Before you give up check on ebay. If you do replace just make sure that the physical size is the same and that the replacement uses the same cpu and memory you have now. Otherwise you will be spending much more dinero.
Did you test the power supply with a power supply tester? You may only have partial power or very low power. I would try a power supply from another pc, Then I would check the ram in another pc if possible one stick at a time or if no other machine : I would try removing all the ram and try one stick at a time in a different slot each time till it boots and then try a different stick the same way. You could have a bad memory stick and or slot. I think its the power supply first, a bad stick of ram second or a bad ram slot third and the motherboard last. I would try all my parts in another pc first before a buy another motherboard
