Question about Samsung DVD-R155
Recording on DVD-R with Samsung DVD-R155
When I put a blank DVD-R in my DVD player with the intention of recording, I get the following message "The disc cannot be played, please check the disk" I have put several brand new discs in and get the same message. This is brand new DVD player.
  • 10 more comments
  • Anonymous Dec 09, 2007
    My samsung dvd recorder r155 ejects the disc i insert for recording (dvd+r).
  • Anonymous Dec 25, 2007
    Yep exactly the same happens with DVD+RW
  • Anonymous Apr 05, 2008
    Rejects new blank Philips DVD-RW
  • Anonymous Apr 16, 2008
    ejects the blank disc I want to use for recording
  • ccnn May 01, 2008
    Do I need only Samsung brand DVD-R disc for recording?
  • Anonymous May 18, 2008
    Rejects my Sony DVD+RW 1x-4x disk?
  • ianandbron Jul 15, 2008
    same problem and i am using dvd-rw discs!!!!
  • Anonymous Aug 19, 2008
    My Samsung DVD R155 often ejects a new blank DVD-R, thereby preventing recording. If I pull the plug and let it 'rest', it sometimes behaves properly next time. I suspect a permanent malfunction is close. The fault first occurred 53 weeks after purchase.
  • triz369 Mar 19, 2009
    Worked for about 4 months...doing the same thing. Im ready to smash it on the floor. Looks like a bad product from Samsung.
    It also happens with regular movies.
  • Anonymous Mar 21, 2009
    Sorry Jacqster
    But r155 CANNOT use BluRay discs and records on all others types except DVD-RAM. I agree with TSYA a definite overheating problem, mine plays fine with the lid off and rejects discs after 5-10 mins with the lid on.
  • Anonymous Mar 27, 2014
    When I turn on the DVD player all I get is wavy lines. I was told to take the batteries out press power button put in new batteries press BD button this worked a couple of times but not longer solves the problem
  • 6 Answers
Heating issue. If you remove the cover and touch the processor chip - you will not be able to keep your finger there for more than a second (that is if your really want to use this crude method to test the temp).
I have taken measurement and its around 50C. Thats a lot for no heatsink or cooling fan.
If you have the unit in a cabinet with no air flow - you will not be able to use this unit for more than 3 months and up to a year. Best to have it on top of a cabinet or in one with an open front and back to allow some airflow - or just anywhere where its in the open.
Samsung has another unit - the AR650, which I believe is discontinued - which for some strange reason has realized this concern. My guess its a whole different team of designers (or at least some folks with some brains) and added a cooling fan into the unit. Its the same exact case and motherboard as the 135, and 155. There are absolutely no issues with it rejecting disc's - even after a year of use for some users.
In Summary:
Solution 1 - Place it in the open
Solution 2 - Remove case and drill holes to the topside
Solution 3 - Remove case and add a fan
Solution 4 - Remove case and add a heatsink over proc (will still need to drill holes over heatsink..
Solution 5 - We can all complain to Samsung and have them recall the units
Posted on Aug 22, 2008
Here are some corrections of comments made by other people.
1 R155 can record on DVD-RAM/-RW/-R/+RW/+R. See page 32 of the DVD-R150 / DVD-R155 Instruction Manual.
2 DVDs recorded on the R155 are not unplayable on other devices. I have another three DVD players that all play R155 recorded material.
Posted on Aug 19, 2008
I spoke to Samsung Customer Care and they have told me that none of their DVD Recorders support DVD+ ; you can only use DVD-
Also you cannot use HD only BluRay.
I am now going to take all the DVDs back to Comet and change them - as they sold them to me as they said they were compatible.
Posted on Dec 31, 2007
Also they have lockouts
meaning you cannot watch the dvd on any other dvd player unless it is the one the disk was originally recorded on
Posted on Nov 21, 2007
I also had this problem with this recorder. This recorder seems to only be able to use DVD-R and DVD-RW disks that are either 2X or 4X.
Posted on Sep 01, 2007
SOURCE:
The dvd wont initialize blanc discs so that i can record with it.i have used different disc as well
Do you mean it won't format/initialize the disc? Alternative possible problem, when you put in a disc, does it not recognize that a blank disc is in the unit? Only DVD-RAM discs need formatting. DVD-RW discs need to be initialized. DVD-R disc do not need either formatting or initializing. (This unit does not write to DVD+R or DVD+RW discs.)
In the case of DVD-RW discs that can't be initialized. Check if this has already been done (or if you need to unfinalize the disc).
If the new disc is not being recognized as a blank disc, the recorder may not be recognizing the disc (dirt, scratches or manufacturing issue) or the recorder is not focusing on the disc properly. In the first case, clean the disc or try a different type of disc (Samsung claims that their discs will be most compatible). In the second case, the unit may need service.
I hope this helps.
(usually tracking and focus problems will be seen on both recording and playback (even with commercial discs).)
Oct 30, 2010 | Samsung DVD-R155
DVD created on my Samsung R155 won't play on other playes or PC
check the output formats the machine is writing to disk and then compare the players formats they are being used in
could be your disk type ie format type - Minus (-) or Plus (+)
One disk is better for data and the other is better for DVD video
Jul 22, 2008 | Televison & Video
Samsung DVD Recorder R155
Sounds like you recorded from a camcorder attached to AV2 (front of DVD player). Press the STOP button, then open the menu and finalize the disk.
Mar 04, 2008 | Samsung Televison & Video
Does the DVD-R155 create PC compatible DVDs?
just try to load the dvd disc.and see if it is reading..
Feb 04, 2008 | Samsung DVD-R155
"Recorded" or "Blank"? this is the Problem!
Check to see what format you are able to play on you Laptop
Sometimes they only work on some formats. Also make sure you are not recording in progressive scan
Jan 21, 2008 | Samsung DVD-R155
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Samsung R155 Recording from VHS Issues
The reason why you are having this problem is because you haven't finalized the disc. In able for you to play that Burned DVD that you have you need to Finalized the disc. Finalizing a recordable optical disc means writing the disc's lead-in (the Table of Contents or TOC) and lead-out information (blank data that fills up the unused space at the end of the disc) so that a DVD player will know where the various tracks begin and end. Without the TOC, a conventional DVD player will not be able to read the contents of the disc. Once the disc is finalized, no more information can be written to it. Finalizing takes about two or three minutes. To finalize a DVD-RW/DVD-R: 1. Press the Menu button with the disc stopped. 2. Select Disc Manager and press Enter or the right arrow. 3. Select Disc Finalize and press Enter or the right arrow. You will be asked twice if you are sure that you want to finalize the disc. Select Yes and press Enter. Once the disc is finalized, you cannot delete entries from the record list. After being finalized, the DVD-R/DVD-RW (video mode) operates in the same manner as a DVD-Video. Recorded discs must be finalized in order to play back in non-Samsung DVD players. A DVD-RW disc that has been recorded by DAO (disk-at-once mode) in a PC cannot be unfinalized. A DVD-RW disc that has been recorded in Video Mode on a non-Samsung recorder cannot be unfinalized by a Samsung recorder. A DVD-R disc cannot be unfinalized. Note: Finalization does not apply to DVD-RAM. If you cannot finalize a DVD-R or DVD-RW disc, make sure that Disc Protection is turned off. If you are still having difficulty, you may try calling technical support of SAMSUNG. Note: Do not turn the recorder off while it is finalizing the disc. Data on the disc will be damaged if the finalization process is interrupted.
Sep 17, 2007 | Samsung DVD-R155
Samsung DVD-R155 Logo
1,266 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
