Question about Bosch Dishwashers
We have a bosch Avantixx and error code E08 is showing which has frozen the dishwasher
5 Suggested Answers
  • 109 Answers
SOURCE: What is error code 2H
doesnt sound like an error code it sounds like its the delayed start feature, not sure that bosch ever used error codes
Posted on Jul 07, 2009
  • 1575 Answers
SOURCE: bosch dishwasher error code c1
Hi
Pump-out not accomplished in normal time.
Check the drainage and replace or reposition the drain hose,Clean it out by running the disposer.
Posted on Feb 27, 2012
  • 51 Answers
SOURCE: Bosch dishwasher showing e:15 error code.....how do you fix it?
E15 means that unit doesn't think it's getting water
If there is not water inside the tub then you have a problem with your electronic water valve and will need to have it replaced. If you do have water inside but it's still giving you the error, then you have a bad flow meter that iwll need to be replaced
Posted on Nov 18, 2012
  • 34 Answers
My Bosch dishwasher did the same thing. When the wash cycle starts, the dishwasher fills with water and then the heater is supposed to turn on to heat the water. If the water does not heat, then it will display 2H continuously. The heating element may be bad, but a more likely cause is with the control module. Bosch has a problem with the control module printed circuit (pc) board that powers the heater on many models. The solution requires some technical expertise and soldering skills. The details are explained in the document "Bosch dishwasher troubleshooting tips" on page 11. Download here
Bosch recommends re-soldering the connection, which is a temporary fix. The problem is that the copper conductor (called a trace) on the circuit board is not wide enough to handle the current required for the heating element, and as a result the copper trace overheats, causing the solder to melt on the relay connection. The best solution is to remove the control module PC board and solder a short length of copper wire between the pins to prevent the overheating problem, as shown in the attached photo (magnified portion of PC board). I did this on my dishwasher and it has been trouble-free for over 3 years.
Posted on Nov 17, 2013
I have a Bosch dishwasher with the E24 error code. Did everything the entire thread has suggested and still no help. It's been -22 here the last few days, is it possible foe the drain to freeze? I tried...
This says it is 'the drain is blocked.' So most likely it is frozen from what you posted. You could heat some water and pour into the bottom of the dishwasher to try and thaw the freeze. Got nothing to lose.
http://www.drdishwasher.com/troubleshooting/manufacturer/bosch/error-codes
Jan 02, 2018 | Bosch Dishwashers
Tip
Xbox 360 RROD E08 / error code 0020
x 360 RROD E08 / error code 0020x 360 RROD E08 / error code 0020x 360 RROD E08 / error code 0020
on Mar 25, 2010 | Microsoft Xbox 360 Console
My Bosch AvantiXX front load washing machine has finished the wash and now it has locked on me and I can't open it. How can I open the door?
hi Suzanne.
i have had a look around the internet and found that there is lots of ways to try and open it.plus there is people on youtube showing how to open a door.
so if you go to this link and pick the one you think would be the best one for you to try.
Bosch AvantiXX front load washing machine door wont open Google Search .
or this one.
How to open washing machine door that won open normally
Nov 20, 2017 | Bosch Washing Machines
Our bosch dishwasher shows an error code H:21
There are many reasons why Bosch Dishwasher Error H21 happen, including having malware, spyware, or programs not installing properly. You can have all kinds of system conflicts, registry errors, and Active X errors. The registry on your computer will accumulate errors over time. It's just a fact of life in the computer world. This happens as programs are installed and modified, or even removed.
May 11, 2017 | Bosch Dishwashers
How to reset the error code F21 on a Bosch Avantixx 6
You can try the following steps:
1. Turn the washer knob to the 'off' or reset position 12 o'clock.
2. Turn the knob to the 6 o'clock position.
3. Press and hold the spin button.
4. While holding it, turn the knob to the 7 o'clock position.
5. Continue holding the spin button for about 5 seconds.
6. Release the button.
7. Turn the knob to off.
When your turn it back on it should have cleared the error code.
Jul 21, 2016 | Bosch Washing Machines
Bosch avantixx 8 waq error code e44
E44 means a motor fault. More here: http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3310-bosch-logixx-was-series-washing-machine-error-codes.html
Mar 03, 2015 | Bosch Washing Machines
ELECTROLUX DRYER T4130, error code E08 show on panel. have tried turning power on and off, but still the error code E08.
Dryer had been overheated (clogged or damaged air filter). Reset 3 thermo-fuses (small red buttons): 2 under top cover and 1 under back side round cover
Jan 02, 2011 | Electrolux Dryers
Bosch excel 7 with F63 error code Cleaned the
my dishwasher will not dispose of the water and remains stuck on a cycle
Nov 27, 2010 | Bosch Washing Machines
Hoover error E08
hi I had this fault, google said it was tachometer fault. the e08 fault on my hoover optima was not the tachometer, i checked it, but the fix was very easy, the motor brushes were worn out and i changed them for 10 quid, I made a video of it its on youtube http://www.youtube.com/watch?v=xYn-f78GB4U and it shows you how to test the tacho and how to change the brushes, hope this helps someone
Oct 02, 2009 | Washing Machines
Dishwashers Logo
116 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
