Question about Bruder Cat Bulldozer
Steering clutch on 850 case dozer - Bruder Cat Bulldozer
How do i adjust free play on clutch 0n a 450 john deere dozer
The clutch is hydraulic, so there is no adjustment.
Apr 21, 2017 | Cars & Trucks
How can i load my td8e dozer on a trailer that don't start
tough one big wench possibly or another dozer to push it on
Nov 07, 2016 | Cars & Trucks
Engage clutch some times does not work. some times it will
call in a caterpillar technician as the adjustment can be tricky or unnecessary as many units use a clutch before a torque converter so the problem may not be in the clutch and the machine is too expensive to hit and miss on a diagnosis
May 30, 2016 | Caterpillar D6t Xw Elevated Sprocket Dozer...
It is a bull dozer not a lawn mower it starts and runs good but it won't move
Hi Diane:
What make and model is your machine?
I have a Case 450.
There are hi and lo speed drives for each side.
Eack drive has a clutch pack and if it does not have enough fluid in the transmission, the plates will overheat and burn out.
Please reply by "COMMENT" in this post so that I will receive notification.
Cheerfuls,
Ted
Aug 17, 2015 | Garden
850 gsl
Have you looked inside the clutch case ? check the clutch is releasing , check the keyway on the crank cog hasnt snapped that drives the clutch etc !
Apr 27, 2014 | 1980 Suzuki GS 750 L
How to fix steering clutches 1986 kumatsu d65-e dozer
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
Sep 11, 2012 | Cars & Trucks
1995 volvo 850 wagon has chronic power steering fluid leak
YOU CAN GET A USED PUMP FOR UNDER 50.00 AND IT IS EAY TO INSTALL AND DONT FORGET TO BLEED AIR FROM SYSTEM AFTER REPLACEMENT
Apr 26, 2009 | 1995 Volvo 850
Kill switch?
I would check the obvious stuff first, like the kill switch. Maybe the clutch damaged the safety switch that is operated by the clutch. But I would think that you could still start it in nuetral if that were the case. hmmmm........ There is also a safety kill switch on the kickstand that may have been damaged. It should not be any kind of major problem from just a little fall. Good luck
Nov 20, 2008 | 2003 BMW R 850 RT
Bruder Cat Bulldozer Logo
158 people viewed this question
Top Bruder Toys Experts
MarK
Level 1 Expert
ptpumpman
Marc Taylor
Are you a Bruder Toy Expert? Answer questions, earn points and help others
