Question about Mustang Rzt 50" Zero Turn Riding Lawn Mower
How to check safety switch on rzt50 zero turn
Got a cub cadet zero turn rzt50 the throttle cable moves back and forth but will not idle down
Check if the small clamp that holds the cable to the engine is tight. The entire cable may be moving with the throttle rather than just the wire inside the cable.
Oct 02, 2017 | Cub Cadet Garden
Zero turn mower shuts doun when trying to go when engaging control arms
On my RZT50 Troy Built I have to engage the parking brake to start it and release it before I move the arms in over my lap or it shuts down.
Dec 10, 2016 | Garden
My RZT 50 turns blades on when levers are pulled back instead of shutting of and shuts off when in forward position ? could it be a switch is bad if yes what switch?
Sounds like someone has been working on the wiring, probably trying to bypass the reverse cut out switches . If you follow your steer control lever down under the plastic console covers there will be a switch, one on each steer lever by where it hinges. I don't think the switch is bad because it would not work at all if it was.It is like a door bell switch, when you pull back on the steer control lever it pushes it in and disconects the circuit to the PTO switch and the blades quit until you push them forwards and lets the curent through again. Also check the push pull PTO switch .Every safety switch on the tractor will meet at that switch and plug into it, . That model cub RZT50 has to have the worst switches ever made, but they are available and cheap on ebay. Plunger Switch 430362 430 362 for Cub Cadet Troy Bilt MTD 700 Series 725... PTO Switch MTD Cub Cadet Mowers GT RZT LT Force Mowers 925 04175
Apr 25, 2016 | Cub Cadet RZT L50 50" 23HP Zero Turn Mower...
Ihavert42.zero turn pto will not work
Check PTO switch
check fuses
check safety switches on the mower.
Mid all good then you will probably need to replace the PTO clutch.
Check switches using a voltmeter
Jul 11, 2015 | Cub Cadet RZT L42 42" 22HP Zero Turn Mower...
How to change out an electric clutch on a cub cadet zero turn RZT50?
Removal is simple if you have access to an impact wrench so you can the center retaining bolt.
When re-installing anti-seize compound needs to used on the crankshaft so the new clutch assembly doesn't seize on the shaft. To tighten the center bolt you must hold the flywheel in place by blocking it. This center bolt must be torqued to 45-55 ft fts. Also the new pto clutch needs burnishing in. Most new clutches come with instruction on this procedure.
Jul 23, 2014 | Cub Cadet Riding Lawn Garden Zero Turn...
I have a cub cadet rzt50 zero tudn. Blades are new and sharp but when i cut there is a trial of cut grass in the center of the mower tracks that is left behind. Mower is only a few years old with 100 hours...
if this started after the blades where replace make sure you have the right blades zero turn and reg mowers have different blades then check the bearings on the blade mandrels then last is to check for a rotted out deck with the belt tension pulling the blades apart
May 16, 2012 | Cub Cadet Garden
I have a cub cadet rzt50 mower...Need to replace a tire
There is a thru bolt, and inside and outside bushing, and center sleeve. Remove those to remove the wheel. Obviously support the frame on a jack. Most tires can be removed using a slight soapy solution and 2 smooth screwdrivers. Replacement, use a soapy solution around the bead, and using only hand pressure put the tire back on. Use a cinch strap around the center of the tire to help keep the tire beads against the rim and air it back up.
Apr 15, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Cub cadet wont engage blades to cut grassmower iz rtz 50 zero turn tried to move the wires around and checked the 20 amp fuse no shorts. was cutting fine i just stopped to dump the bagger. any help would...
Try this:
With the engine turned OFF, unplug the wire connector at the PTO clutch, and use an alternate 12 volt DC power source and some alligator clips to manually power-up the clutch. If a firm, crispy "Click" is heard each time you "power-on / power-off" the clutch, then safety switches on the tractor are the most likely suspects.
If no firm, crispy "Click" is heard, your PTO clutch needs to be replaced.
On the right-hand side of THIS page, type in (without spaces) RZT50 and you will be given a list to choose your EXACT machine & part number.
Special Note:
If your part number description says to refer to "Service Advisory ...(blah blah)" then you will need to call a servicing dealership for the proper replacement part number.
Hope this helps.
Oct 04, 2009 | Oregon Scientific Oregon Gator Mulcher...
Mustang Rzt 50" Zero Turn Riding Lawn Mower Logo
18 people viewed this question
Top Mustang Garden Experts
Dennis Key
Dennis Key
Randy Schumann
Randy Schumann
Paul Sikkema
Paul Sikkema
Are you a Mustang Garden Expert? Answer questions, earn points and help others
