Question about Vacuums
Beater bar not rotating on panasonic mc-ul592
reddevil6
  • 1673 Answers
SOURCE: panasonic vacuum cleaner MC E554
Wish you had listed your model number, they are all different you know, that wire you refer to I have seen on some models and it is only a belt guide. Should be a slot that it fits into.
Posted on Mar 03, 2008
frcs68
  • 1605 Answers
SOURCE: there is suction but no rotation of beater bar
replace the drive belt.
turn the vacuum over. take the buttom plate off, you can access the roller (beater). there should be a belt attached to the roller and the motor shaft.
Posted on Apr 14, 2009
  • 909 Answers
SOURCE: ran across shoe lace and when I pulled it out the beater bar quit rotating
If you can turn the beater by hand(when unplugged) and its easy to turn then it's the drive belt, they do not take long to burn through, and leave a horrid burning rudder smell as a clue.If its hard to turn you have jamed a piece oof lace in it.
Posted on Jun 02, 2009
  • 636 Answers
SOURCE: Beater bar not rotating
Remove the screws from the bottom of the power head.
Posted on Oct 09, 2009
  • 389 Answers
SOURCE: My beater bar will not turn. The motor runs but
This certainly suggests the clutch has packed up, although it is possible that the belt that runs from the motor to the clutch has failed (I assume you've checked the other belt, as it's very easy to see). Changing the clutch, and the motor-to-clutch belt, is not a job for the faint-hearted. If you want to see what's involved go to www.dysonmedic.com scroll to the bottom of the page and click on DC07 clutch replacement.
Posted on Feb 17, 2010
I was told by a previous repair man that there is a fuse in the beater bar that needed to be replaced.
Up to my experience in my Panasonic vacuum cleaner, if the beater bar is not working this could be because the 'Carpet/Floor' selector switch is in the 'OFF' or 'FLOOR' position. In both of these positions the beater bar will not rotate. Move the selector switch to the 'CARPET' position. When in this position the beater bar will rotate once the foot pedal is pressed.
If the selector switch is in the 'CARPET' position and the beater bar is still not rotating it could be that there is something entangled in the beater bar, or the belt is worn or broken.
To check this first unplug the vacuum cleaner
Inspect the beater bar and belts to ensure that there is nothing entangled in the beater bar and that the belts are intact and are not excessively worn. If the belts are excessively worn they may slip resulting in the beater bar not rotating.
The vacuum cleaners often have an overload protection system inside the nozzle, which stops the nozzle motor when the beater bar jams to prevent belt breakage. After clearing any lint build up or jamming you may need to reset the overload protection, by pressing the reset button on the top of the floor nozzle.
May 04, 2015 | Vacuums
Brushes don't turn on my Panasonic Eco vacuum cleaner
Check to see if there is anything holding the brushes in place, i.e., thread, hair, gunk, etc. Or, they could have gone round on the ends and you need a new brush assembly. Not expensive and easy to replace. Just look at it when you remove it. You may have to jiggle the new one in place as they are sometimes square and just irritable when you are trying to put them in. FYI - swearing does not help! Oh, I forgot to add, check to see if the belt is broken. They are not hard to put in either. Buy a couple, it's good to have a spare:)
Oct 25, 2014 | Panasonic Mc-Ul592 Eco Max - Bagless...
Panasonic optiflow upright vaccum
Hello, Put the vac on its side and remove the screws holding the cover plate on. This exposes the beater bar and belt on the side. Pull the beater bar out and take the belt off. Reverse this to put the belt back in place.
May 30, 2014 | Panasonic MC-UG323 OptiFlow Upright Vacuum...
How to fix - unit sparked and died
It's best to have it checked by a professional technician. Sparks can lead to fire.
Jan 04, 2014 | Panasonic Mc-Ul592 Eco Max - Bagless...
Installing new belt
+>> Unplug the mains lead from electrical socket <<+
• Turn cleaner over in flat position.
• Release lower plate by rotating the 3 lower plate latches to the UNLOCK position.
• Remove lower plate and remove any dirt that may exist in belt area.
• Remove beater bar by gripping the belt side of the beater bar and carefully lifting it out.
• Remove worn or broken belt.
• Clean beater bar and the end caps.
• Loop new belt around motor shaft and beater bar belt groove.
• Reinstall the beater bar by inserting the end cap of the beater bar to the slots at both ends of th beater bar.
• After reinstalling the beater bar, turn it by hand to make sure that belt is not twisted or pinched and that all rotating parts turn freely.
• Reinstall lower plate by hooking front end of lower plate into slots on front of nozzle.
• Press lower plate onto nozzle and secure by rotating the 3 lower plate latches to the LOCK position.
Jan 12, 2013 | Panasonic Mc-Ul594 Eco Max - Bagless...
Panasonic upright bag MCE3001 smell of burning rubber, beater not rotating but suction ok. how do i clean the wheel and or fit a new belt?
Hi, You need to disassemble beater bar. There is a belt that is broken and rubbing on motor. Replace the belt with new on.
Jun 10, 2011 | Panasonic Vacuums
Panasonic MC-CL673 vacuum is not getting up to speed and smells
Even though the brush is spinning, you probably need to replace the belt2_bing.gif because it is stretched. It is probably slipping on the beater bar. This is causing the smell (burning rubber). I don't believe it is your motor. :-)
Jim
Nov 29, 2009 | Panasonic Vacuums
Oct 09, 2009 | Panasonic Kenmore Canister Vacuum Vacuum
Vacuums Logo
89 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
