crown size. some are 9/16 others are 1/2
Posted on Dec 01, 2009
  • 12650 Answers
SOURCE: Bostich narrow crown air stapler won't work
before going about rebuild get can of carburetor spray cleaner and stray the ram area lots of times the glue that holds the staples/or nails builds up and stops up the ram rod spray the rod a few times than with air hooked up dry fire if it frees up lube rod area
Posted on Jan 18, 2010
  • 885 Answers
SOURCE: what part do I need
You shouldn't have to do anything to the MIIIFS flooring stapler to shoot 2" staples. It is designed to shoot 1 1/2" to 2" staples right out of the box. If your stapler won't feed 2" staples, check the magazine all the way up to the power head for any foreign material that may hold up your staples.
Posted on Apr 26, 2011
  • 21 Answers
SOURCE: I HAVE A STANLEY BOSTICH ELECTRIC STAPLER,WHEN YOU CLOSE THE DRAWER WHERE THE STAPLES GO YOU GET A KNOCKING NOISE
I recommend that you will post your question under the correct category (Stanley Office Supplies) and maybe add more details to it, so it will be easier for Experts to understand the question and answer it.
Posted on Oct 22, 2012
How do I load the stapler?
No you don't. We answer most things here.
If the stapler is like any of these
http://www.amazon.com/s?ie=UTF8&page=1&rh=i%3Aaps%2Ck%3Abostitch%20staple%20gun
You push the back in slightly to unlatch it and then drop it down a bit and the staple pusher comes out completely.
Jan 28, 2016 | Heavy Duty Stanley Bostich Heavy-duty...
How do I reload staples into a Bostich Electric Stapler E66760? I tried standard staples and they won't seem to fit
RTM. Read the manual. If you didn't keep it, you can Google for one with your make, model and manual in the search box and you should be able to get a .pdf file of the manual which you can save to your computer. You're probably using the wrong size staples.
Mar 05, 2015 | Staples Office Equipment & Supplies
Bostitch stapler instructions
Google search. type in specs and diagram, should come up
Jun 28, 2014 | Office Equipment & Supplies
Oct 04, 2012 | Stanley Electric Desk Stapler, 45 Sheet...
Our staples won't go all the way through . We
You didn't list the make and model of your stapler but if it's not driving the staples flush with the surface here are some possible causes:
1. The wood; If you are driving long staples into hardwood or knotty lumber you may have to use shorter staples to see how they set.
2. Stapler settings; Turning the air pressure up isn't the answer to driving staples deeper, it is only harder on the stapler. Most staplers work in the 90 to 120 psi range. The lower pressure you use the longer your stapler will last. Check/adjust the depth of drive control on the stapler to determine where the top of the staple is driven to.
3. Broke stapler; If it's not driving them to the proper depth but the level they are driven to is consistant, you may have a damaged piston o-ring/seal or the end of the driver is broken off. You'll have to go into the gun or take it to a service center to check these things.
Mar 04, 2012 | Air Tools & Compressors
What part do I need to remove to make a bostich MIIIFS floor stapler to shoot 2 inch staples
Apr 26, 2011 | Stanley Bostitch STB-MIIIFS Flooring...
My bostich flooring staler wont fully drive every staple and it is getting wors....it is not leaking air
Your compressor needs to be checked first. There is an air pressure regulator on most machines - be sure all is in working order. It might help to be sure you're playing any lubricants in the stapler configuration as well.
Nov 05, 2010 | Stanley Bostitch STB-MIIIFS Flooring...
Jan 17, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
Aug 31, 2009 | Stanley Air Tools & Compressors
Stanley Bostitch MiniSuite Electric Desktop Stapler 18 Sheet Capacity Black/Silver -- Sold as 2 Packs of - 1 - / - Total of 2 Each Logo
15 people viewed this question
Top Stanley Office Equipment & Supplies Experts
ray gallant
Bill Boyd
Are you a Stanley Office Equipment and Supply Expert? Answer questions, earn points and help others
