Question about Ruud UBHC Air Conditioner
My system uses a permanent air filter that is missing. The Model is RUUD UBHB-24J18SUEA. I can't find any literature on it. Is there an owners manual out there somewhere?
There's a sticker on the front that says "Filter Access Panel: The filter installed in the unit is a permanent type and requires periodical cleaning...DO NOT OPERATE THIS SYSTEM WITHOUT A FILTER IN PLACE" I couldn't find any filter. I do have an air handler with a 16 x25x4 filter. Does this take the place of it?
2 Suggested Answers
  • 5381 Answers
SOURCE: My system uses a permenant
The Ruud UBHC-21J18SHG has a nominally 21" cabinet width. So the needed filter is 19.75" x 21" x 0.375" (502 mm x 533 mm x 9.525 mm). The Ruud part number for the filter is 54-23217-03 .
The specifications sheet for the Ruud UBHC series air handlers is available here: http://www.coburns.com/images/PDFs/h22-517rev1.pdf . The filter size information is on page 3 and page 12.
I've found the filter at one online vendor: http://www.patriot-supply.com/products/showitem.cfm/RHEEM_68_101807_03 . (This is a common filter that fits several manufacturer's air handlers.)
I hope this helps.
Posted on Sep 11, 2011
My system uses a permenant air filter. It's missing. It's a Ruud Model UBHC-14J11SFA. What size replacement filter can I put in this system?
You can measure what size and use any after market permanent filter. Measure the opening to the rear and across the opening. Should read as ?x?
Dec 03, 2014 | Ruud Heating & Cooling
Ubhb-21j11sfdai: what motor should be in this blower? HP, RPM, Voltage, Amp?
If you have the motor from the blower, the information should be on the motor nameplate. If there's no nameplate or information on the motor. Then to get the correct motor for your blower, you need to call your local Rudd dealer or local parts store. Give them the model number and serial number of the Rudd unit and they should be able to help you.
Jun 11, 2013 | Ruud UBHC Air Conditioner
RolAir PMP11MK238PFI owners manual
Go to the RolAir website (http://www.rolair.com/) and under Literature select Owner's Manual, hopefully your model is listed. You'll have to use the proper model number of your air compressor, PMP11MK238FI is the part number of the air pump only. If you need a breakdown of the pump try a site like http://www.ereplacementparts.com/, you can see a breakdown of the pump and order any parts you may need.
Mar 20, 2012 | Air Tools & Compressors
My system uses a permenant air filter. It's missing. It's a Ruud Model UBHC-21J18SHG. What size filter should I put in this system?
I hope this helps.
Sep 10, 2011 | Ruud UBHC Air Conditioner
I have a RUUD central air conditioning system, model NBHC-18J20SFA. The cooling function is not working. The fan on the outdoor unit is not working. When switching to COOL, the compressor works for a few...
sounds like the outdoor fan motor and/or capacitor needs replaced. The compressor will run for a short time because the fan is not pulling the heat out of the system, it can cause damage to the compressor if the fan is not repaired, Ruud used a 3uf capacitor rating for the outdoor fan motor, if the motor has been changed make sure the proper capacitor is also changed for the new motor rating.
Jul 05, 2011 | Ruud UBHC Air Conditioner
I don't have a problem with my product...im trying to find out how many watts do my product use. Model #uamb-036jaz serial #6263f040410617
Brand: RUUD Manufacturer: RHEEM Model Number: UAMB-036J* Condenser Type: air-cooled Condenser Coil Model Number: RCGA-36A2 System Configuration: split-system air conditioner Cooling Capacity: 34,200 BTUHs per hour Efficiency: 12 SEER
10.5 EER Electrical Service: Single-phase Electrical Input: 3,272 watts per hour Voltage: 230 and 208
Jul 01, 2011 | Ruud UAMB Air Conditioner
IS the filter for permanent use or can I buy a replacement?
It depends upon your maintenance. Some filters long lasting, if frequently cleaned. Helpful?
Jan 15, 2011 | Ruud UBHC Air Conditioner
Filter Placement Ruud UBHA
hey brad first you need to indentify wich is your supply and wich is the return after you have done that the filter is allways on your retun side however not allways is the filter set up at the air handler sometimes its in a duct sytemn on the ceeiling or wall hope you find it
Jul 05, 2008 | Ruud UBHC Air Conditioner
Ruud UBHC Air Conditioner Logo
61 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
