Logik L32DIGB20 Recently moved the TV, now i get no power or standby light, have checked power to the TV, is there another internal fuse?
  • 3 Answers
SOURCE: No power light on TV, power at outlet, acts like internal blown fuse
Make sure your main switch near the power cord where fits in the tv is on,if it is and you have power in the outlet you have a power supply problem.i sugest to take it to a repair shop.I am a technician but i am in Puerto Rico otherwise i would be more than happy to fix it for you.I have a good experience with these tv and have fix a lot with thesame problem.
Regards and good luck,
Jorge.
Posted on Aug 24, 2008
  • 187 Answers
SOURCE: Can turn on to red light and get blue light, but no picture
The mainboard needs to be replaced
Posted on May 27, 2009
budmrtn
  • 11361 Answers
SOURCE: TV will not turn on
You need to look inside next.
If you are going to DIY and have proper tools, knowledge of electronics and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jul 09, 2010
SOURCE: Hi,my LG 26LB75 LCD TV displays nothing at all,no standby
hey man,
i have th same problem. have you find any solution?
Today i will verify, if the problem isn't it in noise filter IF - N06AEW.
I will post a result. Please let me know about your solution.
thanx
mailto: daniberk@centrum.cz
Posted on Jul 16, 2010
gopakumarg43
  • 74383 Answers
SOURCE: need code to get sky
Hello
If your Tv is LOGIK; skay remote codes are :
221 033 061 039
726
If it is LOGIX; code is:
696
OK.
Posted on Jun 29, 2011
LED52B45RQ RCA TV will not turn on
Could be an open internal fuse or power supply failure. The "standby light" merely indicates that power is getting to the TV.
Jul 14, 2016 | RCA Televison & Video
I need the code for my Logik tv model no L32DIGB20 SO I CAN PUT IT IN TO MY SKY REMOTE
Try this clip I have just found, hope it helps.
TRY 0335 OR 0060
PRESS TV ON YOUR SKY TV REMOTE , PRESS RED & SELECT TOGETHER UNTIL RED LIGHT FLASHES TWICE , PRESS TV ENTER 0335 OR 0060 PRESS TV AGAIN THEN THE OFF BUTTON IF THIS TURNS OFF YOUR TV SELECT IF NOT PRESS TV THEN THE OFF BUTTON AGAIN REPEAT THE LAST BIT TILL THE TV TURNS OFF THEN PRESS SELECT ; DONT RUSH THIS BUT FOLLOW THIS TO THE WORD HOPE THIS WORKS FOR YOU .
I FOUND THIS ANSWER ON THE WEB IT'S BY AN EX SKY ENGINEER . GLAD TO HELP...
Dec 19, 2015 | Televison & Video
Logik L32DIGB20 TV comes on with retrieving data sign & control won't work anything whilst this on screen. Says refer to manual re firmware - not in mine - help please
A firmware update is necessary. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 27, 2015 | Televison & Video
My LOGIK L22DVDB19 was working O.K. We had to turn the Power-Off for work to be carried out. When the POWER was turned back on, everything worked save for the TV?- No red light on: can anyone help?
Check that the power cables were properly seated to the power board internally. If your TV is not starting at all, then likely this occurred, or that the cables are not seated properly to the TV. Any number of things can happen when you do servicing to the TV, assuming that had happened.
Jan 15, 2015 | Televison & Video
Logik l22 fed12 stuck in wont come out of standby
sounds like a Power Supply Board gone bad, or an internal fuse could be the problem, (which is an easy easy fix. ) just make sure the unit is UNPLUGGED from the wall socket. If it is a power supply they too are easy to replace also.. be sure and be careful some of those cap. can still store energy and give u quite a jolt. NOTE ,,, take pictures of the inside of the TV,. take close up of the power supply and make sure u get the model # off the power supply board itself. and get an exact match when u order. I usually try Shop JImmy.com first. DO NOT remove the power supply till u have the new one in your hands. that way u won't for get how it hooked up..
Jan 07, 2015 | Televison & Video
Need base stand for logik l32digb20
I need one too for same model. if you find let me know
Mar 25, 2013 | LG 32LD550 32 in. LCD HDTV
LOGIK L32LW783
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.4_3_2012_1_28_26_pm.jpg look at power board for caps puffed up like these
Apr 02, 2012 | Televison & Video
I have a logik television HDMI 28 inch with builtin freeview and dvd. The standby light stays on when I try and put the tv on. It wont kick in to let tv turn on and remains red/standby. Any advice?
Hi Sarah,
Please check your :
- Power board . You may have defective part like IC and capacitor
- Video board. A defective part in this board will make your display stay freeze.
Regards
Sep 27, 2011 | Televison & Video
Need code to get sky remote to operate LOGIK L32DIGB20 tv
Hello
221 033 061 039
726
696
OK.
Jun 29, 2011 | Televison & Video
Tv wont go from standby to on....
I SUGGEST TO CHECK THE INTERNAL FUSE , IT MAY BE OPEN
Dec 06, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
